Replacing hard drive
open
PostPosted: 11:03 - 28 Aug 2013    Post subject: Replacing hard drive Reply with quote
My Hard drive has broken on my netbook.
Want to replace it - physically replacing isn't a problem. But what do I do about re installing windows 7? I have no CD drive. If I replace it will I have to buy Win & again or what.
Please help thanks!
"Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
[s]Baotian BT49qt-9 --> Honda CG125 (4 speed) '51 plate ----- 03/11/2012 Mod 2 PASSED! --> Cb500s[/s] Revoked Sad
Phil.
PostPosted: 11:17 - 28 Aug 2013    Post subject: Reply with quote
I expect you will have the option to re-install using a bootable USB drive.
Firstly go in to your bios settings and make sure USB is set as a primary boot option.
Then you will need to get windows 7 installed on a USB stick.
Microsoft provide a tool to do this for you;
https://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool
t121anf
PostPosted: 11:51 - 28 Aug 2013    Post subject: Reply with quote
ISOs are available from here
https://www.w7forums.com/official-windows-7-sp1-iso-image-downloads-t12325.html
Providing you have your key you don't need to buy again, if you don't have it and don't want to pay you can use such programs as win loader.
there was a thread in here not long ago with other activation tools.
prawny1
PostPosted: 14:30 - 28 Aug 2013    Post subject: Reply with quote
How has your drive broken, does it still power up etc?
If you can't boot from it or run windows repair, try cloning it to another drive then running the repair facility.
You will have to do an advanced repair using the cmd to fix mbr etc but will be more likely to succeed on a healthy drive.
I had to do the same on a laptop drive on a sony for my sister in law, she wanted to try save all her pictures and the recovery partition and stuff after the drive started throwing up bad sectors and wouldn't boot or repair.
It did bsod a couple of times since when trying to access corrupt data cloned over but it stabilised after a few check disk runs, I was expecting to be able to access the cloned drive to save the data then wipe everything fresh but she has been using it daily for months now.
hellkat wrote:
Scotsman37
PostPosted: 11:35 - 30 Aug 2013    Post subject: Reply with quote
Like others have stated you can either load it from a USB Data stick drive that had been made bootable, and once done go into your BIOS and tell your system to look at your USB device 1st to find the bootable Windows device.
Or you can buy an external CD/DVD drive for £15 on Ebay or so and use a bootable Windows Disk that matches your version of Windows allowing you to use the Windows COA label found underneath your netbook which load the correct software. You must keep in mind that you will need download the drivers from manufacturer's website to access the special features your netbook i.e. chipset drivers, etc, and for your webcam, etc.
If your Hard drive may or may not be dead and one way of checking it is use an external hard drive casing for laptop hard drives which comes with USB connection cables from Ebay for about £5. This will allow to possibly access your hard drive otherwise you may need to load specific software that allows you to recover data from a damaged hard drive.
CaNsA
PostPosted: 11:42 - 30 Aug 2013    Post subject: Reply with quote
bitch please....
drop me a pm and ill hook you up with windows 7 enterprise
Ive been using this release it for years without any problems at all.
prawny1
Scotsman You just reminded me that is what I had to do with the sister in laws, I fitted it in an external caddy then copied each partition to the new one at a time because it kept erroring when I tried to copy the whole drive at once THEN ran the repairs from the recovery environments cmd prompt.
open
PostPosted: 12:21 - 01 Sep 2013    Post subject: Reply with quote
When it boots it asks to insert bootable media - so I think its pretty gone. Not to bothered about the stuff on it (except some music - but everything else wasn't to important) so not really bother about repairing it. Just want to replace it and install windows.
I think the main thing being I dont have the windows serial key any more. So can someone elaborate on how to activate an ISO of windows 7?
PostPosted: 12:41 - 01 Sep 2013    Post subject: Reply with quote
Daz boot loader. I asked the same.
https://www.bikechatforums.com/viewtopic.php?t=277377
SQL
PostPosted: 13:07 - 01 Sep 2013    Post subject: Reply with quote
https://forums.mydigitallife.info/threads/24901-Windows-Loader-Current-release-information
Hit install and forget about it
prawny1
PostPosted: 17:34 - 01 Sep 2013    Post subject: Reply with quote
Have you checked your boot options in the bios, you could have the hdd disabled somehow, one of my desktop machines sometimes detects usb drives left in the pc as bootable and sets them to boot first and I have to go into bios and put the hdd back as first boot device.
Download the windows iso anyway and run the fixboot and fix mbr from the advanced cmd options, you might get lucky.
I have replied to a few threads recently about how to make a universal install disc that will activate on any machine (non branded get daz'z loader) all the tools can be had for free and the iso and usb tools are genuine Microsoft so no risk on getting iso's with virus's injected.
Even if you decide to make a plain install media I can highly recommend creating a usb drive for it as it will load a lot faster than a dvd.
The last post was made 12 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 72.84 Kb
