Damn burnouts!
Fire_Eyes
PostPosted: 19:13 - 12 Dec 2004    Post subject: Damn burnouts! Reply with quote
Me and my friends decided to change the rear tire since we bought the bike 2months ago and it's second hand. So like the nice noobs we are we decided to do burnouts... try actually Embarassed ... After each of us tried a few times we gave up. Then my friend was like your always reading things on that forum of yours. I told him yea I read a tutorial, front break in all the way feet on ground just in case. Rev up to 6k then release clutch... sadly it didn't work with me. Anyway he kept on trying and now I think the clutch is ....well fucked! The bike wont accelerate after 4k on first gear. Tried to pull the clutch in a bit, changed gears..nothing changed. Lucky for me I was intending to take the bike out for repair on wednesday. How much would it cost to fix this problem? What was I doing wrong? The rear spun a few times, the other few it was moving forward Evil or Very Mad .
Kawasaki ZZR 400 | K5 GSX-R 600
Sparks!
Sir Tart-a-lot
PostPosted: 19:19 - 12 Dec 2004    Post subject: Reply with quote
It's a burnout, not rocket science! Laughing front brake on fully then accelerate and let the clutch out, bingo one spinning wheel! Laughing
california_rookie
PostPosted: 19:21 - 12 Dec 2004    Post subject: Reply with quote
Hmm. I don't think anyone will argue against the fact that burnouts are bad on the clutch..
...that being said, burnouts should be really easy to do, as long as you're not placing any weight on the seat or rear portion of the bike. My little 600 has absolutely no problem breaking rear traction at 2500-3000rpm.
Is there a chance that you and/or your friends weren't completely off the bike while attempting to initiate wheelspin?
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Sparks!
Sir Tart-a-lot
PostPosted: 19:23 - 12 Dec 2004    Post subject: Reply with quote
They aren't bad on the clutch unless you keep feathering the clutch, getting the wheel spinning is barely different to pulling away so it does not damage the clutch any more than pulling away does, unless you feather it but we're talking a stationary burnout? No need for clutch once the wheel is spinning...
PostPosted: 19:27 - 12 Dec 2004    Post subject: Reply with quote
It depends on the bike. Initially you may need to feather it a bit to get it going, but once you are used to doing them it should be fine.
More likely the clutch was already on the way out and this just finished it off.
On my zx9 you don't need to use the clutch at all... doing a rolling burnout you just increase the front brake pressure as you turn the throttle without touching the clutch Smile.
Fire_Eyes
PostPosted: 19:43 - 12 Dec 2004    Post subject: Reply with quote
G are you trying to piss me off cause it's working Laughing . Well yea I was actually sitting on the bike Embarassed . Don't laugh please but am I supposed to dump the clutch or let it out easy cause I'v heard 2 different ways Confused .
california_rookie
PostPosted: 19:45 - 12 Dec 2004    Post subject: Reply with quote
Yams: Smaller motors need much higher revs to produce enough power to break traction, which is very hard on the clutch, especially the smaller clutches on such bikes. Besides, when you're taking off from a light, you're probably using about 2000rpm and the clutch is having some success at getting the wheel spinning. When doing a burnout, the clutch is working against a stationary object at much higher rpms. In this sepecific case, FE states that a number of people had a go at it. Seems like the clutch might have sustained some damage in such strenuous conditions, though I don't think you stated otherwise.
Apparently I was wrong about no one arguing on the side of the burnout. Razz
As always, don't hesitate to point out any errors I've made as I'm admittedly not the brightest.
I would recommend letting it slip at first. Once your comfortable with it, dump away. That's how I did it, anyway. Thumbs Up
Sitting on the bike while trying to get the wheel to spin is a major no-no. Feel free to have a seat once you get it going, but to get it to spin in the first place, you want to keep as much weight off the rear as possible.
Fire_Eyes
PostPosted: 19:55 - 12 Dec 2004    Post subject: Reply with quote
Alright, thanks a lot for the help. However what's been happening with me is sometimes the bike sort of jumps forward. What if I'm standing and it jumps Exclamation Question . And I would like to say ARE YOU INSANE!! I CAN'T WAIT TO GET A GIXXER AND YOUR DOING BURN OUTS WITH IT! Rolling Eyes
Sparks!
Sir Tart-a-lot
He's got a ZZR400 not a 125... ZZR would break traction relatively easy thus not requiring much clutch abuse!
Nowt wrong with sitting down... weight over the front is essential for rolling, but stationary I've never felt the need to stand up.... maybe that's just me tho Laughing
PostPosted: 20:11 - 12 Dec 2004    Post subject: Reply with quote
I wouldn't have thought a zzr400 would have that much low down torque, being an inline 4 400cc.
If you are trying to do stationary burnouts...
Stand up, pull the front brake on and maybe put a bit of pressure on the bars to help aid front end traction. Try to keep your weight off the bike apart from the front end.
To get used to it you will have to slip the clutch a bit. On a clutch that has life left this shouldn't be a problem, only likely to cause trouble if the clutch is already on the way out.
Start slipping the clutch as you would to make a quick getaway, but keeping the front brake hard on. Give it quite a lot of revs and let the clutch out slowly. If the bikes starts to stall, give it more revs until the rear starts to spin a bit. Once it starts to move smoothly let it out all the way.
If you are trying to do 'rolling' burnouts...
Start going along slowly, then do the same procedure to get it spinning. You however have to control the brake to keep the speed correct, so you can't just grab a big handfull.
I try to keep all my weight over the front by standing up around the tank and leaning down on the front. See: here for an example.
california_rookie
YOU CALLIN' ME FAT?! Twisted Evil Laughing
PostPosted: 20:13 - 12 Dec 2004    Post subject: Reply with quote
Or because it doesn't make any difference on your wr? Razz
Sparks!
Sir Tart-a-lot
PostPosted: 20:19 - 12 Dec 2004    Post subject: Reply with quote
I'm not talking about the WR, I rarely do burnouts on that as it's got a shite front brake.
ZXR, R6... never felt the need ever to stand up..... only time I ever stood up is for rollng......
Fire_Eyes
PostPosted: 20:24 - 12 Dec 2004    Post subject: Reply with quote
ZXR, R6, GIXXER 600, CBR ... WHYYYYYYYYYYYYYYYYYYYYYY? Crying or Very sad . Thanks for the help G I'll try just that in 2 months time, the new bt 014 might wear out by then.
Fire_Eyes
PostPosted: 20:32 - 12 Dec 2004    Post subject: Reply with quote
Oh and yes the zzr 400 isn't great at low revs Sad . If your own first gear you feel like the bike doesn't accelerate fast untill your at like 6k but after that it's fast Cool fast enough for me since I'm still new.
Sparks!
Sir Tart-a-lot
PostPosted: 20:38 - 12 Dec 2004    Post subject: Reply with quote
Anyone got a ZZR400 I can borrow??? Razz Twisted Evil Laughing
Fire_Eyes
PostPosted: 20:41 - 12 Dec 2004    Post subject: Reply with quote
Laughing You think you can manage to get it accelerating faster Yams? I'd let you try but im in the other end of the world Mr. Green .
Sparks!
Sir Tart-a-lot
PostPosted: 20:44 - 12 Dec 2004    Post subject: Reply with quote
I don't think it'd be /that/ hard on a ZZR400 no! Razz
Fire_Eyes
PostPosted: 20:50 - 12 Dec 2004    Post subject: Reply with quote
I'm not saying it's slow. It's a really nice bike! Heavy though... It's fast really i just don't ull throttle everywhere but I've noticed that below 6k the power doesn't come out as smooth. I feel gay Sad . I want gixxer 600 2005 model, black and red! Hell I saw a 636 today for sale, isn't that a nice bike! and the sound is just Thumbs Up . And the tacho goes up a lot faster than my zzr doesn't it Middle Finger .
Sparks!
Sir Tart-a-lot
PostPosted: 20:53 - 12 Dec 2004    Post subject: Reply with quote
No one is saying the ZZR is slow, calm down Laughing
PostPosted: 20:56 - 12 Dec 2004    Post subject: Reply with quote
I've always found that standing up for stationary burnouts at least helps, as I've often had it jumping forward if I try sitting down.
Fire_Eyes
PostPosted: 20:59 - 12 Dec 2004    Post subject: Reply with quote
I know Yams but it's sad. I walk in a bike shop to buy oil and I see this nice green thing for sale that sounds nice, then I look to my left and see a nice little R6. While the shop is surrounded by a 2004 red R1. So I enter the next shop to notice a 999r and a 749 another R1 and a 2005 MV Agusta!! Buys oil... Gets in car.. returns home...burns clutch Laughing .
Sparks!
Sir Tart-a-lot
PostPosted: 21:01 - 12 Dec 2004    Post subject: Reply with quote
CBR/R6/GSXR/MV aren't the best things in the world mate Razz can often have more fun on cheaper, smaller CC bikes... well... I found out the hard way anyway... so did G and a few others... one day you'll learn too! Laughing
Fire_Eyes
PostPosted: 21:02 - 12 Dec 2004    Post subject: Reply with quote
True, but I'm sure all the bikes you just listed look nicer than a ZZR. Hell I'm just glad I gave it a nice black paintjob... Are you suggesting a dirt bike Laughing ?
Sparks!
Sir Tart-a-lot
PostPosted: 21:06 - 12 Dec 2004    Post subject: Reply with quote
Fire_Eyes wrote:
True, but I'm sure all the bikes you just listed look nicer than a ZZR. Hell I'm just glad I gave it a nice black paint... Are you suggesting a dirt bike Laughing ?
Not suggesting anything.
Just saying that expensive shiney bikes isn't neccessarily the road to happiness, unless you plan on never riding it properly or aren't worried about damaging it or getting it dirty Laughing
The last post was made 21 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.24 - MySQL Queries: 15 - Page Size: 139.59 Kb
