| David072 |
 David072 Nova Slayer
| SQL |
 SQL World Chat Champion
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| recman |
 recman World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 08:23 - 03 Sep 2013 Post subject: |
Before getting drastic... try the simple.
- Adjust your sitting position on the bike.
- Adjust angle of incident of helmet to wind.
- Adjust road position
- Slow Down (you dont say how much 'over' 60 you are going!)
- Take a different route to work - why do you want to sit on a boring motorway squaring tyres anyway?
Sitting position; depending on the bike, at higher speeds, you can get a little 'lift' changing the bikes balence. Sitting further forwards or further back, can make huge difference to how stable the bike feels beneath you. Will also change where your head is in relation to the wind blast and turbulance coming off its screen. Try find teh sweet spot.
In days of old, they used to give two top speed figures for bikes; 'Upright' and 'Prone'... Ie sat up straight, or leaning down over the handle-bars.
Leaning down over the bars, putting your head down can reduce your frontal area by as much as 1/3, and could, on old naked bikes make as much as 20mph difference to top speed.
Wind-Pressure increases disproportionately to speed. Takes 3bhp or so to go 30mph, 9bhp to go 60, 27bhp to go 90 and so on.
Faster you go, so the 'power' in any turbulence is going to be amplified.
Slowing down just 2-3mph can make a very big difference to how much wind turbulence you experience.
BUT; anything much over 60, its almost always going to be there, and heading into more elevated Auto-bahn-Basher velocities; unless you are tucked behind the 'bubble' of a sports fairing, 'prone' or cossetted behind a wind-jammer of something like a Pan-Euro, is always likely to be a little less comfortable.
(I actually passed a lad on an XJ600 who was lying flat on the tank, to get out of wind-blast the other day on the by-pass off the M6... he was being over-taken by a Ford Ka.... He cant have been going more than 60, but I suspect, it was his way of defeating the fatigue of sustained wind-buffet of longer motorway run... it does get tiring... hence I try and avoid motorways and take the scenic route - I ride for pleasure, and looking at monotonouse motorway furniture, and being hammered by wind-blast just isn't )
However, modern full face helmets, may be 'optimised' for different riding positions. Tilting into the wind, is likely to negate lift on the helmet, and hence 'buffeting'.
If you are sat behind or besides lorries; there is a lot of turbulance. Adjusting road position can take you out of high turbulance zone into a dead zone... buffeting goes.
Mods? What bike? What screen?
Is your screen a 'flip', or 'extended' one? If not, is there one available? These can change where the sweet-spot behind them is.
You can get small 'spoilers' that fit to the trailing edge that can again, change where the sweet-spot behind them is; some are adjustable.
Messing with gaffer-tape & card-board to make a temprary 'deflector' on the screen edge may help you find out how much effect such a mod, to a different screen might make.
How Old is your Helmet? How much wear has it had? How good a fit was it when you bought it? How good a fit is it now?
Helmets are made of expanded polystyrene. You should buy a 'bit' tight; as the inner layer of the polystyrene will compress and 'bed' to your head, with use and get a little looser. Loose helmets will shift about on your head.
Have you had a hair-cut recently? Can make a hat feel REALLY sloppy on your bonce. Try a balaclava beneath.
'Good' crash-hats have an expected life expectancy of approx 3-years 'normal' use. Cheaper hats significantly less.
Daily commuting; putting the hat on and off twice a day, to go to and from work, plus a few incidental journeys; would, by modern standards, be relatively 'Heavy Use'. I believe that Police Riders, used to get an allowance to replaced their helmets every year, and they tended to get better quality ones, to start with. For an every day commuter, buying middle range hats, I would suggest that as a fairly reasonable 'guide-line'. The DO go 'sloppy'. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| prawny1 |
 prawny1 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| David072 |
| hedgehugger |
 hedgehugger World Chat Champion
| prawny1 |
| Notj7 |
 Notj7 Brolly Dolly
| Atomic Punk |
 Atomic Punk Scooby Slapper
| garth |
 garth World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 10:39 - 03 Sep 2013 Post subject: |
More expensive helmets do have a lot more aero work put into em. I belive shoei have their own wind tunnel, and they claim that makes them better than everyone else as they're the only one that doesnt have to rent one out or some other horseshit.
Personally i'll only spend more than £100 on a lid if it's really pretty. In your case i feel this might help;
https://stores.sportbiketrackgear.com/images/InitialSet/ICON_Airframe_Ghost_Carbon_detail_2_600.jpg
My airmada isnt bad on buffetting, that's the one up & in carbon. It'll be lighter & apparently they've tinkered with the aero on the airframe. Plus you'll look like a pimp.
Scorpions are also worth a look, they've got more nice toys on em but the Icon's got the better graphics.
Shoei's are overpriced & everyones got one. Same with Arai. I'll await the torches & pitchforks...
https://www.niklassmith.com/torch%20mob.jpg ____________________ Please be aware that the above post may be full of complete nonsense.
| Mehty |
 Mehty Spanner Monkey
 Posted: 11:20 - 03 Sep 2013 Post subject: |
I think it's a case of MTFU.
I ride 70 mile sprints of dual carriageway on the er6-n, wind blast is never really a problem, just adjust depending on wind/speed (at some 'perfectly legal' speeds if I sat up completely I swear I'd be ripped from the bike. ____________________ 2007 YBR 125 (sold), 2011 ER6-N (sold), LHD 1999 GSX750F (sold), ??? ??? |
| hedgehugger |
 Posted: 12:30 - 03 Sep 2013 Post subject: |
BTW, it's buffeting  |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:49 - 03 Sep 2013 Post subject: |
| _Iain_ |
 _Iain_ Banned
| totalllama82 |
 totalllama82 Crazy Courier
| scorps |
 scorps World Chat Champion
 Posted: 20:50 - 03 Sep 2013 Post subject: |
I have a half shell and have started to develop some serious muscle in my neck and shoulders  ____________________ Do not presume that I am male. |
| kiddakidda |
 kiddakidda Spanner Monkey
| Nobby the Bastard |
| Nobby the Bastard |
| iMark |
 iMark World Chat Champion
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:46 - 03 Sep 2013 Post subject: |
You do get used to it, and bizzarely ear plugs help a bit as you can't hear the wind buffeting as much so you don't notice it as much.
keeping your visor closed (incase you weren't) helps too.
I've got a cheap HJC helmet which buffets a bit, but used to it now. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
The last post was made 12 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
