Turbo's and carbs - how do they work?
cb1rocket
PostPosted: 22:47 - 03 Sep 2013    Post subject: Reply with quote
You need to see Chris's turbo topic in show and tell !
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
Ariel Badger
PostPosted: 23:01 - 03 Sep 2013    Post subject: Reply with quote
Superchargers are easier to set up.
Ariel Badger
PostPosted: 23:03 - 03 Sep 2013    Post subject: Reply with quote
orac
PostPosted: 03:25 - 04 Sep 2013    Post subject: Reply with quote
safe boost level is determined by engine parts, if the piston, bores bolts etc tec ar all good for 15psi, but the head gasket is gone by the time you get to 8psi then there your answer.
plnum chamber from my understand is due to the fact that if you give it a hand full there will not be enough air in the pipe to sustain the engine, it kinda like a reserve if air which is then replished as the motor winds up.
oil feed, that depends on the turbo, the drain would have to run into wht ever you are using to pump it, are you using shared engine and turbo oil? dont forget turbo will dump a shed load of extra heat into that oil, so an extra oil cooler for a seperate oil loop is normally the best way to go.
again, i dont fully understand but ignition will normally be variable and it more important to be accurate with higher boosts.
carb presurising is beyound my currect understanding, however i have heard that putting the entire thing in a seal box and then presurising the box with the turbo is way to resolve the issue... not really thought about it to be honest
Pete.
PostPosted: 05:58 - 04 Sep 2013    Post subject: Reply with quote
You don't pressurise the float bowls via the overflow - you do it via the carb bowl breathers. Turn carbs over, remove bowl and you'll see the breather hole. They vent into the top of the bowl chamber.
Carbs are pressurised by a pitot tube. This is just a piece of pipe that pokes into the airflow in the pipe between the turbo and plenum.
Jetting - leave it standard. More pressure equals more fuel.
Plenum is just a mixing-pot to distribute air evenly across the cylinders. It's not so much a reservoir of air - more of a damper.
Oil feed - turbo manufacturers specify an oil pressure at the turbo usually. Think plain-bearing often is 35-40psi. Put a gauge on the feed line after the restrictor to set the size, I use an old carb jet.
Safe level of boost is determined by remembering how much you were using last time it detonated.
Ignition timing - pff I'd leave it stock and see what happens. Loads of stock-timed bikes out there.
My best advice if you're thinking of turbocharging your bike - get the turbo high up on the engine. High as possible, then move it up a bit. It's most important.
Don't go mad on the header and up-pipe tube sizes. For a 600 you only need headers of about 30-35mm ID, up-pipe about 40mm and very often smaller works a lot better than bigger. You DON'T need stainless for headers, mild steel is perfectly acceptable just that it goes rusty. It's also less likely to crack. For a budget up-pipe radiator hose is perfectly good.
a.k.a 'Geri'
P.
PostPosted: 06:33 - 04 Sep 2013    Post subject: Reply with quote
Assuming if its FI, you'll need a way of remapping?
P.
PostPosted: 08:27 - 04 Sep 2013    Post subject: Reply with quote
They do a bolt on SC Shocked They make a funny noise and provide 180hp to the rear wheel.
Thinking
Dear Santa...
P.
PostPosted: 08:49 - 04 Sep 2013    Post subject: Reply with quote
Don't have link Laughing Seen one on a TL on TLPlanet, various others have bought one. Looking at a fairly large sum though..
Pete.
PostPosted: 15:53 - 04 Sep 2013    Post subject: Reply with quote
_Iain_ wrote:
Paddy, you need one of theese if you're doing it the pikey way and a fully mappable ECU if the "proper" way. At least thats what i remember from building the civic - we packed it off in the end for a proper ecu & setup. Made a respectable 180bhp at the wheels from a D14 engine for all of three months before it shit the bottom end.
https://www.ebay.co.uk/itm/RISING-RATE-FUEL-PRESSURE-REGULATOR-KIT-ADJUSTABLE-/180464897392
Basicly have been looking at rear turbo setups on cars. Seem to work just fine. Looking at my bike if i can mount a turbo instead of a can it'd put the drain higher than the oil filler cap & theres adaptors to fit breather hoses onto them anyway, so could drain directly into the oil filler cap & feed off that pressurised 8mm bolt on the head that everyone runs top end oiling kits off. Its not an ideal set up for maximum power, but for simplicity & cost purposes it seems ideal - and easily swapped between bikes.
You can run the turbo remotely but they are less efficient. Heat energy drives the turbo so any energy lost by radiation (and it's a lot) is less to produce boost. It'll work but not brilliantly.
Run our oil from the gallery plug.
Pete, could i do away with the pitot tubes & run a nipple off the plenum to pressurise the whole lot?
No, you must use a pitot tube. It's the difference between pitot pressure and plenum pressure you need in the two areas of the carbs.
a.k.a 'Geri'
Pete.
PostPosted: 16:11 - 04 Sep 2013    Post subject: Reply with quote
Pitot size makes almost no odds, it's not flowing anything. The position in the up-pipe is what matters. The up-pipe diameter has a much bigger effect than pitot size. I recall one guy who built a system that ran like a dog until he fitted a smaller up-pipe and it was transformed into a nice responsive bike. Bigger isn't always better.
a.k.a 'Geri'
lihp
PostPosted: 17:08 - 04 Sep 2013    Post subject: Reply with quote
The trick to turbo exhaust systems and installations that work well is more about gas velocity rather than volume
Pete.
PostPosted: 18:20 - 04 Sep 2013    Post subject: Reply with quote
And that velocity is achieved by releasing heat energy in a confined space. As the exhaust gases exit the port they must expand into the exhaust and give up a large amount of energy whilst doing it which is spent driving the turbine fan. It's basically free power as it would otherwise just escape out the tailcan.
If you put the turbo further downstream the gases have already expanded into the exhaust and there is far less energy to drive the turbine - the initial expansion carries the most benefit.
a.k.a 'Geri'
Shaft
PostPosted: 23:04 - 04 Sep 2013    Post subject: Reply with quote
For all the reasons Pete has already explained, I can't see what the advantage is of running a remote turbo.
It might be slightly less of an issue on a bike, due to the shorter distance involved, but on a car, surely you must have to use massive boost pressure to get anything like the efficiency of a conventionally mounted turbo.
The point of forced induction is to improve the performance of an engine of a given size (originally to save fuel) by optimising the use of otherwise wasted energy; the further you put your turbocharger from the optimum position, the more energy you waste, so it's kinda self defeating.
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 3.33 - MySQL Queries: 13 - Page Size: 105.45 Kb
