| Bentley2210 |
 Bentley2210 L Plate Warrior
 Posted: 00:31 - 05 Sep 2013 Post subject: Another Honda CG125 starting problem |
Hey guys. I've had my Honda CG 125 ES4 for a couple of years now and it's ran great over the course.
I've had a few issues with starting in the past with your typical dead battery and the likes but this issue I have now is quite strange.
I'm quite a newbie when it comes to fault finding and repair and usually consult my Haynes or forums like this. About a week ago or so it wouldn't start up, I found that the battery wasn't an issue as it was a fairly new battery, fully charged, cells were all still pretty much topped up and when I pressed in on the ignition start, my neutral light wouldn't flicker like it did in the past when the battery was an issue.
What happens is the bike makes one click, not repeated, when I push the ignition switch. So, I had a quick look around and thought maybe it was the starter motor. Took it out, cleaned out all the build up in it and put it back in. The bike started twice, both on first attempts. Then it started happening again. So this time to get it fired up and started I knocked it into 3rd gear, give it a push forward pulled the clutch out for one compression of the engine and pulled the clutch back in, by doing that the bike started off the electric start, a little slugish, but still fired up.
This method worked for a short while until it stopped working today, in which case, i had to properly bump start it.
I'm quite baffled and I'm not sure what's going on. It's going for its MOT and service on Friday and I'm hoping I won't have to bump start it to get there and back!
Any advice/help would be greatly appreciated! |
| mudcow007 |
 mudcow007 World Chat Champion
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 10:12 - 05 Sep 2013 Post subject: |
flat battery or gummed up starter . Strip starter of corrosion and check replace bushes . It could be a faulty solenoid but unlikely , test by subsitution . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| prawny1 |
 prawny1 World Chat Champion
| sickpup |
 sickpup Old Timer
| Bentley2210 |
 Posted: 15:39 - 05 Sep 2013 Post subject: |
| unitynotsocri... |
 Posted: 10:49 - 06 Sep 2013 Post subject: |
On the bright side ...the brushes look good ......spare brushes . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| SteveZZR |
 SteveZZR Scooby Slapper
 Posted: 18:14 - 06 Sep 2013 Post subject: |
Whose idea was it to stop fitting kick starts? Fuck the electric shit when it isn't needed. Given the choice I always kickstarted my moped (nothing wrong with electric, just preferred kick)
My kickstart 1990 CG has 42,000 miles and still goes like a good un
Electrics are fucked though. Has a battery wired.to the horn and no lights.
Will soon be getting a bigger battery and twin dominator lights  |
| Mark65 |
 Mark65 World Chat Champion
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
