DT175(mx?) restoration - slow
mudcow007
PostPosted: 15:40 - 06 Sep 2013    Post subject: DT175(mx?) restoration - slow Reply with quote
i was given an old DT175 last week to see if i coudl do anything with it
i suggested scrapping it but the previous owner wouldnt hear of it
its in a bad way
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193643_zps2777bd73.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193648_zpsb6b7456e.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193653_zpsc67af210.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193700_zps8d22d34d.jpg
the plan is to see if i can get the engine going as cheaply as possible. if the engine lives i will start to (hopefully) bring it back to life.
i think its going to be a full engine teardown. im told 2 strokes are the most simplest creatures in the world though
frame so far seems to be ok, the swing arm is in a bad way though
engine is now out (only 2 bolts holding it in)
https://i25.photobucket.com/albums/c81/mudcow007/20130903_202146_zps38afd02b.jpg
carb is in a bit of bad way
https://i25.photobucket.com/albums/c81/mudcow007/20130906_153815_zpsd6d31e8a.jpg
anyone got a mikuni carb that i can take bits off?
clutch lever on this has snapped
pepperami
PostPosted: 16:06 - 06 Sep 2013    Post subject: Reply with quote
Looking at those pictures , I`d say there`s life in that bike yet.
I used to play Motoball and our bikes would be in a lot worse state than that before we got rid of them.
Even if it cant go on the road again , it might have some life left in it as an off-roader?
Looks like you need to spend some time at a bike auto-jumble Thinking
DT 175`s are/were great little bikes and are getting few and far between nowdays.
It would be a crying shame for it to be scrapped Crying or Very sad
mudcow007
PostPosted: 16:18 - 06 Sep 2013    Post subject: Reply with quote
cheers pepperami
i think it looks a whole lot worse than it is (hopefully)
the worrying bit is the missing bits
The rims are ally so, i hope to rebuild them - i have rebuilt pedal bike wheels so im hoping its just a bigger version of that
ideally i would like to make it road legal, i dont think its ever been on the road though
numbers match on the frame & engine.
i dont know of any way to do a check to see if its legal?
the bloke i got it off said its legit etc, plus i know him..
im told you have to speak to the heritage club or something an they will give you a letter to verify its age which you then take to the dvla about getting a age related plate etc (thats a million miles off though)
stevo as b4
PostPosted: 18:04 - 06 Sep 2013    Post subject: Reply with quote
Just my opinion, but I wouldn't bother trying to get the engine running after all this time stood around with no exhaust. Just decide if your going to stand the budget of a full motor re-build, and hope that the cases and transmission shafts and gears are re-usable. All bearings, seals and gaskets will need replacements IMO.
I'd be much more concerned about de-rusting the frame and the swinging arm, and see if you have got solid enough metal underneath. You will need at least one other tatty part complete donor bike to make it realistic to bring this back to life, as sourcing all of the individual missing parts to renovate and fit will be prohibitively expensive.
I've always found it strange how many people try to get old non runner's to start before they take them apart anyway to fully re-build. Maybe I'm missing something though?
mudcow007
PostPosted: 18:36 - 06 Sep 2013    Post subject: Reply with quote
well, i was thinking if i can make it run then at least the engine an box are good etc
i would hate to shell out on bearing n' seals to find the engine is dead
worrying the kick start shaft just turns with little resistance
gear selector moves a few mm
i haven't tried to force any of them to move etc
i think i will just break the engine down an see what i find (my first engine tear down)
the thing that is seriously worrying me is the rusted solid fly wheel. god knows what its like behind it
evoboy
PostPosted: 18:42 - 06 Sep 2013    Post subject: Reply with quote
Carb looks to be mikuni.
Similar to alot of 80's Suzuki 2strokes. What diameter are the openings?
Rebuild the engine anyway. 2strokes dont take much work to run as there are barely any internal components compared to a 4stroke. But trying to make it go in that state may make your job harder...
APT Motorcycles
evoboy
PostPosted: 18:45 - 06 Sep 2013    Post subject: Reply with quote
APT Motorcycles
pepperami
PostPosted: 18:53 - 06 Sep 2013    Post subject: Reply with quote
If it was mine , every orifice would get a really good dollop of diesel .
And a daily wiggle of anything that was supposed to move for a week or two before trying to get anything off it.
If it was mine it would get a great dollop of diesel in the exhaust port.
I would worry about seeing if you can get things moving first.
I once had a Bultaco Sherpa in the same condition as that and I was able to get it going as a tatty bus Thumbs Up
It had stood for 7years before I got it and the exhaust was off.
I did the diesel trick and luckily for me it did free up and I was able to get it going.
EDIT : What? aren't all bikes supposed to look like that when the likes of us get to ride em??
mudcow007
PostPosted: 10:34 - 09 Sep 2013    Post subject: Reply with quote
good idea about the diesel, i have a readily supply of kerosene, could i use that?
im thinking of just filling the container the engine currently live in with diesel/ kerosene for a few weeks - or is that ridiculous
obviously i wont be trying to start it covered in diesel/ kerosene!!
quite a few parts have appeared on gay-bay recently for DT's
fingers crossed i can start to rebuild the wee beasty
openings on the carb are 3cm & 4cm is that a common carb?
there are spanking new ones in the good ol US of A for £50 odd.
id quite like to use as much as the original stuff as possible.
i stripped the foot pegs off the frame this weekend, the return springs have corroded into the pegs!! Shocked
UnspeedySam
PostPosted: 10:41 - 10 Sep 2013    Post subject: Reply with quote
I read somewhere, but it could well be utter crap, that the DT175 engine is pretty much the same design as an RXS100 one. If that's the case it should be stupidly simple to rebuild.
I wouldn't have too much problem with starting it with diesel all over. the moving components, it's not super flammable like petrol and as long as you keep it off electrical stuff it'll be fine anyway.
stevo as b4
PostPosted: 12:37 - 10 Sep 2013    Post subject: Reply with quote
The DT shares no real engine design similarities with the RXS100, other than the layout, but it is very closely related to the TY175 trials engine, and the IT175 enduro. bike. The early YZ125's have the same shape engine casings too, and the design is similar across the DT100-DT400 engine range.
A very good air cooled steel linered motor with cylinder mounted reedvalve or (torque induction).
IT175 top end and carb, exhaust parts can be fitted to the DT175 cases, and I think the IT was about 24bhp? The TY engine appears to be the same but with a different non radial head and a 2mm smaller carb, along with of course a different exhaust system.
UnspeedySam
PostPosted: 14:43 - 10 Sep 2013    Post subject: Reply with quote
Clearly what I read was crap then Laughing I'm sure I've seen talk of getting the 175 top end to fit the RXS bottom or something...I'll google around.
pepperami
PostPosted: 19:33 - 10 Sep 2013    Post subject: Reply with quote
!! Shocked
I have used paraffin in the past , but diesel seems to have a "creeping" quality about it and it seems to get into the tiniest of places that have not had lube for years.
I have used a squirty bottle that cleaning products come in to apply the diesel.
mudcow007
PostPosted: 10:51 - 11 Sep 2013    Post subject: Reply with quote
cheers mr pepperami
i will give it a blast
im just in the process of getting rid of my CG so i need that gone before i can tinker with the DT (no room in my shed)
spikenipple
PostPosted: 16:52 - 11 Sep 2013    Post subject: Reply with quote
Do you want to buy a complete DT125 front end? I picked it up at Beaulieu on the weekend. It's from a disc model. Includes yokes, forks, wheel, disc, caliper, hose, master cylinder and the mudguard if you want it.
Not looking for a great deal of money for it.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
The last post was made 13 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 95.49 Kb
