| gmc38609 |
 gmc38609 Nitrous Nuisance
| P.addy |
 P.addy Red Rocket
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 19:13 - 07 Sep 2013 Post subject: Re: Rear Spocket Change |
| gmc38609 wrote: | Hello,
Can I just change the rear sprocket on my bike to a larger one without having to replace the other sprocket and chain? |
Yes, but the chain's gonna be too short I'm afraid. If you want it to be swifter, change the front sprocket for smaller one, cut and shorten the chain, if needed, and you're good to go.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| gmc38609 |
| Nobby the Bastard |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
| RhynoCZ |
 Posted: 19:58 - 07 Sep 2013 Post subject: |
Have you ever been on a mountain bike? Imagine all those cogs and gears you can ''create'' with combining them together.
It goes:
Smaller front sprocket = acceleration // worse mpg, more rpm/heat
Bigger front sprocket = speed // better mpg, less rpm/heat
Smaller rear sprocket = speed // better mpg, less rpm/heat
Bigger rear sprocket = acceleration // worse mpg, more rpm/heat
If you get some specs to your bike you will certainly find what sizes of sprockets you can use. I personally have experience with 44 teeth rear sprocket then 40 teeth on NC27. It felt so fast and powerful, got up to the top of 190kph, terrible mpg, a bit more heat and I hit the rev limiter at 6th at those 190kph. Plus I could ride at 6th all day long from 50kph up to the top. With 40 teeth it went alright, the top moved to 5th gear (180+kph) and it had better mpg and ran much cooler but I had to use the gearbox more often to keep it at revs.
I'd go for smaller front, it's easier to shorten the chain rather than putting there another links to have it long enough. I had to cut 2 links from my chain to fit there 40 teeth sprocket (previous owner put there the 44). ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Nobby the Bastard |
| gmc38609 |
| RhynoCZ |
| gmc38609 |
| Raffles |
 Raffles World Chat Champion
| RhynoCZ |
| SteveZZR |
 SteveZZR Scooby Slapper
| P.addy |
 P.addy Red Rocket
| Rogerborg |
 Rogerborg nimbA
| P.addy |
 P.addy Red Rocket
 Posted: 08:52 - 08 Sep 2013 Post subject: |
Rogerborg, wheelie king  |
| RhynoCZ |
 Posted: 09:22 - 08 Sep 2013 Post subject: |
I say just do it, loose 2 teeth on the front, if it's possible and you'll see. Maybe you're not going to need to cut the chain at all, so if you won't be happy, you can change it back.
It will give you some fake torque and ponies.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ariel Badger |
 Ariel Badger Super Spammer
| pepperami |
 pepperami Super Spammer
| Nobby the Bastard |
| RhynoCZ |
 Posted: 13:28 - 08 Sep 2013 Post subject: |
| Ariel Badger wrote: | The front sprocket will always wear more than the rear as each tooth has more work to do due to the reduction ratio. Change both and a new chain. |
If OP wants to just try it, then I'd just change the front one and shorten the chain (if needed). Front sprocket is about 15 pounds and the work is for free and sort of a part of the reward. What I mean is, OP's gonna have to change the chain and sprockets in the future anyway, this way he can try different ratio for 15 pouds and then decide if he wants it this way or not.
Why I'm telling you this, there is a possibility that the change of the ratio won't be exactly what OP was looking for, and I think it is a waste of money to buy a brand new chain twice.
EDIT: One more thing, you have to be certain that you can use smaller front sprocket, I do know my mate had one tooth less on the front sprocket of his CB500 and it worked.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:23 - 08 Sep 2013 Post subject: |
Indeed, I can't get my head round the advantage of binning thousands of miles of usable wear in order to... uh... avoid getting the most use out of those components.
| Paddy wrote: | Rogerborg, wheelie king  |
The "650" is higher geared than the F800GS that it's based on. It made 2nd just a bit too long, and all the shifting between 1st and 2nd was putting premature wear on my slipper.
No, I did not change the chain, rear, or my baffies as well as the front.  ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
