| Nobby the Bastard |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:59 - 10 Sep 2013 Post subject: |
What is the color of the smoke? It sounds like a normal steam to me, the exhaust is very cold over night and you push through there hot exhaust gases. Like when you breathe in winter and there's smoke coming out of your mouth/nose.
Worse starting can be result of faulty choke or it's cabel (it just doesn't choke the carbs enough, I've been there), or sparkplugs, or battery, or valve clearences, or old fuel...
If FZ is what think it is, 80's sport-touring bike, then try some Seafoam (fuel system cleaner, helped me alot with my GPz).
About the oil, if it's the 80's sport-touring Yamaha, then I'd be surprised if it didn't eat oil. How do you measure it? ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Nobby the Bastard |
| RhynoCZ |
 Posted: 14:38 - 10 Sep 2013 Post subject: |
Well, that is bad, if it spits oil out of the exhaust. It'd rings or one of those 20 valves then, if the engine's dry.
EDIT: The only unusual tool to have would be torque wrench, people say you don't need one, but I think that if you want to put the head back on the engine right, then you should do it with torque wrench.
When you have the head done, put in all valves and plugs, put it on table upside down, so you get the insides of the combustion chambers and pour in each some petrol, nothing should leak through. If it's done right  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Nobby the Bastard |
| RhynoCZ |
 Posted: 14:44 - 10 Sep 2013 Post subject: |
| Nobby the chihuahua wrote: | | RhynoCZ wrote: | Well, that is bad, if it spits oil out of the exhaust. It'd rings or one of those 20 valves then, if the engine's dry. |
I know it's either rings or the valves. I said that in my first post.
What I want to know is, which one? Rings or seals? |
Take the head off, keep in all valves and plugs, put it on table upside down, so you get the insides of the combustion chambers and pour in each some petrol, nothing should leak through.
EDIT 2: One more thing I forgot, take off cams and push all valves in, so they seal the area. It'd be stupid to pour in petrol while an valves open.
EDIT: It's hard to say which one it is, if you have original exhaust system and rigns were bad, you could find some bits of rings in the exhaust system, if it's an open exhaust then you've got no chance to find out, I'm afraid. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Robby |
 Robby Dirty Old Man
 Posted: 14:49 - 10 Sep 2013 Post subject: |
Valve stem seals are on of the things that people like to diagnose because there isn't any particularly good diagnosis - the only way to check is to replace them.
They don't fail that often. Like many things, the killer is leaving the bike standing for years, in which case they may dry up and perish, or the valve stems may develop a bit of surface corrosion to rip them up. If the bike has been used regularly for a good while, I wouldn't start suspecting the stem seals.
Looking at the issues:
1. Poor starting. When did the bike last have a full service, what state is the battery in, and how old are the HT leads?
2. Smoke on start up. The last few days have been humid and a lot cooler, so you will see an awful lot more smoke (steam) on start up. You may also be spending longer on the choke, which can add to the problem.
The test to valve steam seals going is smoke on the overrun - long straight road, open the throttle up, close it, look for smoke in the mirror as the revs die down. The high revving engine is trying to suck in air, the throttle is closed so there is more pressure trying to suck air and oil past the stem seals. If they have failed you can expect to see a decent amount of smoke. |
| Nobby the Bastard |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 16:26 - 10 Sep 2013 Post subject: |
| Robby wrote: | The test to valve steam seals going is smoke on the overrun - long straight road, open the throttle up, close it, look for smoke in the mirror as the revs die down. The high revving engine is trying to suck in air, the throttle is closed so there is more pressure trying to suck air and oil past the stem seals. If they have failed you can expect to see a decent amount of smoke. |
I thought that was the diagnostic for rings? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Aff |
 Aff World Chat Champion
 Posted: 17:10 - 10 Sep 2013 Post subject: |
I thought the most reliable sign of valve seals failing was blue smoke on start up after sitting while hot. The thin oil will seep down and pool above the valves, then be burnt on start up.
Also if left at idle for a while then harshly accelerated you would see blue smoke. Manifold depression at idle pulls the oil past the seals which collects in the ports, which aren't hot enough at idle to burn it all off, when you pull off the oil gets burnt. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| Nobby the Bastard |
| orac |
 orac World Chat Champion
 Posted: 18:56 - 10 Sep 2013 Post subject: |
Compression test when cold and then when hot check against specs, if ok that chances of being rings is extremely slim, same goes for head gasket. By deduction it leaves one option, stem seals.
if you are so inclined you can even do a leak down test which will even pick up loss of compression that compression testers cant.
fyi my old motor would smoke when cold, and when you gave if a hand full, it had ovalled the bores. Had gs5 that had done seal, only ampked when cold and when give a hand full ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| Nobby the Bastard |
| orac |
| MarJay |
 MarJay But it's British!
 Posted: 20:27 - 10 Sep 2013 Post subject: |
| Robby wrote: | Valve stem seals are on of the things that people like to diagnose because there isn't any particularly good diagnosis - the only way to check is to replace them.
Often if you can inspect the inlet ports by removing the airbox and opening the carb butterflies you'll see oil on the bottom of the carb butterflies and all over the inlet if the valve stem seals have gone. You can also make some bikes valve stem seals go by seriously overrevving the bike and ramming the machined part of the valve into the seal somehow. I'm not sure the mechanism for that but I'm assured by an experienced mechanic that it can happen. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Nobby the Bastard |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:41 - 14 Sep 2013 Post subject: |
Think later FZ / FZR engines could often burn a bit of oil (early 1FN FZ750s had different designs of pistons). From memory the quoted max oil consumption for an FZR1000 (very similar engine to your FZ) is far higher than you are getting.
Getting the head off the FZ is a minor pain due to the tools you need. You need a long allen key (from memory 6mm, but I could easily be wrong on that) which you can attach to a torque wrench to do the head up (the nuts are under the top half of the head, and there is a small hole to put the allen key through to get at the nuts).
With dipping down the inlets I would suggest that fuel residue is more likely to be found than oil.
| Nobby the Bastard |
| Kickstart |
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful? |
