180 or 190 Rear?
Fowlersrs
PostPosted: 17:54 - 11 Sep 2013    Post subject: 180 or 190 Rear? Reply with quote
I've got the option of either when I come to renew the rear on the gsxr this winter, the current 190 BT014 is so square I think it's unfair for me to judge...
Have been reading up; some say switching from a 190 to 180 will result in the bike turning in faster??
Obviously 190 is a bigger tyre so bigger contact patch??
Which way should I go?
PostPosted: 18:04 - 11 Sep 2013    Post subject: Reply with quote
Whatever the manufacturer recommends.
I can't believe a company that spends millions on R&D would produce a bike that handles better with a different tyre size.
Slacker24seve...
If its a 600 or 750, do you need a bigger contact patch? If its a thou, might be a good idea.
Banger rallies are ace
Old Git Racing
PostPosted: 18:10 - 11 Sep 2013    Post subject: Reply with quote
What bike, 750 or thou? Generally a 180 will make it feel nimbler, also depends on your rim size and the height of said tyre as to whether its a good idea.
I always ran 180 on my gixxer 750 and currently run it on my 999 Ducati, feels better turning to me. Strangely the 999 rim is made for a 180 but they fitted 190 from the factory, fashion I suppose.
OGR
Fowlersrs
PostPosted: 18:28 - 11 Sep 2013    Post subject: Reply with quote
Yeah it's the 750 srad, standard is 190 from manufacturer, just debating wether to stick a 180 on instead?!
Slacker24seve...
PostPosted: 18:32 - 11 Sep 2013    Post subject: Reply with quote
A SRAD has nowhere near enough power to warrant a 190 then. Go back to 180 and enjoy the better handling.
dansp1
PostPosted: 19:49 - 11 Sep 2013    Post subject: Reply with quote
or put a 190/55 on it and have the best of both worlds (albeit at a greater cost)
johnsmith222
PostPosted: 19:50 - 11 Sep 2013    Post subject: Reply with quote
I was under the impression that putting a larger tyre on a rim made for a smaller size can actually decrease the contact patch as the tyre is more "rounded" due to the smaller width of the rim holding the sidewalls closer together.
I'd be interested for someone to confirm or deny whether this is true.
Fowlersrs
130bhp, so why did they put one on there as standard?
Fowlersrs
PostPosted: 19:54 - 11 Sep 2013    Post subject: Reply with quote
The rim must be designed for both 190/50 & 180/55 as the gsxr 600 has the 180, and the 750 the 190, go figure?!
Richy CB1000
PostPosted: 20:43 - 11 Sep 2013    Post subject: Reply with quote
Stick to manufacturer first, however if you and others see benefits changing sizes check the rim size. There's a site, I can't remember where currently, I think via tyre manufacturers sites that show what size tyre for what size rim. It's usually up or down one size is ok.
e.g. mine is a 5,5J rim, takes as standard a 180. Honda in their wisdom specified a 170 (pain in the arse size on an 18 inch wheel).
But other owners use a 160 (availability reasons) they say they simply run out of tyre quickly although it has a flatter profile due to a "stretch" remember it's smaller.
Some use a 180 that supposedly is perfect for the rim and they report the bike slower to turn, yes it's more rounded but is still wider than the 160.
So I stick to Honda's R&D, they've tested the best compromise at 170. Added to the mix is the tyre brand itself, Bridgestones 170 is actually 166 mm wide. Avon's 180 is actually 187mm wide.
You pays your money...... everybody rides different and prefers different tyre options.
Slacker24seve...
PostPosted: 21:26 - 11 Sep 2013    Post subject: Reply with quote
Sorry mate I misread, I thought you said it was 180 stock.
Snorty
PostPosted: 23:19 - 11 Sep 2013    Post subject: Reply with quote
SRAD 750 '98 model.
I've got Bridgestone R10s on mine at the moment 190/55 rear. Got a BT016 190/50 lined up to take its place.
The bike came with a 180 on it, but stock is 190. Can't say I've noticed a difference but I like to stick to manufacturer's.
PostPosted: 00:07 - 12 Sep 2013    Post subject: Reply with quote
Regularly swapped between 180 and 190 tyres on the GSXR I had, never really noticed much difference and I wouldn't think twice about doing it again. Just swap for whatever you want/can find cheapest
iooi
PostPosted: 06:06 - 12 Sep 2013    Post subject: Reply with quote
Handling is very much a personal matter..... Just ask any racer.
I do wonder just how much R&D goes into tyre choice....
Oh its round and black and looks OK on the bike.... That will do... Laughing
evoboy
PostPosted: 14:13 - 13 Sep 2013    Post subject: Reply with quote
Stick whatever on it.
My old zx6 used to get whatever i had lying around slung onto it. Never noticed a difference.
Didnt notice a difference on my zx7 when i put a 180 55 on the back ( 190 50 std), except i used to go off the edge of the tyre...
Zrx has a 180 on the back at the moment, i have a 190/50 lined up for it...
But, if your buying brand new tyres, i would put a 190/55 on the back, as its the best of both worlds.
APT Motorcycles
evoboy
APT Motorcycles
fozzym
PostPosted: 21:16 - 15 Sep 2013    Post subject: Reply with quote
Couple of points......Firstly if you ever watch the 125/moto3 racing they are always banging on about how quickly the little bikes turn in or flick side to side in a chicane. The point being the narrower the tyre (to a point) the quicker and easier it is to turn hence better handling. Obviouly the power of the bike is the limiting factor, the greater the power the wider the tyre needs to be to give traction. So in therory provided the tyre can handle the power the narrower tyre will be better.
Second point, from my experience the difference between a slightly narrower or slightly wider tyre is not noticeable. So lest you are a very very good rider I'd stick with either what the manufacturer recommends or whatever is cheaper.
PostPosted: 21:45 - 15 Sep 2013    Post subject: Reply with quote
5.5 inch width rim 180 section.
6 inch width rim 190 section.
Job done. Thumbs Up
Old Git Racing
PostPosted: 23:20 - 15 Sep 2013    Post subject: Reply with quote
Job done. Thumbs Up
190/55 on a 5.5 rim will do the job. Its not all about the section.
OGR
spnorm
PostPosted: 06:50 - 16 Sep 2013    Post subject: Reply with quote
Bear in mind the tyre must be approved fitment for your bike by either the bike or tyre manufacture. You wouldn't want your insurance company wriggling out of covering you in the event of an accident Thumbs Up
There is a gap of 350 days between these two posts...
Musketeer
PostPosted: 08:31 - 01 Sep 2014    Post subject: Reply with quote
Sorry for the revival..
I believe my rims are 6 inch. Will 180/55 tyre be still ok?
Also many people recommend 190/55 tyre instead of 195/50. Why is it so? It raises the rear a bit which I know benefits of, but anything else than that?
Snorty
PostPosted: 09:19 - 01 Sep 2014    Post subject: Reply with quote
If you have a hugger, deviating from the manufacturer's standard can make it rub. Other than that, it's fine - my SRAD came with a 180/55 on it and it has a 6" rim.
I've had 190/55s 190/50s and 180/60s on it as well. It doesn't have a hugger though.
Musketeer
PostPosted: 09:26 - 01 Sep 2014    Post subject: Reply with quote
Good point. I don't think 180/55 would be a problem in this case as the diameter is about the same as 190/50. But 190/55 has a larger diameter and may indeed not fit under the hugger.
I won't bother with 190/55 tyre then. I've got Pilot Power 3 180/55 tyre that has done only 400 miles and I'm very tempted to use it.
Fizzer Thou
PostPosted: 10:21 - 01 Sep 2014    Post subject: Reply with quote
My old Exup1000 has a 5.5" rear rim and as standard the rear tyre was a 170/60x17.But the tyre manufacturers suggested a 180/55x17 when it came time for renewal and I have been happy with that size for some 50,000 miles.
But a friends GSXR750K7 has a 6.0" rear rim and is more than happy with the 180/55x17 that is fitted and around the twisties in France earlier this year it was more than adequate.
Just make sure that the tyre is ZR rated.
Always have a 'Plan B'
The last post was made 12 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 129.01 Kb
