| sebulba |
 sebulba Borekit Bruiser
| lihp |
 lihp World Chat Champion
| sebulba |
| CG Sam |
 CG Sam Crazy Courier
| prawny1 |
 prawny1 World Chat Champion
| sebulba |
| sebulba |
 Posted: 16:57 - 02 Dec 2013 Post subject: |
So a little update and also a question.
Ignition coil has been changed as well as the HT lead cables. The spark is much better now and the idle is good. At least it was ...
The bike was running fine but now the problem is back again. The bike starts to "slack" and kind of loses a bit of power. It just feels like it's not running properly as well as the idle goes down from 1.2k to about 500 or less. But not always. Sometime si give extra gas and it stays normal...
Another thing: Basically, I was riding along and I heard this bang like a metal hitting another metal or chain. It felt like the chain would lock up and the bike would like stop pumping fuel for literally a half a second. It's hard to explain but it was like; lock up ( the bike would kind of slow down) > bang, power back on and the bike is running again BUT still kind of struggling and it feels weird.
Id like to add that this used to happen before the ignition coil change.
Another thing I found the other day was like a oil leak or something from the cylinder? Anybody have any clue what the hell is that. It's only on one cylinder tho... |
| CG Sam |
| sebulba |
| CG Sam |
| misscrabstick |
 misscrabstick Crazy Courier
| i2ico |
 i2ico Two Stroke Sniffer
 Posted: 18:54 - 03 Dec 2013 Post subject: |
Ive just cleaned my carbs on my er5.
Little advice leave the carbs attached to each other, dont separate them, just disconnect from air filter and mannifold.
Make sure to drain your float bowl before taking it off to access the pilot jet, main jet and starter jet.
Spray carb cleaner in all the jets.
I found my pilot jet was blocked and cleaner wasnt getting it out, so just ran some fine electrical wire through the hole, (is very very small) till when i held it to the light i could see through it.
Good luck ____________________
Limitations are only what you make of them.
Current: ER5, Stolen/Recovered:Honda CG |
| sebulba |
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
