Electrical issue, bit further help now.
R1stu
Shrek!
PostPosted: 22:43 - 13 Sep 2013    Post subject: Electrical issue, bit further help now. Reply with quote
Ok, we'll looks like the issue is with the tail light loom. Not a clue what it is. When both bulbs are in the holders they will not light, or they will be so dim thy hardly glow. Yet if I remove one bulb then the tail light works fine,
It doesn't matter which bulb or which side, but both is no go. I've popped a video up. Please help.
https://www.youtube.com/watch?v=G4VXhNQcWlk
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
moonzoomer
PostPosted: 23:45 - 13 Sep 2013    Post subject: Reply with quote
The wiring is wrong, when both lamps are dim means they are wired in series which is wrong. I strongly suspect a bad earth on one of the earth leads between the lampholder and the 3 pin connector, meter each earth wire out and also move the cable about as you meter as the plastic outer of the cable may be intact but the inner is broken.
R1stu
Shrek!
PostPosted: 01:06 - 14 Sep 2013    Post subject: Reply with quote
So maybe replace both earths in the loom?
moonzoomer
PostPosted: 01:29 - 14 Sep 2013    Post subject: Reply with quote
Yes, you could prove this by connecting the black negative(earthwire) directly to the metal outside body of the lamps and then connecting the positive lead to each of the tail light and brake light feed cables from the connector, this will show up if one or both earth connections are bad.
ZebraDriver
PostPosted: 09:57 - 14 Sep 2013    Post subject: Reply with quote
The bulbs can't be wired in series. If they were and you removed one the other one wouldn't light. It's either an earth fault or a poor connection in the supply to the bulbs.
ZD
ZebraDriver
ZD
Islander
PostPosted: 10:28 - 14 Sep 2013    Post subject: Reply with quote
ZD
Yep, this. ^^^
Check your connections and earths. Check the holder contacts for corrosion too.
R1stu
Shrek!
PostPosted: 11:28 - 15 Sep 2013    Post subject: Reply with quote
Think it's fixed. The earth wire on the holder was blue with corrosion an some broken. I cut the plastic away and replaced with new wire, and all seems ok with the battery test!
moonzoomer
PostPosted: 16:16 - 15 Sep 2013    Post subject: Reply with quote
ZD
Yes they can and the video clearly shows them been wired in series, just connect the 12 volt positive supply to one positive connection and the neutral supply to the second positive connection.
ZebraDriver
PostPosted: 16:45 - 15 Sep 2013    Post subject: Reply with quote
Well Fuck Me.
You obviously know more than me and thousands of other electrical engineers worldwide. I guess that by your reference to "positive" and "neutral" your an electrical engineer as well.
Series connected bulbs will not light if you remove one of the bulbs. If you remove one of the bulbs there is a break in the circuit, hence it will not light. Not only that, if you connect two 12 volt bulbs in series they will only glow as they are receiving 6 volts each.
If your going to give advice here try to understand what your talking about first.
ZebraDriver
PostPosted: 16:46 - 15 Sep 2013    Post subject: Reply with quote
Well Fuck Me.
moonzoomer
PostPosted: 17:25 - 15 Sep 2013    Post subject: Reply with quote
ZebraDriver wrote:
Well Fuck Me.
If you had have looked at the video before commenting you would have clearly seen the Op had wired the lamps in series so there is no question that they cannot be wired in series and to answer your question I am an electrical engineer, no need to be so defensive when you are proven wrong.
The last post was made 12 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 72.74 Kb
