Help! Chain not adjusting
esullivan
PostPosted: 14:22 - 14 Sep 2013    Post subject: Help! Chain not adjusting Reply with quote
I went to adjust my chain on my Honda NC700. This is the third time I've adjusted it and the first two times went OK, but today I did a turn too many and the chain is tight as a drum, so I tried to loosen it and it won't loosen. The adjusting nuts are completely loose (not even touching the end of the swing arm, but the chain is still very tight. Has anyone heard of this before? What do I do? The wheel doesn't seem to be moving in the swingarm, back or forth.
Edit: Got it. Sorry for the panic. Had to give the wheel a good solid kick or two to move it forward.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
cb1rocket
PostPosted: 22:00 - 14 Sep 2013    Post subject: Reply with quote
Next time loosen the nut on the spindle more! Thumbs Up
esullivan
PostPosted: 23:36 - 14 Sep 2013    Post subject: Reply with quote
It was practically off. That wasn't the problem. The tyre needed a good kicking.
cb1rocket
PostPosted: 23:38 - 14 Sep 2013    Post subject: Reply with quote
Ok, shouldn't need a good kicking. next time the wheel is off make sure the adjuster and spindle are well lubed
Robby
Dirty Old Man
PostPosted: 12:09 - 15 Sep 2013    Post subject: Reply with quote
If everything is jamming up a bit, it won't hurt to strip the adjusters down, clean them up, and give it all a smear of coper grease. Swingarm adjusters typically suffer from a combination of corrosion, road crap, and initial dry assembly to make adjustment tricky.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:34 - 15 Sep 2013    Post subject: Reply with quote
Commonly, it's actually the bar that holds the rear brake in position (both drum and disk) that is done up too tight to allow the wheel to move forward if you over-adjust.
Triumph Sprint ST 1050
esullivan
PostPosted: 16:29 - 15 Sep 2013    Post subject: Reply with quote
Thanks all. I'm a very unconfident mechanic, so prone to these panics. Embarassed
I brought the bike over to the dealer for a quick look after I finally seemed to get the tension right (the 1.5 mile ride seemed fine). He said having to kick the wheel to move it forward isn't unusual and that the tension on my chain was still a tad loose (it was about 1.5 inches, when 1 inch is the spec). I took the wife around for lunch in the countryside to test with a pillion, and that seemed fine too.
I was still worried about it (I'm a fretter) and gave it another go, did the same over-tightening mistake again and still had to give a kick. I think you are right, the mechanism is getting a bit gummed up. The next time, I'll loosen the nuts all the way so the end plates come out and grease it up inside, then tighten it up again.
With all the kicking and in/out, I completely lost track of the number of turns on each side and just had to eyeball it with the hash marks. While test riding, I let go of the handlebars and the bike didn't steer to one side or another. I have no idea if that's a good test, though...
Nobby the Bastard
Harley Gaydar
PostPosted: 16:36 - 15 Sep 2013    Post subject: Reply with quote
A good wy of telling whether the rear wheel is aligned correctly is to get some long (straight) batons of wood.
Put the bike on the centre stand (or as upright as you can get it) and put the batons either side of the rear wheel tight to the tye with the other end by the front wheel.
If the alignment is right, the bits of baton will be equidistant from the front wheel.
I've never bothered with this myself, I tend to look down the chain run and make sure it looks like the chain is in a straight line from the front prokct, down the length to the rear sprocket.
esullivan
PostPosted: 17:46 - 15 Sep 2013    Post subject: Reply with quote
Thanks. I eyeballed it from the rear and it seems straight. I asked on an NC700 forum and the adjusters only pull, they don't push, so shoving in the rear wheel is SOP, apparently. It doesn't mention this in the manual, but it makes sense when you look at the mechanism. Well, learned another thing about (my) bike maintenance this weekend, so not all lost. Smile
YBR Ric
PostPosted: 15:55 - 16 Sep 2013    Post subject: Reply with quote
Assuming the adjusters have sufficient slack and the spindle is loose...
If you ever need another method of moving the rear wheel forward instead of kicking it, just shove an old rolled up flannel or rag between
the lower chain rung and the sprocket and rotate the wheel forwards until all the slack has been taken up and it's ready for another bit of fine adjustment.
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 64.38 Kb
