Which bike lift? Are they all the same or should I pay more?
ninja_butler
PostPosted: 09:27 - 15 Sep 2013    Post subject: Which bike lift? Are they all the same or should I pay more? Reply with quote
I'm thinking of buying a cheap motorcycle lift/jack but without seeing them up-close it's hard to tell which one to go for.
On eBay we have:
MC480 Sealey for £114 + free p&p https://www.ebay.co.uk/itm/400212427695?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Tongrun lift for £73.95 + £9.95 p&p https://www.ebay.co.uk/itm/Tongrun-680Kg-Motorcycle-Bike-Lift-ATV-Jack-1500LB-/300915909738?pt=UK_Motorcycle_Parts&hash=item460ffc646a
No-name bike lift for £69.90 + free p&p https://www.ebay.co.uk/itm/1500LB-Motorbike-Bike-ATV-Quad-Motorcycle-Jack-Lift-/380347307746
The Sealey is probably the safest bet out of the three, but it's £40 more than the cheapest option and I'm not expecting to use a lift very often. Thinking
PostPosted: 10:36 - 15 Sep 2013    Post subject: Reply with quote
Red one?
The "Tongrun" from Busters has two braces between the platform rails. If they were just making a cheap knock-off of the Sealey then they wouldn't have bothered adding the extra one. Is how I'd probably rationalise it.
Chuffin Nora
PostPosted: 10:55 - 15 Sep 2013    Post subject: Reply with quote
I've never quite understood the point of them, myself, but then I've never seen one being used.
I mean, if it's supposed to make contact with the frame's bottom tubes - and I can't think how else - what then of a lower-than-bottom tube exhaust system, and the like?
If you're building from scratch, sans wheels and/(or not) forks and swing arm, concentrating on engine - less sump + gubbins - and frame-bound bits thereabouts, as restorers/renovators are wont to do, then all well and good; and if that is you're intention, being that that's what they're for, I might shut-up now.
But . . .
'Cause when I read the word 'motorcycle', as in 'motorcycle lift', an image of a wholly entire bike springs to mind and not a half-built bitza in the loving and greasy mitts of a thoroughbred craftsman in a pukka shed at the bottom of his garden, you dig?
Therefore, are you sure that you don't mean one of these:
https://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=9135
which makes an awful lot of sense.
Do tell if I'm missing something.
There's a fine line between integrity
ninja_butler
PostPosted: 11:15 - 15 Sep 2013    Post subject: Reply with quote
But . . .
I've been looking for a jack that would be a universal fit for all types of bikes, but I've only seen two types; one that fits under the cradle and one for sports bikes that connects through the sides with bobbins.
I've got a Fazer and a XL 250 so the "underneath" type should be good for both of those, but yeah, it's next to useless for any bike covered in plastics or with low-slung exhausts.
What I want the jack for is to do basic jobs on a bike like replacing fork seals and removing swing arms and rear shocks.
Teflon-Mike
tl;dr
PostPosted: 11:40 - 15 Sep 2013    Post subject: Reply with quote
If you want to work on road-bikes FORGET those.
I have one; it's great under a dirt-bikes frame rails where there is no exhaust or belly-pan or anything, but of very limited use for much else.
Pair of paddock stands, preferably the swan-kneck under the head-stock front, with adjuster cups, not hooks & bobbins, is the more useful bit of equipment for routine maintenance & fair bit of full up built TBH. Or a work-height rail-bench.
The off-road / atv jack is neither nor; unfortunately. Its dont go up so high as to substitute for a rail-bench, and its no where near as stable as paddock-stands.
e-bay, ricambi-weiss... think that's the set I have. £65, and far more all-round use, on far more motorcycles than the ATV jack... though that has proved useful hanging garden gates and tackling a broken car exhaust hanger!
And TBH, the hydraulic bike ATV jack is total over-kill for most dirt bikes. I bought mine mainly because we dont have Milkmen any more.... for twenty years, I quite happily propped my Cota trils bike up with an upended milk-crate... but they go brittle and crack eventually, so thought that would be 'just the job'..... its actually heavier than the fucking BIKE..... and more effort holding the bike up and pumping than to just lift the ruddy thing on and off it!
Might be suitable for a heavy cruiser I suppose; but?!? Mine rarely earns its keep. The paddock stands DO!
ninja_butler
PostPosted: 11:53 - 15 Sep 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/STFLT-HEADSTOCK-LIFT-PADDOCK-STAND-SET-FRONT-AND-REAR-/310291249971?pt=UK_Motorcycle_Parts&hash=item483eccbb33&clk_rvr_id=520975641552
Thanks Mike, I like the look of that. Do you think that "headstock lift" would hold a Honda Blackbird 1100? I'm going to buy it anyway, it looks like what I need for the Fazer.
Aff
PostPosted: 11:54 - 15 Sep 2013    Post subject: Reply with quote
Buy an ABBA stand.
/Thread.
Electric Bike Project
Quote Me Happy
PostPosted: 11:57 - 15 Sep 2013    Post subject: Reply with quote
I've got the 'no name' one. Had it a couple of years and has been fine. Very stable and lifts the bike nice and high.
They're more suited to off-road style bikes which can be lifted from underneath.
ninja_butler
PostPosted: 12:06 - 15 Sep 2013    Post subject: Reply with quote
Aff wrote:
Buy an ABBA stand.
/Thread.
Looks the business, but maybe a little expensive; £90 for the stand, £20 for the fitting kit, £45 for the optional superbike front lift arm. Oh, and there's no fitting kit for Fazers! So that's out. Mr. Green
PostPosted: 12:45 - 15 Sep 2013    Post subject: Reply with quote
Erm, you do know these lifts are designed for bikes with twin frame rails at the lowest point?
Won't work well on bikes with underslung exhausts protruding.
'Front lifting kit' for an ABBA = bit of wood. (Or some weight on the back.)
You can get copy abbas that have generic fitting kits which will fit most bikes.
Teflon-Mike
tl;dr
PostPosted: 17:52 - 15 Sep 2013    Post subject: Reply with quote
Hmmmm... don't know... I know it wont 'lift' a long travel fork MX bike... well, it might... height is probably just enough you could get it under the bottom yoke of one, but doubt it would lift the front wheel off the floor!
Black-bird? Not so far from the floor; so dont think there would be a problem on that score; if there is one, I would imagine it would be whether you can wiggle the swan-kneck in under the nose-cone of the fairing and mudguard.... but they sell the same thing for other full-faired sports bikes; so stands reasonable chance.
Weight wise? How heavy is a bird? Propped the 750 up with it no probs, and that's 215Kg.. Cant say I have tried it on anything heavier than that; VF's got no motor in it, and only other candidate to present itself since I have had it was my uncles Honda Civic SORRY... 1500 Gold-Wing! (bludy things got a bigger engine, with more cylinders than my Civic, and probably weighs more!) DIDN'T really want to risk crushing the poor thing giving myself a hernia with that one!
The last post was made 12 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 76.03 Kb
