| skatefreak |
 Posted: 11:43 - 15 Sep 2013 Post subject: Spotlights? |
Afternoon all.
The weather is turning and I'm thinking about the cooler, darker months ahead.
I have a few pairs of dirty Chinese grip heaters on their way and was thinking about putting some spot lights on the cbr6oo f3/NSR125 as I'll be commuting to new premises involving nastier junctions/town roads etc.
Thus, as the NSR has little spare power going I am hoping some LED spotlights wont take to much power but still help me stand out etc without resulting in a dead battery etc.
I am looking at these:
https://i.ebayimg.com/t/2-Pcs-1500lum-12V-3-LED-High-Power-Auxiliary-Spot-Light-for-Motor-Bike-ATV-Jeep-/00/s/NjAwWDYwMA==/$T2eC16h,!)kE9s4,Bum1BQl2u1VltQ~~60_12.JPG
It should be a fairly simply procedure to fit and wire them in however I was thinking it would be ideal to wire them into the headlight circuit however I would like them to be on with the main and high beam.
Would this be feasible with relatively simple wiring?
Any thoughts would be much appreciated.
Best regards
-Jvr |
| -Savage- |
 -Savage- World Chat Champion
| Nobby the Bastard |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 12:11 - 15 Sep 2013 Post subject: |
You could use the power for side lights so that they come on when any light is switched on or personally I'd use power from brake light or indicator circuit do that when they go wrong and blow a fuse it will be your indicators or brake light that goes out not your headlight. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| Nobby the Bastard |
| skatefreak |
| wilz1234 |
 wilz1234 Trackday Trickster
| J.M. |
 J.M. World Chat Champion
| skatefreak |
 Posted: 10:24 - 16 Sep 2013 Post subject: |
Well the way I'm looking at this is to hard wire both the grips and lights directly from the battery to the components so they don't interfere with any other wiring on the bike and then just splicing a switch into the ignition/headlight/somewhere convenient so when ignition is on it will power the gubbins. I do have one knocking about but that's quiet a chunky 25'ish amp jobby for something completely different lol.
This approach is as much for preserving the wiring on the bikes as well as simplicity and because I can with absolute certainty say I will forget a switch on the handle bars
Am I thinking about a relay here?
Supply a small voltage one side and it connects a circuit on the other?
Best regards
-Jvr |
| StormCrow |
 StormCrow Scooby Slapper
 Posted: 10:41 - 16 Sep 2013 Post subject: |
Best thing is to wire a relay in - that way you don't need to remember to switch the whole lot off again when you stop.
A relay is basically that - think of it like a fat power cable with a switch on it - the small feed (from the switch) is just to energise the relay, that will then latch 'on' and switch on whatever you've got wired in to it.
If you want to minimise the effect on the bike's wiring, then run +12v from the battery to the relay, through the relay and then on to the extra components. Earth somewhere convenient (I'd earth straight to the frame somewhere) and run the switch in to the other side of the relay.
https://www.r1200gs.info/howto/images/Schematic4.gif
Personally I'd do what's been suggested above - run the relay into the brake light wiring using the wiring as the 'switch' - when the lights are on then the relay is energised and the grips will be on. Then run the extra lights off the lighting circuit on a switch. It'll all turn off when you switch the bike off, and the relay will physically break the connection to the grips to save any parasitic draw. That way, you'll only be disturbing two wires - the brake light +ve feed and the headlight/sidelight +ve feed. DO put fuses inline though - you don't want your cheap sidelights taking out the rest of your lights in the dark at the side of the road... (trust me, been there! ) |
| J.M. |
| Chalky. |
 Chalky. World Chat Champion
| raesewell |
 raesewell Traffic Copper
| raesewell |
| lihp |
 lihp World Chat Champion
| Christoffee |
 Christoffee Nitrous Nuisance
| Chalky. |
The last post was made 12 years, 177 days ago. Instead of replying here, would creating a new thread be more useful? |
