| DanCassidy |
 DanCassidy Derestricted Danger
| SQL |
 SQL World Chat Champion
| DanCassidy |
| SQL |
| DanCassidy |
| sickpup |
 sickpup Old Timer
| P.addy |
 P.addy Red Rocket
| prawny1 |
 prawny1 World Chat Champion
 Posted: 11:32 - 16 Sep 2013 Post subject: |
10th digit on the frame number will tell you how old the frame is at least,
https://en.wikipedia.org/wiki/Vehicle_identification_number
You would need to check the engine number against a manual or search on line, usually you will find stuff like 1992-1997 001000-002345 and so forth (example).
If you have no numbers to go by then some engines have a model designation cast somewhere on the barrel/head etc Yamaha often use three digit codes like 3bn (2000's I think) to distinguish revised motors.
Early motor will use the old style stator coils (one for spark/light one for charging) the later use the tzr star shaped (three wire) stator.
The white bodywork suggests early to mid 90's but without numbers we are stabbing in the dark,
If you don't have numbers the bikes is basically worthless as you will never be able to prove it isn't stolen. Unless the guy gave you legitimate receipts from a shop for the bike/ frame that states no numbers you should take it for granted that the bike IS stolen and proceed with caution.
Any dtr/tzr (possibly tdr125 too) engine will fit any of the year dtr/tzr frames as the mounts line up fine, I have seen people fit the electric start to the earlier bike
Though if you are fitting a dtr engine into a tzr or visa-versa you need to keep the correct cylinder head for your bike as the mounts are on opposite sides.
If you have the early bike with the ypvs locked shut the servo system from a full power tzr or dtr will fit either with the correct cables,
The later bikes have the servo system as standard but are set up to close the servo at high revs, I recall something mentioned about a sensor in the clocks being used to control it that needs ticking out of the way rather than removing to get the servo working correctly. ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them.
| Irn-Bru |
 Irn-Bru World Chat Champion
| Boxing |
 Boxing World Chat Champion
 Posted: 12:29 - 16 Sep 2013 Post subject: |
Probably is stolen. I need a right rear panel. Give you £5 for it.  |
| DanCassidy |
| DanCassidy |
| Irn-Bru |
 Posted: 19:18 - 16 Sep 2013 Post subject: |
It's pretty much impossible to find a DTR that hasn't been either stolen and ragged, or just ragged.
Yours is a pre-04 that's all I know, or at least it has the seat. I had a nice and shiny 07 once:
https://i30.tinypic.com/eiv4uf.jpg ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| DanCassidy |
 Posted: 19:20 - 16 Sep 2013 Post subject: |
Is that the stefan everts one? Looks spanking matey!  |
| Irn-Bru |
| prawny1 |
| P.addy |
 P.addy Red Rocket
| prawny1 |
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
