| leonadele |
 leonadele Derestricted Danger
| mudcow007 |
 mudcow007 World Chat Champion
| leonadele |
 Posted: 07:28 - 12 Sep 2013 Post subject: |
Thanks
Mine is a '99 model, I will have a look in the headlight bowl when the new switch comes! |
| Teflon-Mike |
 Posted: 07:34 - 12 Sep 2013 Post subject: |
If you haven't already ordered it; a full 'keyed alike' lock-set; ignition barrel; separate steering lock if the bike has one; seat lock & locking fuel cap, if you have one; costs something like £25 over £10 for ignition barrel on its own.
Fuel cap is straight swap; Seat Lock & steering lock are normally just two cross head screws; Ignition is two screws and plug in the head-lamp.
Lot can be swapped in about quarter of an hour.
Keyed alike set means that you dont have hassle of seperate keys for seperate locks; and if ignition lock worn other probably aren't much better; and key certainly will be. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| leonadele |
 Posted: 12:28 - 12 Sep 2013 Post subject: |
Bugger!
Already ordered the barrel, didn't even think about the rest!!
Looks like I am a two key man now! |
| P.addy |
 P.addy Red Rocket
 Posted: 13:41 - 12 Sep 2013 Post subject: |
Not a tested item...  |
| Teflon-Mike |
| P.addy |
 P.addy Red Rocket
| Rogerborg |
 Rogerborg nimbA
| leonadele |
| P.addy |
 P.addy Red Rocket
| leonadele |
 Posted: 12:40 - 13 Sep 2013 Post subject: |
I will put the exact wording on when I get in from work later for you
In the meantime...
New ignition switch came in the post, its a five wire which should be right for my model, however, took the front lamp off, and there is some kind of connection box, which the wires wont fit into
Has anyone seen one before?
i will try to get a pic up when I get in also |
| leonadele |
 Posted: 13:49 - 14 Sep 2013 Post subject: |
Hope the attachment works, thats my advisory list on the MOT no code next to it, just the **DANGEROUS**?
I just unclipped the wired base from the bottom of theold barrel, and clipped thenew barrel onto the base
Works great!!
Many thanks to everyone for your advice  |
| P.addy |
 P.addy Red Rocket
 Posted: 14:41 - 14 Sep 2013 Post subject: |
Sounds overly picky and hasn't been able to put the actual MOT code on there because the don't exist, either get a new ignition or ignore it  |
| leonadele |
 Posted: 13:47 - 16 Sep 2013 Post subject: |
Cheers Paddy
New ignition sorted  |
The last post was made 12 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
