| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 21:40 - 26 Aug 2013 Post subject: Hornet front wheel - 16 to 17... with a small difference! |
Now, I have an old school Hornet with the 16" front wheel and would like to upgrade to a 17" for better tyre choices... Normally I know I would need a new wheel, discs, etc...
However, my current Hornet has SP1 4 pot Nissin calipers unlike the standard 2 pot jobbies they have. Now I very much like these brakes as they are hundreds of times better than the Hornet ones!
So... if I was to upgrade to a 17" wheel... Would I be able to keep the discs? Or would I also need to upgrade the discs & calipers?
I think I know the answer, I hope I'm wrong and someone else can say if they'll fit!
Ta ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| reed |
 reed Nearly there...
| prawny1 |
 prawny1 World Chat Champion
 Posted: 15:02 - 16 Sep 2013 Post subject: |
If your hornet is this type of three spoke wheel
https://www.ebay.co.uk/itm/HONDA-HORNET-FRONT-WHEEL-16-/230787654429?pt=UK_Motorcycle_Parts_13&hash=item35bc04231d
then the vtr1000 firestorm 17" would be an ideal replacement since they have the same style spokes and the same disc bolt pattern (probably even the same discs)
https://www.ebay.co.uk/itm/Honda-VTR1000F-VTR1000-VTR-1000-F-Firestorm-98-FW-Front-Wheel-/180977333637?pt=UK_Motorcycle_Parts_13&hash=item2a2316f585
The vtr1000 rear wheel is actually the same width as the later smooth spoke hornet wheels at mt5.50 so are better suited to the 180 tyre, but I would imagine you might have to swap bearings and stuff due to the vtr using a 20mm axle (only the inner id of the bearing changes for most.
If your want six spoke wheels the cbr 400/600 vfr400/750 wheels cb400sf wheels would probably do depending on the width (some are only mt3.00),
Most of the time the only difference in the discs between a lot of Hondas (with the same bolt pattern) are the diameter and the thickness of the actual disc and sometimes the bolts thickness,alignment with the calipers is rarely an issue.
The ebay links are by no means the cheapest available it was just two similar pictures to show the spoke types are the same.
I am looking to do a wheel swap on my own bike (cb-1 nc27) only I was looking at early hornet three spoke rears (mt5.00) and was planning on fitting the entire vtr front end.
The 180/55-17 would be too wide for my needs I want to use a 160 section tyre,and from what I can tell 160/60-70x17 are the correct sizes for the rim the 180 should be on an mt5.50+ rim.
Is there any chance you could take a few measurements for me from your rear wheel, I would like to know the width between the sprocket and the disc and the width of the swingarm on the inside so that I can check if the chain will line up.
cheers
sean ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them.
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 16:46 - 16 Sep 2013 Post subject: |
SP1 wheel?
Have you got Hornet or SP1 disks on it at the mo, VTR firestorm front also drops in as said. ____________________ My Flickr |
| m0l0t0v |
 Posted: 22:01 - 18 Sep 2013 Post subject: |
The last post was made 12 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
