Please Help (New Reply) Regarding Jetting!
RalphCh97
PostPosted: 19:55 - 16 Sep 2013    Post subject: Please Help (New Reply) Regarding Jetting! Reply with quote
Hello BCF Members, I am new to bikes so please forgive me if my explanation isn't the best.
I have recently just purchased an Aprilia RX 50 Engine for my bike (Takes AM6 Engine)
I would like to run it with a Yasuni race exhaust and a ram-air air-filter.
I have a Dellorto SHA 12 14 M Carburettor.
The Jet in the carburettor is currently "63" which is stock but i need to up-jet it because of the open air filter and the Race Pipe.
I have been told to up-jet by 10%-15% if running on just the Air filter, But i am not sure how much to up-jet it by with a race pipe and the air filter. 25%?
Please can someone help me, Regarding what jets to buy (For example you can buy jet packs 80-90, Please can someone help me with what sizes to buy so i can find my idle jet.
Please respect my topic as i am very new to bikes and not to good at explaining this stuff.
Please get back to me, thanks.
Regards
Ralph.
prawny1
PostPosted: 21:35 - 16 Sep 2013    Post subject: Reply with quote
Ram air is when you feed high pressure air from the front of the bike through a duct directly into the airbox effectively supercharging the bike at speed,
It is totally different to fitting a pod/ cone type filter which I assume is what you are talking about.
Removing the airbox from a two stroke bike is going to cause you to seize up from running lean, even after re jetting the bike will be less reliable, use more fuel and be worse to ride.
The exhaust would need minor re-jetting but wont be as risky to run round with as a pod filter.
The rs/rx 50 according to the wiki is meant to have a 17.5mm carb and a 102 main jet when derestricted (74 jet when restricted).
The fact that you have a different carb will mean you will struggle with advice on jetting.
https://en.wikipedia.org/wiki/Aprilia_RX/SX_50
hellkat wrote:
andys675
PostPosted: 21:38 - 16 Sep 2013    Post subject: Reply with quote
there is no definitive answer, even 2 bikes with the same parts could be different, go as big as you can maybe even 50%, a jet too big will only knacker your spark plug, too small with knacker your engine, you need to start big and come down in size while doing plug chops (checking the spark plug colour, google it) and also getting a feel for the performance with different jets
PostPosted: 22:07 - 16 Sep 2013    Post subject: Reply with quote
Presume you mean Ram Air as a make of filter.
Idle jet I would leave for now. Main jet is the important one. Do as andys675 says and start big and work down. Remember to move the clip on the needle as well (closer to the pointy end to richen the mixture).
RalphCh97
PostPosted: 17:18 - 17 Sep 2013    Post subject: Thanks Reply with quote
The only reason i am running it on a open filter is because the CPI air box (I have CPI) is different to the air box on the RX, the manifold is bigger, So i am having to run it on a pod filter.
This is the exhaust i have:
https://www.pedparts.co.uk/c/products/RAW/Yasuni_Cross_Exhaust_System_-_Derbi_Senda.jpg
This is the Pod filter i have: Its huge:
https://www.adrenalin-pedstop.co.uk/upload/359x359/09978-MR-016.JPG.jpg
And thanks about the information, I have just posted this to see if anyone has any more information, If so please reply.
RalphCh97
PostPosted: 19:22 - 18 Sep 2013    Post subject: Reply with quote
Hello would you be able to explain what plug chopping is :) sorry about this, new to bikes!
A100man
PostPosted: 19:58 - 18 Sep 2013    Post subject: Reply with quote
Ralphch97 wrote:
Hello would you be able to explain what plug chopping is Smile sorry about this, new to bikes!
Run the bike under load (you on it) down the local bypass at near enough full pelt. Just before you hit a lay-bye kill the engine and stop asap. Do NOT idle the bike.
Remove the spark plug and check the electrode colour.
Black/sooty => too rich
Tobacco/grey colour => about right
White => too lean.
JS
RalphCh97
PostPosted: 20:39 - 18 Sep 2013    Post subject: Reply with quote
Thanks very much everyone, You have really helped me, Ill see you around the forums.
Regards
Ralph
RalphCh97
PostPosted: 19:44 - 19 Sep 2013    Post subject: Reply with quote
Thanks very much for your help, I will do, Thanks again.
The last post was made 12 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 78.99 Kb
