35kw restriction
Bike Chat Forums Index -> New Bikers Goto page 1, 2, 3  Next
barneyr22
PostPosted: 21:44 - 17 Sep 2013    Post subject: 35kw restriction Reply with quote
Does anyone know where i can get a 35kw (46.6 bhp) restrictor kit for a honda cbr600rr 54 plate? Can only find them in germany and dont quite understand Confused OR does anyone know of any other way to restrict it to 35kw? ... heard of throttle restriction but dont know how it works or how to go about getting it put on. Please help!!
Many thanks
Barney
Teflon-Mike
tl;dr
PostPosted: 22:35 - 17 Sep 2013    Post subject: Reply with quote
I suspect you cant get one, because they sell them to make bikes A2 licence catagory complient.
CBR600RR CANNOT be made A2 complient. A2 restrictions say a bike up to 35Kw or restricted down to 35Kw from a standard machine making no more than 2x restricted power.
CBR600RR makes more than 70Kw as standard ergo cannot be restricted, therefore little point making restrictor kits for them.
shaanaleem92
PostPosted: 22:43 - 17 Sep 2013    Post subject: Reply with quote
Unless they passed before the New rules kicked in, in January this year. Which I suppose Is possible,
Then again it wouldn't be 35kw if following old rules I think? Its should be restricted to 33hp (dunno what that is in kw, but think its less than the New 46.6bhp at 35kw)
Right?
Teflon-Mike
tl;dr
PostPosted: 00:49 - 18 Sep 2013    Post subject: Reply with quote
Right?
Yup. There would be no point in marketing a 35Kw restriction kit as 600RR cant be made 35Kw/45bhp A2 complient.
Might, restricting to 25Kw/33bhp be made complient with 'Restricted' licence entitlement, awarded prior to Jan this year.
And to save some searching; I did a review of specs a while back; as far as I'm aware, if you have an A2 licence, you can pretty much dismiss ideas of riding ANY sports 600 made this century; and most made since the class evolved in the mid 80's!
If it is 600cc, has four cylinders, water cooling; and a pointy fairing; odds are you cant ride it legally on an A2 licence.
You will be looking at twins, or tourers, or street-bikes... but even then; the less inspiring 'nakeds' like the Diversion or Bandit; FZ600 Fazer is boarderline depending on model year and who'se numbers you take; Hornet is pretty much off the menu; I think there is one model year variant that might qualify.
Sorts-Bikes? About the only things I found that might be made eligible by restriction was the very early, 1984 Kawasaki GPz600R and its successor the GPx600, which are just heavy enough to not to require restricting beneath 45bhp to meet power to weight limit; and have quoted power low enough that that restricted power is over half stock.
Early CBR600F 'Aero' the jelly-mold model... is on the boarder-line; depends who'se numbers you use, but most favorable I think give it 86bhp, you might squeek one. Likewise early Suzuki GSX-R600's; just heavy enough and just low enough on power depending on whose figures you choose, it 'may' be restrictable.
Suzuki RF600 isn't. Kawasaki ZZR600 isn't. Kawasaki ZX6R definitely isn't. Yamaha YZF-600 'Thundercat' isn't. R6 certainly isn't. Triumph TT600 isn't. Later Model CBR600FII's aren't, FIII's and definitely RR's aren't. Later model GSX-R600's aren't either.
If you have an A2 licence ans want a sports-bike; you are going to have to look at the modern generation of sportier commuter twins; the 250 Ninja or a restricted SV650, kind of thing, to get a more contemporary machine; or you are looking at older 500 twins, like the GPz500S or CB500, or the even older minefield of 90's Japanese home market 'Sports' 400's.
Licence limitations were set DELIBERATELY, where they were to stop, hamper or otherwise discourage new and younger riders from trying to jump straight onto modern sports-bikes and higher performance street-bikes.
And to be honest; you'll likely have more fun on a bike like a 250 Ninja that's un-restricted, or a GPZ500S that's only mildly restricted; and able to run pretty close to the edge of its performance envelope and not feel frustrated; than you would on a 600cc sports-bike, designed to go 150 miles an hour, with its balls lopped off, so you never get to let it stretch its legs! Things are designed to do one thing; go fast. Restrict'em? So they cant, why bother?
The modern sports 600 is a very refined and clinical bit of kit; it's designed to make going fast easy; consequently they offer very little rider feed-back until they are pushing the limits of their performance envelope; and just 'work' offering very little sense of satisfaction or reward for riding them unless you are right on the ragged edge.
Get on a bike like the GPz500? Well, the twin pot motor is rather lumpy, and you'll know when you are thrashing the thing; same with the handling; softer, less refined, built to a lower budget, it'll start getting 'entertaining' at the sort of velocities it can more easily achieve; and it will have a much wider margin in that 'ragged edge' before it chucks you in a hedge! Meanwhile... you'll have to work for your fast, and from that effort comes reward and rider satisfaction. So far better choice for a newby, all round, really.
Even on a pre-Jan 2013 25Kw/33bhp restricted licence.
Slacker24seve...
PostPosted: 07:49 - 18 Sep 2013    Post subject: Reply with quote
Mike you always say this about 600 Supersports not giving feedback.... When did you last ride a 600 sportsbike or is that something you just plucked out of your arse? They give plenty of feedback.
I'd advise against one as a first bike and getting something softer and friendlier but they aren't the instruments of death you make them out to be.
Banger rallies are ace
shaanaleem92
PostPosted: 08:00 - 18 Sep 2013    Post subject: Reply with quote
Well companies have made bikes to comply witb the New rules I.e Honda with their new 500 range
Cbr500 cbf500, I think theirs one more maybe cb500
And I believe these are built just on the limit, so must be good as they are unrestricted. Problem being they are pricey as they were manufactured from 2013 onwards.
Kawasaki have the ninja 300 which complies with the a2 license, and they also provide an er6f - to be restricted which meets a2 license... These can be had cheaper
Not sure about other brands as Ihaven't looked into them but I would imagine they all would bring out New bikes that meet the requirements of the newer license category
PostPosted: 10:22 - 18 Sep 2013    Post subject: Reply with quote
Pointy-plasticky bikes under 70kW and suitable to restrict down to 35kW (but be careful of the power-to-weight):
CBR400R
GSX-R400
ZXR400
GS500F (bang on 35kW natively)
SV650S with fairing lowers.
GPZ500S (middle fairing panels are available to fill the gap)
GSX650F
Ninja 250
Ninja 300
CBR500R
SteveZZR
PostPosted: 21:54 - 18 Sep 2013    Post subject: Reply with quote
I quite like the Triumph approach to these stupid new rules
They're offering certain bikes of theirs that come from the factory with a fiddled ECU that makes them 93BHP instead of whatever they are standard and call it a derivative model so that "as standard" it falls into the category for the new licenses.
Personally, what is achieved by limiting the power the bike "did" have before restriction? My ZZR 600 would've been 98bhp on paper "as standard" so would fall outside the current licenses for some reason; yet was a perfectly competent machine (and faster than a Ninja 250R) as a 33bhp machine.
OP, Just get an older 250 or something they're better than modern ones.
Best bet - VFR 400
Teflon-Mike
tl;dr
PostPosted: 22:13 - 18 Sep 2013    Post subject: Reply with quote
As above; they want to stop, detur or make it as pointless as possible for new riders to jump onto high performance sports bikes.
Too many 'loose' the restrictors; so they have simply capped what you can restrict beneath what they dont want you to have.
bren_9311
PostPosted: 22:18 - 18 Sep 2013    Post subject: Reply with quote
The op has to be trolling.
My opinion is neither copyrighted nor trademarked. If you like, I'll trade for one of yours.
Currently bikeless. Sad
Ps4- bren_9311
SteveZZR
PostPosted: 11:03 - 19 Sep 2013    Post subject: Reply with quote
By that logic it's been deemed ok to have a 94bhp machine on an A2 then?
If they're choosing it by "what's ok to ride unrestricted" as the valid bikes for restriction, why not just put out a list of bikes people can ride on an A2 and stick to that?
My main issue with this is, you could have something like a Ducati 748 (94 paper horsepower but a metric fuckton of torque) which is like shit off a shiny shovel sports performance and handling but A2 valid, yet an all rounder and fairly docile when restricted / below 8000rpm ZZR 600 (which I found to be brilliant restricted) isn't allowed to be used.
What really takes the piss, as previously mentioned and I've now found a link https://www.bikechatforums.com/viewtopic.php?t=275331
Triumph make a Street Triple with a flashed ECU so it comes from the factory with a little bit less power (same bike and price!!) so it falls into this ridiculous category.
To me that is the same as restricting any bike you want - If you got an injected SV650 that was set to 47bhp and fitted a full power ECU it'd be full power. If you got this A2 Street Triple and fitted a full power ECU it'd be full power. If you fit the 47bhp ECU it's an A2 compliant machine. I really don't get why they picked 94bhp as an upper limit either? Why not 100bhp? Why not 90bhp? I think 100bhp and 700cc would've made more sense really as it'd eliminate the higher performance V-Twin's that people could kill kittens with unrestricted; but then it discriminates if someone wanted a cruiser which is generally lower power, lower RPM, higher CC.
Clearly needs more complex rules, governed by Torque and P:W ratio not a power limit.
Is there a bike weighing over 175kg with retarded amounts of Torque and under 95bhp?
PostPosted: 14:37 - 19 Sep 2013    Post subject: Reply with quote
You can't, makes too much horsepower to begin with.
Good bikes though.
lihp
PostPosted: 16:08 - 19 Sep 2013    Post subject: Reply with quote
Torque is a function of power and rpm.
PostPosted: 16:29 - 19 Sep 2013    Post subject: Reply with quote
I think they shouldn't restrict people. Either make them wait it out till they are 24 or let them run wild, the shit and weak will wipe themselves out of the gene pool soon.
Teflon-Mike
tl;dr
PostPosted: 17:33 - 19 Sep 2013    Post subject: Reply with quote
No, they merely have looked for a way to limit how much scope cheats have to play with in the margins.
There's no real 'logic; to it.
I've always held that 'restrictions' are self defeating anyway; I mean; conscientious rider likely to respect restrictions, probably doesn't need restricting to begin with; rider who they try and save from themself by imposing restriuctions, is unlikely to respect them.
Man can drown in an inch of water reasoning; 125's can be as fast as any bike is allowed to go on UK roads; most motorcycle accidents happen under speed limits anyway...
Its like trying to tackle drunkeness by stopping the bars selling spirits, when beer will get folks drunk just as well if they are deturmined to!
Yeah... what they are trying to do, really, is steer newbs to bikes of a certain 'nature'... trouble is, bike's charecter or nature isn't something that can really be defined in vital statistics!
How close are the numbers for a ZZR600 to those of a GSX-R600? Yet, 'soft' all-round capable Zed falls outside restriction perameters; rather more 'hooligan' Gixxer might be restrictable.
And of course; there's always cheats.
When the UK MCI made a gentlements agreement with the DoT not to import any bike over 125bhp in the late 1980's, Yamaha put rubber restriction shrouds in the carb rubbers of the FZR1000EXUP. 140bhp bike was sold in the showrooms with a 'quoted' 125. Wip the carbs off, cut teh shrouds out with a scalpel. Full power, and Yamaha still honoured the warranty!
Manufacturers fudging the figures with alternative ECU Maps and the numbers they declare to be 'Standard'? It's Nothing new.
And its not great.
The 'Restrictions' are the legislators attempt to stop people being a bit 'Daft' on motorbikes..... the stuff they choose to target for 'restriction' is only notionally associated with the problem of safety they want to address, but practically all they can fiddle with to do 'something' that might help.
So, market reacts, finding more imaginative ways to 'cheat' the restrictions, proving them less effective than legislators hoped.... so they go back to the drawing board, and frame new even tighter legislation to curb the excesses of those that look for a work-around!
Which thems that would respect the restrictions to begin with... get lammed with, and probably have thier biking needlessly impedimented... while thems that need the restrictions, and don't respect them, dont respect and look for newer and more imaginative work-arounds... and so the cycle continues, in ever decreasing circles!
Well, A2 says 35Kw, 0.2Kw/Kg and restricted power >2x original spec power... its already got power to weight, and its already got complicated convalutions!
What they OUGHT to do, is;
1/ Get rid of unsupervised 125 L-Plating.
2/ Get rid of the fucking DAS rules and dopey age limits.
Theres bog all 'real' corrolation between maturity and age. And DAS pandering to the impatient, 'want it all here and now; just tell me how much' rider, is breeding riders with the 'wrong' attitude to begin with; and giving them instant access to the machines they want to discourage!
And regs are ignoring their own evidence for the regs!
Biggest risk groups in the stats are L-Platers. There are more of them and lacking experience they tend to crash most. But while perpetual L-Plating is maintained; there's nothing being done to improve rider standards amongst them!
Rather ironic then to start imposing 'restrictions' on those riders who HAVE made the grade and proved their competence who are rather less at risk!
Except that while L-Platers crash most often; DAS newbs with less than three years experience, are the most likely to be Killed-Seriousely-Injured!
THEY actually are the ones who might be 'saved' by performace limitations! Yet, they are being given ride what you like, unrestriced licences for doing a three day crash course, and thinking that makes them competant enough to handle an R1!
The tiered licence does have some good and reasonable reasoning behind it... but way its been framed into legislation is a farse!
Way to actually make a difference would be to encourage riders to gain competance and experience and a 'sensible' attitude, following a motorcycling 'aprenticeship', irrespective of 'age'.
Make the CBT a little more rigerouse; include a 'Verbal' theory in the class-room element, and 'practical' Hazard Perception test; maybe make it a two-day course; hand out A1 licences upon submission of a DL196
Want more than a 125? Then an A2, licence; Compulsary Training course, say six modules of continual assessement, like CBT Road Element; covering specific areas of road riding. Instructor signs off student, and when the student has enough module passes; applies for a DSA assessement ride; pass that; gets A2 licence. Perhaps with slightly better A2 licence restrictions; something simpler... say... 500cc and 60bhp. 'as standard' no post show-room restrictions.
Want more than that? More training, more modules, Another assessement ride. Perhaps twice as many though. Go through that; get A3, but not quite a full unrestricted ride what you like licence; lets say 1000cc, 100bhp, more than 200Kg, 'as standard' no post show-room mods or restrictions.
Want to ride anything else? More training, more modules, another assessement ride. Possibly even on the bike you WANT to ride! As some other country's licencing / taxing system. You want a new bike; you have to take it to licence office within ten days, and show them you can ride the fucker!
No cheats, no shortcuts, work your way up, at whatever pace you want, whatever age you are.
BUT; political. They don't do what's 'Sensible' they do what they can get away with!
Copycat73
PostPosted: 18:07 - 19 Sep 2013    Post subject: Reply with quote
@ Teflon-Mike
you need to get out more ... Rolling Eyes
caveat emptor
J.M.
PostPosted: 18:33 - 19 Sep 2013    Post subject: Reply with quote
Copycat73 wrote:
@ Teflon-Mike
Why? Maybe he enjoys writing.
2004 R1 & 2018 XSR900
Copycat73
PostPosted: 19:07 - 19 Sep 2013    Post subject: Reply with quote
J.M. wrote:
Copycat73 wrote:
@ Teflon-Mike
the word is pontificating ..
and yes "enjoy" ....that was never in any doubt ... Crying or Very sad
caveat emptor
barneyr22
PostPosted: 02:07 - 21 Sep 2013    Post subject: Reply with quote
cheers guys this has helped a lot ... actually have some direction now in finding another bike!! Very Happy
many thanks
barney
Barney
weasley
PostPosted: 08:16 - 21 Sep 2013    Post subject: Reply with quote
No - power is a function of torque and rpm.
Slacker24seve...
PostPosted: 08:58 - 21 Sep 2013    Post subject: Reply with quote
All that stuff by Mike and he still ignored my question about his experience of modern 600s.
Any danger of an answer Mike? You write a lot about this topic but some of it sounds like rubbish. What modern 600 sportsbikes have you actually been on to know that they give no feedback?
Copycat73
PostPosted: 20:01 - 22 Sep 2013    Post subject: Reply with quote
you are the third person to ask him; that I am aware of ;where he gets his information/opinions/experiance from or similar question.... as yet there have been no replies... I`m not holding my breath till he replies Sick
caveat emptor
Slacker24seve...
PostPosted: 20:26 - 22 Sep 2013    Post subject: Reply with quote
Exactly. I'm in agreement with him that they don't make ideal first bikes but saying they give no feedback is bollocks - they just have a bigger performance envelope and the consequences of not listening to what the bike is telling you are greater.
Teflon-Mike
tl;dr
PostPosted: 00:52 - 23 Sep 2013    Post subject: Reply with quote
Not replied, as I don't see much point in joining an argument where you are so happily telling every-one what you would like me to have said... not what I did, and why you disagree with what I didn't say... and expecting me to defend it?!?!? While agreeing, in principle to what I actually DID say?!!?!?!?
PostPosted: 06:57 - 23 Sep 2013    Post subject: Reply with quote
Ignoring it again, he hasn't ridden anything modern anyway so its not worth the hassle. Laughing
The last post was made 13 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 151.96 Kb
