Warning, windows 8 downgrade to 7 is a minefield
oldpink
PostPosted: 22:04 - 17 Sep 2013    Post subject: Warning, windows 8 downgrade to 7 is a minefield Reply with quote
I think I hate Windows 8 more than apples software (yes that much)
A friend got himself a plotter / vinyl cutter so needed a laptop to run it
he bought an Asus that has pretty decent spec's
when we tried to install the plotter the installer just kept looping back to the install screen
and the software that came with it was from 2009 and no mention of win 8
I put the drivers & software into my win 7 laptop and bobs your aunty away it went
he seen my win 7 setup and asked if I could put the same on his as it was similar to what he used at work
I said yeah no problem Rolling Eyes
turns out you can't just bung windows 7 in and reboot and install
I had to reconfigure the Bios to turn off boot protection then reboot
select the boot drive (USB DVD)
then after 3 attempts I finally wiped all the partitions removing the system / restore / data / and another reserved partition
before it would even allow me to format so it would allow the install and bypass the GPT disk format protection
thankfully it worked or it could have been a brick with no restore option
so take my advice buy a laptop with 7 on it or be prepared for a major mission to get 7 or any other OS working on it Thumbs Up
Marmalade
PostPosted: 22:08 - 17 Sep 2013    Post subject: Re: Warning, windows 8 downgrade to 7 is a minefield Reply with quote
oldpink wrote:
...so take my advice buy a laptop with 7 on it or be prepared for a major mission to get 7 or any other OS working on it Thumbs Up
I hate it too but finding an affordable (or any) laptop with win 7 is a job in itself
sickpup
Old Timer
PostPosted: 22:45 - 17 Sep 2013    Post subject: Re: Warning, windows 8 downgrade to 7 is a minefield Reply with quote
Would only be bricked because you didn't make a USB restore drive before messing around with it.
oldpink
PostPosted: 23:18 - 17 Sep 2013    Post subject: Reply with quote
no I'd would have to have loaded it back up with Win 8 from the DVD
but it would still be useless as it won't allow the driver to install and there is no upgrade available
I've been building and sorting peoples fucked up PC's and laptops for well over 20 years
and have loads of experience with CAD and plotters having worked in engineering as an IT consultant
I like a challenge and it didn't take me long to figure out the problem and sort it
this was more for people that may think its easy when in fact you need to have some knowledge of what you are doing
the backup plan was Linux but said friend isn't tech savvy but there was drivers and software
but I did enjoy the challenge to getting around micro$oft's stupid policy's
Sload
PostPosted: 23:23 - 17 Sep 2013    Post subject: Reply with quote
Nothing you described sounded particularly awkward or out of the ordanary, just unfamiliar to you.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
oldpink
PostPosted: 23:35 - 17 Sep 2013    Post subject: Reply with quote
well you don't normally have to do more than change the boot sequence in the bios to get an OS to install
the awkward part was I was trying to keep the restore folders as M$ say the warranty is void if you "down grade"
and you can only do it if you have Win 8 pro according to M$
yes unfamiliar as I'd never had to do it before
but I know enough about computers to know it could be done
CaNsA
PostPosted: 23:37 - 17 Sep 2013    Post subject: Reply with quote
I see the problem here....
Its the 1st 3 letters in your nick.
Leave this sorta stuff to the whippersnappers.
prawny1
PostPosted: 23:48 - 17 Sep 2013    Post subject: Reply with quote
Does windows 8 not include compatibility mode for windows 7?
Did you make the asus system restore discs before wiping everything? (worst case scenario recovery media in case hdd dies) you know in case he wants to sell it with 8 on or send it in for repair under warranty with the factory installed o.s.
My acer v5 would not let me use my restore dvd's until I completely erased the hdd and all partitions (new hdd would have worked though) , it then started fresh and remade all the hidden recovery partitions.
Once I knew the disc are good and had that I had all the drivers identified I went for a clean generic install anyway to keep things clean and the hdd uncluttered.
hellkat wrote:
oldpink
PostPosted: 23:49 - 17 Sep 2013    Post subject: Reply with quote
may be getting old but not that old I still enjoy a challenge
and I did what I set out to do and had fun doing it
oldpink
PostPosted: 23:52 - 17 Sep 2013    Post subject: Reply with quote
the main issue was a driver issue and the software compatibility
also a familiar interface was required
the down grade sorted all these issues if not a bit of a PITA to get to work
Spudly
PostPosted: 23:55 - 17 Sep 2013    Post subject: Reply with quote
Don't spose you considered right clicking the installer and looking at "Properties", choosing the "Compatibility" tab and setting the installer to run in Windows 7 compatibility mode?
May have saved a lot of time.
The Old Apprentice
CaNsA
PostPosted: 23:58 - 17 Sep 2013    Post subject: Reply with quote
So do retards.
LOL!
oldpink
PostPosted: 00:03 - 18 Sep 2013    Post subject: Reply with quote
doesn't work that way
M$ does not allow you to downgrade to an older ver you have to remove the newer ver or dual boot
and my friend can just about turn it on
CaNsA
I've always been a retard but it helps Laughing
prawny1
PostPosted: 00:06 - 18 Sep 2013    Post subject: Reply with quote
setting up a vm (virtual machine) for the software to run on would have been another option.
Spudly
PostPosted: 09:27 - 18 Sep 2013    Post subject: Reply with quote
CaNsA
You missed my point. You uninstalled an entire operating system, with all the attendant niggles and problems involved - fdisking and formatting and so on, because you wanted to run a particular program. Did you try running the program in compatibility mode before deciding on going down the downgrade path?
The Old Apprentice
Scythe
PostPosted: 10:10 - 18 Sep 2013    Post subject: Reply with quote
+1 Looks like the OP hasn't experienced compatibility mode. Saying that, it never seemed to work anyway although the last time I had to use it was XP.
Also, in almost all OEM builds you have to change the boot sequence and they almost always have the HD as #1 with CD / USB as #2 as it helps to speed up booting as time is saved from seeking a ext. drive at first.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
oldpink
PostPosted: 10:48 - 18 Sep 2013    Post subject: Reply with quote
on the contrary I am very familiar with compatibility mode we often had to use it to get software to work
after upgrading the OS in banking systems etc
its not just a case of changing the Bios boot list,
in this case I had to turn off the boot protection mode, them turn on CSM legacy mode before it will even see the DVD as a device
you then need to save reboot then go back into the Bios and then select the DVD as the first boot device
J.M.
PostPosted: 13:40 - 18 Sep 2013    Post subject: Reply with quote
Secure Boot is not a Microsoft invention, Windows 8 is simply the first major OS to implement it. It's part of the UEFI specification.
In order for a computer to be Windows 8 certified, the computer must support Secure Boot. Additionally it is specified that Secure Boot must be able to be disabled. Secure Boot works by ensuring that the OS Loader is valid, trusted and untampered with. A good thing because it works to prevent low level malware. Some Linux distributions are becoming compatible with this Secure Boot too. So not all in all a bad thing, but it does introduce extra steps.
https://www.howtogeek.com/149254/if-i-buy-a-computer-with-windows-8-and-secure-boot-can-i-still-install-linux/
2004 R1 & 2018 XSR900
PostPosted: 14:36 - 18 Sep 2013    Post subject: Reply with quote
We'll look back on EUFI as the Good Old Days once TPM 2.0 and it's "Off switch? No... you don't need an off switch," is in the wild. I.e. a big f​uck GNU. You'll have the OS that comes with your hardware, and not question it, or what it's doing.
That shebang was cooked up by Microsoft and the NSA, without any veneer of non-hostility. Remember the Clipper Chip? No, you probably don't.
I may just be a wacky paranoid, mind, like those crazy funsters in the German government who are shitcanning Windows 8.1 on that basis. Wink
Jayy
Mr. Ponzi
PostPosted: 15:09 - 18 Sep 2013    Post subject: Reply with quote
I just bought Windows 8 earlier today from Scan.
Depends on what you want to use it for, it's just Win 7 but refined and tweaked.
Hetzer
PostPosted: 15:27 - 18 Sep 2013    Post subject: Reply with quote
No it's not, it's Win7 turned into a mobile-device POS.
PostPosted: 15:29 - 18 Sep 2013    Post subject: Reply with quote
Definitely not a refined Windows 7, its far too restrictive and definitely more mobile/tablet based.
Jayy
Mr. Ponzi
PostPosted: 17:14 - 18 Sep 2013    Post subject: Reply with quote
It has mobile/tablet orientated features, for the likes of their surface tablets etc, hence the Metro interface but under all that, there are refined/tweaked things in there.
Like I said, depends what your reason for using it is.
The last post was made 13 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 124.59 Kb
