| Going2fast |
 Going2fast World Chat Champion
 Posted: 00:35 - 11 Dec 2004 Post subject: Fuel Tap |
Hey this is going to sound kind of silly but...
How long do you allow your bike to stand before you turn your fuel tap to off?
Lets say you were doing a 8hour shift at work, would you turn it to the off position or just leave it set to on?
Hope that question is not so silly
Andy ____________________ Passed My Test 15/03/05
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy |
| Ste |
 Ste Not Work Safe
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| instigator |
 instigator Super Spammer
 Posted: 14:41 - 11 Dec 2004 Post subject: |
Mine doesn't have an off switch, so its not an issue with me. Thankfully  |
| Frost |
 Frost World Chat Champion
| Going2fast |
 Posted: 18:26 - 11 Dec 2004 Post subject: |
Okay cheers for replies, how you think my RVF would take it leaving it set to "on" ?
Thanks again
/-\ndy |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
| Marc_Buck |
 Marc_Buck Could Be A Chat Bot
| DM |
 DM Scooby Slapper
| Josh|RD125LC |
 Josh|RD125LC World Chat Champion
 Posted: 21:46 - 11 Dec 2004 Post subject: |
Yeah same here. Oh I did turn it off once when I went on holiday  ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| Craggles |
 Craggles Traffic Copper
| Mister James |
 Mister James I want to believe!
| TheShaggyDA |
 TheShaggyDA Repost Police
| mrchips |
 mrchips World Chat Champion
 Posted: 18:23 - 12 Dec 2004 Post subject: |
I've done it when my bikes have been flooding but apart from that I've had it on for months as there's no point turning it off all the time it nearly seems harder to start then. It may also be good for security though so if they don't know how to work fuel taps you;ll find it about a mile down the road! ____________________ Northern Irish? www.nibikers.com |
| pipnet11 |
 pipnet11 Brolly Dolly
| 8316 |
 8316 Could Be A Chat Bot
 Posted: 14:24 - 13 Dec 2004 Post subject: |
i switch the fuel off when im at school and work. i know some idiots pretend they are cool and open the throttle when its off. very annoying.
as for the reserve switch- well mines bust! my "on" tap has lost the filter, so i cant tell when I'm in reserve or not! so I've run out 3 times now. 1 intentional though!  ____________________ Now own a Fireblade!! Speed Limits? Bah! |
| steveh |
 steveh World Chat Champion
 Posted: 16:04 - 13 Dec 2004 Post subject: |
well now i leave it on, as i kept on turning it off and forgetting, getting half way down the road and shudders to a halt
Steve. ____________________ Current : 06 Zx10r, 07 Wr450f SM, 74 850 norton commando, 63 bsa b40, 1962 Triton 650, 67 Triumph Tr6r, 1955 Triton 750, 1978 TY250E. |
 Posted: 19:59 - 13 Dec 2004 Post subject: |
You really should not need to switch it off.
Fuel will only get into the carbs from the tank if either the fuel level drops or the needle valve does not close. The fuel level should not drop of its own accord (but it does on the FZR600 for some reason). Only time opening the throttle will be a problem is if you have accelerater pump carbs (which counts out most carbed bikes, and the only ones I can think of are some Guzzis and Ducatis). If the carbs are in good condition then the needle valve should seal properly.
Also most bikes have vacuum fuel taps so should only allow fuel to flow when the engine is running to generate a vacuum (this is why you often have a "PRI" position which is not vacuum controlled).
That said a tiny piece of dirt in the needle valve will allow petrol to flow through. On the Bandit once I was forgetful and left if on prime, and overnight it drained about 3/4 of a tank of fuel through the carbs into the engine and airbox.
Generally I do not bother to turn off the petrol. It can cause other problems with some bikes, and the tiny amount in the float bowl will dry out and leave a residue that can cause the carb to stick (so when you turn the petrol back on it floods out).
| Barker-CBR 600 |
 Barker-CBR 600 Could Be A Chat Bot
| Gazdaman |
 Gazdaman I did a trackday!!!
| mchaggis |
 mchaggis World Chat Champion
The last post was made 21 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
