| Cyclingbiker |
 Cyclingbiker Spanner Monkey
 Posted: 15:46 - 22 Sep 2013 Post subject: CB500 Charging issue - Is my rectifier duff? |
I have my first big bike now after passing my test last year. It is a 1999 Honda CB500s (with the half fairing) in yellow, the bike is in fairly good nick for its ages some chips and scratches plus a hole in the silencer that could do with welding up at some point. The bike runs well and is sooooo much faster than my 125, even at 33bhp.
The only issue I'm having is with battery charging. Basically the bike will run forever with no lights on or just the sidelight on, but as soon as I put the main or hi-beam on it will drain the battery very quickly. The bike will run but won't start again if I switch it off, the battery will be flat or very nearly so. This doesn't happen unless I have been running the main beam though.
I have suspect a duff rectifier and have my Haynes manual to help me test it. So far I taken the battery from the bike and charged it up to capacity with a trickle charger, I left it on all night and by the morning it showed a steady 12.9 volts once it had been disconnected from the charger for a few hours. It was then hooked back up to the bike to test for rectifier output with my multimeter.
In the Haynes it asks to start the bike and switch the Hi beam on, the bike is supposed to run a 60/55w H4 bulb and I can confirm that it has one fitted. There are no other power-draining accessories such as alarms or heated grips fitted to suck the power.
So with the lights on and the bike held steady at 5000 rpm I should be seeing between 14.0 and 15.5v on the meter across the terminals but I can only see a max of 12.7v and with any less revs it drops rapidly (within a few seconds) below 11v. This is why it is draining so quick I suppose.
Without any load on the system, all lights off, I do get the specified voltage across the terminals but not with the lights on.
Then I go to test the rectifier with the Ohms resistance scale on my meter. The Haynes has a small diagram of the 5 pins on the rectifier marked clockwise from bottom-left "A-B-C-D-E". B-C-D are the input from the generator and A-E are to the battery and earth respectively.
https://cdn.bikechatforums.com/files/rectifier.png
What is confusing me though is that I only get the specified readings with the polarity of the leads reversed! So that when I should be getting those readings with the positive lead on "A" and the negative lead on one of the others I get no continuity. It is only when I put the negative lead on "A" and try again with positive lead on the others that I get the readings I am looking for
Somebody help me out here, if is duff or not? ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12 |
| salem1987 |
 salem1987 Scooby Slapper
| Cyclingbiker |
| stinkwheel |
 Posted: 21:04 - 22 Sep 2013 Post subject: |
Ignore that testing diagram. It will only work on a dynamic test with a particular type of ohmeter.
A normal multimeter doesn't use enough voltage to saturate the semiconductors in the reg/rec and you'll get all manner of weird readings.
The cances are, it's the reg/rec. Your bike is bang in the middle of the era when they were making dodgy ones and I know for a fact yours has one of the ones with absolutely no heat sinking at all because Mrs stinkwheel has the exact same model.
One other possability is if there is something causing a huge drain along with the lights. Repeat the test with the lights off and see if it's putting out your 14-15.5V.
If it's charging properly with the lights off, it would be nice to get an ammeter in series with the headlights and see how much current they're drawing. I'd be expecting somewhere in the region of 6.5 to 7.5 amps just from the lights. Bear this in mind because you'll fry a standard multimeter with this much current. Many of them will have a specific 10A input, this would be the time to use it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Islander |
 Islander World Chat Champion
 Posted: 21:09 - 22 Sep 2013 Post subject: |
As Stinkwheel said, you'll need a specific type of meter with a semiconductor test function to get any sense out of it. A reading in one direction and not the other is normal for a semiconductor junction - that's what they do, pass current in one direction only.
Voltage checks are the usual way of finding out where the fault is.  |
| Cyclingbiker |
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
| cb1rocket |
 cb1rocket World Chat Champion
| Islander |
| Robby |
 Robby Dirty Old Man
| smegballs |
 smegballs World Chat Champion
| Cyclingbiker |
 Posted: 18:55 - 05 Oct 2013 Post subject: |
Cheers guys this is now (Hopefully) sorted for good.
I ended up with a MOSFET rectifier from a BMW S1000rr that I picked up from a German breakers on eBay for £65 posted. It is specifically a Shindengen FH012DA.
For connections instead of buying those blocks from the states I went off a tip from many of the Triumph forums' threads on rectifier upgrades following a recall for some models fitted with shunt-type rectifiers. There is an official link lead sold by triumph for these upgrades with the part number T2500676
https://www.triumphrat.net/memberalbums/data/837/FH012_adapter.jpg
The 2-pin plug had the wires removed and set aside for a later date when I can fit the unit a little more permanently and so I untaped the two sets of wires so I have no excess wires in the tight space behind the LH panel of the bike. The 3-pin plug is the input from the genny and plug at the other end matches the plug from the stator but lacks the locking pin so I'll need to get that rectified fairly soon but for now it is going nowhere. I have removed the two battery wires from the old rectifier block and fitted the + and - spades directly to the pins on rectifier, it is not ideal but will do for now.
The battery is a little discharged at the moment but I was still getting a steady 12.5v at idle with full beam with a slow rise over the course of a few mins. At 5k rpm the voltage was up past 13.5v with high beam on and 14v without. I will be having a good ride out tomorrow and so the battery will get a good top-up.
I've just had a good 20 min ride in the dark with lights on and all is well so far
Did have an unrelated issue earlier as I was about to take the bike out for a test rise. The sidestand switch had developed at fault and was intermittently cutting the engine even with the stand up and the bike in gear so I had to bypass it for now with a piece of wire bridging 2 of the 3 pins and held on with insulating tape. I will get a new switch or permanent bypass sorted ASAP.
Also found out headstock bearings need replacing too as they are knocking slightly and have a notchy feeling to them  ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
The last post was made 12 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
