| blueflash |
 blueflash L Plate Warrior
 Posted: 01:52 - 21 Sep 2013 Post subject: Fireblade 954 'launch' problem |
Hi all,
hope someone can help, I've owned my Blade for about 6 months and almost 4000 miles and it's never missed a beat, pootling in traffic or screaming round the Isle of Man this year but today, after a short ride back from work, after waiting at the traffic lights for a minute or two, it really struggled pulling away...the worst thing being I almost didn't pull away from the moped eyeballing my bike! It really felt as if I'd try to pull away in 3rd or 4th, it was really weird, it then picked up after some high revving and was fine for a minute or two then it felt sluggish again briefly then fine, i was near home then so pulled into the drive and left it running for abit, held it at different revs for a bit but no problem.
I'd be very grateful if anyone could suggest anything, it's had a full service, at the end of May, there is fuel in there, not loads but not on reserve light.
Thanks buckets!
Dan |
| Pete. |
 Pete. Super Spammer
 Posted: 08:34 - 21 Sep 2013 Post subject: |
Your clutch is slipping. Common reasons are:
Cable stiff from being full of gunge at the ends or frayed
Not enough free-play in the cable
Clutch pack worn
First thing to do is loosen off the cable adjuster and check that the cable moves freely. you should be able to remove the cable at the engine and push-pull it with light effort and make the lever flap about. ____________________ a.k.a 'Geri'
| Hetzer |
 Hetzer Super Spammer
| jjdugen |
 jjdugen World Chat Champion
| Fizzer Thou |
| prawny1 |
 prawny1 World Chat Champion
| blueflash |
 Posted: 16:54 - 21 Sep 2013 Post subject: |
Cheers guys, it did feel to me more fuel symptomatic than clutch as revving whilst slipping the clutch which was biting fine seemed to alleviate the problem then only a little reoccurance half a mile later but not as severe. Serviced about 2000 miles ago in May but don't think the filter was changed but I'll check as it was mate who did it at his garage, I know I had to change one on my '98 CBR600, that had really gone.
Might be worth changing the Rectifier and pump anyway, sooner rather than later to be safe...I can check the contacts to be sure at the time, can't be getting taken at the lights by a Honda Melody!
| blueflash |
| CaNsA |
 CaNsA Super Spammer
| Fizzer Thou |
| CaNsA |
 CaNsA Super Spammer
 Posted: 19:44 - 22 Sep 2013 Post subject: |
fair enough  |
| Aff |
 Aff World Chat Champion
 Posted: 19:54 - 22 Sep 2013 Post subject: |
Fuel pressure regulators are a very common problem on 929's and 954's. The diaphragms fail and fuel is sucked directly into the throttle bodies.
Cause pretty similar symptoms to what you're describing, along with terrible fuel efficiency.
Pull the tank up and locate the FPR (on the end of the fuel rail on the left hand side of the bike).
Pull of the vacuum tube and check to see if its wet, it is is, you need a new FPR.
If it isn't, the fuel may have evaporated, take the vacuum pipe off and turn the ignition on and off letting the fuel pump prime. If fuel starts pissing out the hole, you need a new FPR. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| blueflash |
| Aff |
| Acemastr |
 Acemastr World Chat Champion
| blueflash |
The last post was made 13 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
