Lighting a garage
Paris2
PostPosted: 15:31 - 23 Sep 2013    Post subject: Lighting a garage Reply with quote
I have been using my garage as a mini gym for the past few months during the evenings. Though with daylight getting shorter I need to find a way to light it up so I can use it throughout winter.
The garage itself is about 30 feet from my house, though it has no mains power. I don’t want to use an extension lead, as it is a frequently used parking lot so that would cause issues. I would ideally like something I can hang on a wall or shelf, that would be rechargeable and would give decent light for the whole space. The lights themselves don’t need a decent battery life, as I am not in the garage for any longer than 2 hours at a time.
I have been thinking along the lines of a couple of these, hanging from opposite walls (though a rechargable one would be better):
https://www.amazon.co.uk/Rolson-61770-LED-Camping-Light/dp/B002JM0JIA/ref=pd_cp_kh_0
Would these be sufficient to light the space, or does anyone have any better ideas?
Current Ride: Daytona 600
metalangel
PostPosted: 16:43 - 23 Sep 2013    Post subject: Reply with quote
I don't know how well put together your garage is, but with mine there were a few gaps in the door and also some condensation from the roof. The missus bought a 'push light' somewhere, basically you push on the clear part of the light itself to turn it on or off. Both this mechanism and the backup pull cord quickly became ruined by the cold temperatures/moisture/dust in the garage and it stopped working reliably.
That one in the link seems decent looking switch and if it's designed for camping it's probably reasonably resistant to weather too.
PostPosted: 16:48 - 23 Sep 2013    Post subject: Reply with quote
My Dad was a fire alarm and emergency lighting engineer, he 'acquired' some of the lighting units and wired a mains plug to the cable. Basically any time it is plugged in the light is off and it charges when it is unplugged the light comes on a lasts a few hours, they are pretty bright and 1-2 of them would certainly cover a standard garage. We keep one by the fuse box.
nowhere.elysium
The Pork Lord
PostPosted: 17:10 - 23 Sep 2013    Post subject: Reply with quote
Those Rolson light bars are bright, but pretty directional (as is the problem with LEDs).
Paris2
PostPosted: 18:20 - 23 Sep 2013    Post subject: Reply with quote
Cheers guys.
I've heard the LED bars are bright but don't give great light coverage, would two of those be decent enough to light an average garage? Or shall I look for something more substantial?
Wonko The Sane
PostPosted: 19:36 - 23 Sep 2013    Post subject: Reply with quote
Old motorbike fuse box, headlight and battery?
mic
PostPosted: 19:37 - 23 Sep 2013    Post subject: Reply with quote
lesuire battery for around £60 and a camping light (or mechanics spotlight thingy) will only need to charge the battery every now and then whilst your at work etc Thumbs Up
zzr600
BTTD
PostPosted: 20:55 - 23 Sep 2013    Post subject: Reply with quote
I've got four of those light bars in my garage and they're bright enough when the batterys are in good shape. In my single garage with no electric I've painted the walls and ceiling white which helps bounce the light around a bit.
One or two of the individual LED's look like they've given up, and I've had to super glue and duct tape one back together after I dropped it - they don't bounce.
I've tried using camping gaz lamps and a Tilly paraffin lamp which produce a lot of light, but they also produce too much condensation.
If I'm working on the bike then I'll have my little geny going with some real lights running (need to make a sound box to reduce the noise for that).
The LED's get used when I'm locking the bike up, or don't need that much light - they should be fine for a weights session. If you did get a leisure battery you should be able to link two of those lights up in series, although there are other 12v options for leisure battery use - caravan awning lights etc.
pepperami
PostPosted: 08:25 - 24 Sep 2013    Post subject: Reply with quote
chris-red wrote:
My Dad was a fire alarm.
Shocked
DrDonnyBrago
PostPosted: 09:17 - 24 Sep 2013    Post subject: Reply with quote
I have one of those Rolson things for venturing into the garage at night, quite bright, good enough for finding things and locking up the bike but nowhere near good enough to use whilst lifting weights.
Do you have space for a deep cycle battery, solar panel and that 12v LED strip light tape (gayBay or Amazon)?
Paris2
PostPosted: 11:44 - 24 Sep 2013    Post subject: Reply with quote
No real chance of solar or any decent sized battery unfortunately.
Is LED the wrong way to go in terms of decent overall light distribution? Shall I look for some conventional lights?
map
Mr Calendar
PostPosted: 12:36 - 24 Sep 2013    Post subject: Reply with quote
Generator?
The ones from the likes of Aldi / Lidl (for example) when they come along are only about £60. So you should be able to get similar for the same or less.
PostPosted: 12:51 - 24 Sep 2013    Post subject: Reply with quote
pepperami wrote:
Shocked
Didn't cause us any problems, unless we were cooking bacon.
Paris2
PostPosted: 13:24 - 24 Sep 2013    Post subject: Reply with quote
Just remembered I used to use one of these in my old job, in a remote stockroom where there was no power
https://www.tool-net.co.uk/p-351869/sealey-ml18-36.html?gclid=CI_SydaQ5LkCFUHHtAodpHkAJQ
And it was hella bright Thumbs Up
arry
PostPosted: 13:29 - 24 Sep 2013    Post subject: Reply with quote
map wrote:
Generator?
They're very noisy unfortunately.
Wondering how long a decent 110ah leisure battery would run a fairly significant LED strip light for...
smegballs
PostPosted: 14:18 - 24 Sep 2013    Post subject: Reply with quote
arry wrote:
map wrote:
Generator?
Well for some fag packet calculations.......
A 15W LED strip is a shit load of light.
15W @ 12V = 1.25A
110 AH / 1.25A = 88 hrs
Quite a long time, altho in practice there will some voltage drop as the battery discharges and you wouldnt want to run the battery right down to empty as that of course damages it (altho not to the same extent as a normal "cranking" battery). So the figure is going to be on the high side of reality. Either way I'd easily expect 48hrs ie 2 days of solid light without a problem....
I met some people at a festival and their van was kitted out with some of the LED strips. About 3W of light was more than enough all under the awning over the table etc. So 15W of led strip will be loads and loads. They even come pre-wired with resistors for 12V so all you need to do is attach some leads and put straight on a 12V battery.
The last post was made 13 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 93.36 Kb
