| oldpink |
 oldpink World Chat Champion
 Posted: 23:47 - 25 Sep 2013 Post subject: ever had an idea that you can't get out of your head |
even though you know its almost impossible to do
but you keep going over and over it
recently I listened to a radio play set to music (dark side of the moon)
that had a visual aspect on the web page using CGI animation
when I thought why can't you use lasers to create
a 3d environment to control light and create geometric or even more complex shapes and images
pretty much like a quadrophonic sound allows you move certain sounds around a room but leave
others in a 2D state (yes I'm a big floyd fan)
I already use several lasers and control them by laptop to create 2D effects and shapes
but these rely on the lasers passing through smoke to make them visible
but I can create complex 2D waves and shapes like tunnels or revolving prism's
or even text and graphics that project onto the walls
my initial thought was to use 8 lasers (one in each corner of the room)
focused to a single central point then use a modified version of the software I have to create a 3 dimensional
map of the room and then use the lasers to project beams to intersect to create a 3D image
but I realised quickly that for quad sound you are moving molecules of air
to do the same with light you need to manipulate photon's and stop a light beam dead in its tracks
which is where my idea hits the rocks of known science
but I keep thinking about ways to do this using other medium (like the smoke to create the 2D effects)
again there is an issue, to get enough density in the smoke to get it to work the audience would suffocate
or drown as the smoke is water based and would vaporise the whole room to about 100% humidity
as then I wouldn't need to manipulate photons there is enough partials for the light to interact with
suppose I could always make the audience wear respirators LOL
anyone else have out of the box idea's that they can't stop pondering
or should I cut back on the weed  ____________________ I have become comfortably numb
Theory & hazard 24-may 2016, CBT 8th June 2016, MOD 1 2nd Aug 2016 Mod 2 2nd-Nov 2016 - Current bike CBR 600 RR |
| prawny1 |
 prawny1 World Chat Champion
| el_oso |
 el_oso World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| tbourner |
 tbourner World Chat Champion
| Spudly |
 Spudly World Chat Champion
 Posted: 22:33 - 26 Sep 2013 Post subject: |
Different concept than the one tbourner linked to, but it is in fact possible to adjust the "speed" of light. Light only travels at 186,686 mps in a vacuum. That's the constant. It can be brought down to walking pace or even slower by passing it through different substances.
https://cerncourier.com/cws/article/cern/28403 ____________________ The Old Apprentice |
| krarkol |
 krarkol World Chat Champion
 Posted: 01:57 - 27 Sep 2013 Post subject: |
If you mean like a hologram as such, but made from lasers. I think the only way to get it to work would be if you had say a big black box/pillar in the middle of the room. That way it would stop the light the way you want it
I think the only way to actually stop the light in theory would be to find a sort of optimum watts to wavelength ratio? So the lights still visible but not strong enough to actually make it across the room... ____________________ Bandit 600 - deaded |
| G |
 G The Voice of Reason
 Posted: 22:29 - 27 Sep 2013 Post subject: Re: ever had an idea that you can't get out of your head |
There are a few things out there doing similar.
If you could create a really good solution you'd make millions and be doing better than some that no doubt have many millions invested in it.
I think the water-fountain solution is quite an eloquent one.
https://www.youtube.com/watch?v=anANEPt_a4E |
| oldpink |
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
