Best practise for coasting on a carb'ed bike
maxp
PostPosted: 09:36 - 26 Sep 2013    Post subject: Best practise for coasting on a carb'ed bike Reply with quote
Hi guys,
On my fuel injected car, when rolling down a hill, as long as I leave it in gear (and the revs are above 1200), the fuel injectors are closed, meaning the car is effectively doing infinite miles per gallon.
In terms of fuel economy on my carburetor fueled motorbike is it more economical to coast with the clutch depressed or the clutch engaged?
As far as I understand it (but am fully prepared to be wrong!), the pilot air circuit is always open, so a small amount of fuel will always be consumed, but (although the difference may be minor) is it more economical to coast clutch in or out in this scenario?
esullivan
PostPosted: 10:08 - 26 Sep 2013    Post subject: Reply with quote
I hate word problems. The trains meet in Liverpool in 2.5 hours, travelling 66.7mph. That's my standard answer.
I don't think your car is doing infinite miles per gallon, though.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
PostPosted: 10:11 - 26 Sep 2013    Post subject: Reply with quote
Don't do it. If you're tight fisted enough to try to coast on a motorcycle then A) You've got a problem and B) You'll end up damaging it trying to ride it like that.
Wobbling Dog
PostPosted: 10:47 - 26 Sep 2013    Post subject: Reply with quote
fuel tap ?
PostPosted: 11:17 - 26 Sep 2013    Post subject: Reply with quote
With the engine running, having the clutch pulled will mean less vacuum in the carb and so probably less fuel drawn in along with less engine braking compared to having the clutch released.
With the engine no running having the clutch pulled will mean zero fuel drawn in (but will likely wear the clutch thrust bearing), while having the clutch out will still mean fuel drawn through and likely a very loud backfire when the engine starts again.
guile
PostPosted: 11:25 - 26 Sep 2013    Post subject: Reply with quote
_Iain_ wrote:
Trying to coast it clutch out is going to give significant engine braking & slow you down to a standstill very very quickly.|
I have an FI bike and I coast all the time up to traffic lights in the city. I don't get significant engine breaking when doing it. I can't see how I would be damaging the bike but these comments have me worried.
PostPosted: 11:36 - 26 Sep 2013    Post subject: Reply with quote
Engine braking will depend on the gear you are in. Higher gear means less engine braking but there will still be some.
PostPosted: 12:09 - 26 Sep 2013    Post subject: Reply with quote
You won't get engine braking when coasting... you remove the link by coasting, what slows you down is resistance and friction, loss of momentum init.
With the clutch out, you'll stop feeding the engine fuel so it will slow down, on an FI bike that is. That will have engine braking.
map
Mr Calendar
PostPosted: 13:25 - 26 Sep 2013    Post subject: Re: Best practise for coasting on a carb'ed bike Reply with quote
maxp wrote:
...As far as I understand it (but am fully prepared to be wrong!), the pilot air circuit is always open, so a small amount of fuel will always be consumed, but (although the difference may be minor) is it more economical to coast clutch in or out in this scenario?
The pilot jet is always fed. It depends on the throttle position and the venturi effect to control fuel to the main jet.
So close the throttle and it should be pilot jet only (if not you need to fix it).
I would not engage the clutch unless I have to. Then again I dislike really hard breaking as well. As said engine breaking works. Keep it smooth and flowing.
I don't even like sitting at traffic lights with the clutch lever pulled in if I know it'll be more than a few moments wait. Possibly because of the stories about the old bikes and the clutch being rather fragile. I see no reason to ride a clutch. Apart from when needing to go slowly (like your CBT and turn in the road, constant throttle and clutch feathering) I see it as more of a switch.
pits
PostPosted: 13:33 - 26 Sep 2013    Post subject: Re: Best practise for coasting on a carb'ed bike Reply with quote
maxp wrote:
Hi guys,
I am a pikey
keggyhander
PostPosted: 16:50 - 26 Sep 2013    Post subject: Reply with quote
Don't coast downhill with the clutch in unless you fancy losing the front end when you have to brake sharply at the bottom of the hill.
Cheeseybeaner
PostPosted: 18:48 - 26 Sep 2013    Post subject: Re: Best practise for coasting on a carb'ed bike Reply with quote
maxp wrote:
Hi guys,
Sounds dangerous and pointless. You should be using the throttle and gears to match and control the rolling speed of the bike not trying to avoid them worrying about a negligible difference in fuel economy. A better approach would be to accelerate more gradually, keep to speed limits religiously and short shift, turn engine off at traffic lights - the difference all this will make to your fuel consumption can be quite startling. If you spend a lot of time trying to 'coast' then you won't be in full control of the bike and able to react to whatever is on the road.
My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S
Irn-Bru
PostPosted: 18:51 - 26 Sep 2013    Post subject: Reply with quote
Petrol isn't so expensive that it's worth increasing your chances of a crash for. If you coast down a hill you have much less control with no engine braking and if you read the manual of any bike it always tell you to never do it.
The last post was made 13 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 102.95 Kb
