| Bikercem |
 Bikercem Borekit Bruiser
 Posted: 14:01 - 28 Sep 2013 Post subject: Low idle, Misfire. YBR125 06 |
Hey, got an issue with my Idle, It should ideally be at 1k or close to it, I'm having to set it at 1.7 because at 1k it just misfires and cuts out most of the time.
Also it misfires at 1.7 ish aswell and just sounds unhealthy.
I've driven the same model and it sounds and acts so much more smoothly then mine.
And I've also driven a GS500 which runs at 1k fine.
Here is what I have adjusted to try and fix my idle problem apart from one thing which I am in the midst of doing. (Air filter)
Exhaust valve set to factory, and the fuel mixture screw adjusted to factory standard, the idle screw adjusted to the problem.
New exhaust(Stock) (Not adjusted to the problem, the one I got with it had holes in it...)
The one thing I haven't changed is the air filter, now it still has the original in there, I've ordered a new one because I'm stuck to think what else might be causing this issue, but any advice on other possible problems could help me a lot, thanks (Air filter should arrive by Monday and I will let you guys know if it helps).
Cheers. |
| Nemo |
 Nemo Could Be A Chat Bot
| CG Sam |
 CG Sam Crazy Courier
| cb1rocket |
 cb1rocket World Chat Champion
| Bikercem |
| Bikercem |
| moonzoomer |
 moonzoomer World Chat Champion
 Posted: 13:44 - 29 Sep 2013 Post subject: |
| solemnwarning |
 solemnwarning Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| Bikercem |
| Bikercem |
 Posted: 18:46 - 24 Oct 2013 Post subject: |
I've set my fuel mixture to 2.75 turns out and it starts every time now, and idles like a beauty!
Thanks for the advice guys! |
The last post was made 12 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
