What gloves to buy for winter ?
flat eric
PostPosted: 20:21 - 29 Sep 2013    Post subject: What gloves to buy for winter ? Reply with quote
Hi,
I've got £80 - £100 to spend on some decent winter gloves.
probably buy them from the bike show this year, as hoping to get a discount while the show is on.
Can anyone suggest a glove I check out ?
I've been looking at some Alpinestars Jet road Gore-Tex.
There is always someone worse off than you !
Andy_Pagin
PostPosted: 20:25 - 29 Sep 2013    Post subject: Reply with quote
Spend your money on Tucano Urbano muffs instead, much more effective than any winter gloves.
flat eric
PostPosted: 20:40 - 29 Sep 2013    Post subject: Reply with quote
Good suggestion.
Something to think about.
PostPosted: 20:46 - 29 Sep 2013    Post subject: Reply with quote
Another vote for those muffs.
Get muffs first, then consider next move - be it heated grips or gloves.
PostPosted: 20:49 - 29 Sep 2013    Post subject: Reply with quote
I've already got mine fitted.
You're welcome for the hot weather. Wink
ukdiceman
PostPosted: 21:36 - 29 Sep 2013    Post subject: Re: What gloves to buy for winter ? Reply with quote
flat eric wrote:
Hi,
https://www.visordown.com/product-features/tested-sub-100-all-weather-gloves/21734-12.html
FZ6 Fazer
FretGrinder
PostPosted: 21:52 - 29 Sep 2013    Post subject: Reply with quote
Another vote here for the muffs.
Good winter gloves can be OK for a while, but the tips of your fingers will become cold in no time, even with heated grips.
What you need is a pair of the aforementioned Urbano Tucano muffs, your hands WILL stay toasty warm in even the coldest of our crappy British winters.
Have a good search on the forum and you will find plenty of threads on muffs and how people are recommending them.
HTH Thumbs Up
Yamaha MT-09
ಠ_ಠ
DrDonnyBrago
PostPosted: 10:52 - 30 Sep 2013    Post subject: Reply with quote
+1 muffs.
WetAndCold
PostPosted: 10:58 - 30 Sep 2013    Post subject: Reply with quote
And if you're as good looking as me you don't have to pay for muff. Wink
Honda CBR600f sport
Cage: 2008 Honda Civic type-R
flat eric
PostPosted: 11:29 - 30 Sep 2013    Post subject: Reply with quote
Cheers guys. Looks like muffs are the way to go. Wink
PostPosted: 11:50 - 30 Sep 2013    Post subject: Reply with quote
And they definately don't pull your brake/clutch on?
Even at mumble mumble miles per hour?
Any muffs I've tried in the past have promised not to do this and entirely failed to deliver on that promise when put to the test.
PostPosted: 13:55 - 30 Sep 2013    Post subject: Reply with quote
The time I have had it pushing on the clutch etc is on a sports bike with me sitting up too much so the muffs angled down.
They didn't push against, but did make it harder to get your hand on the levers.
This was, on the autobahn, of course, approaching twice the limit which we would have in the UK.
They mount on your bar ends and are pretty stiff, so can't push back.
You are supposed to cable tie them on, but I never bother - they do pop of some times, but I like being able to take them off/put them on in 20 seconds if desired.
On my ZX9 I made a bracket to stop normal muffs doing this and it worked fine - I used a bit of old shelving but proper dirt bike guards work even better.
PostPosted: 13:57 - 30 Sep 2013    Post subject: Reply with quote
I've not done 170 with them on... honest. Nothing sketchy at all from the Tucanos.
PostPosted: 14:39 - 30 Sep 2013    Post subject: Reply with quote
Can't speak to the Tucanos, but my home made ones are fine up to private road speeds.
If you're putting them over bar ends then I'd imagine you could simply find a piece of thin flat metal or stiff plastic the same length as the muff, drill a hole in it for the bar end bolt, and use it as a stiffener.
-Matt-
PostPosted: 15:58 - 30 Sep 2013    Post subject: Reply with quote
Never used muffs, but as a good addition in either case i'd give a big thumbs up for spada enforcers.
Going by my normal sizing i can get a pair of thinsulate thermal ski gloves inside them also which have kept me warm in sub 0's for rides upto a couple of hours fairly well Thumbs Up
IIRC about 50 pound and that was a while back so well within budget, maybe even along with the muffs
PostPosted: 17:12 - 30 Sep 2013    Post subject: Reply with quote
They've got a nice aerodynamic taper, and upto 140 I haven't heard the swish noise from the pads. Infact, I don't think it'd reach 140 if the lever was lightly pressed.
As with most things it pays to try before you buy. See if you can loan a pair, the air flow off your fairing may direct more wind onto the muffs.
matlow
PostPosted: 15:39 - 02 Oct 2013    Post subject: Reply with quote
I've just ordered a set of these on the recommend of this thread. cheers all!
Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s
Serendipity
PostPosted: 19:40 - 02 Oct 2013    Post subject: Reply with quote
Ooo, I like to post in the annual muff thread.
I used the old Oxford style muffs for years. They were a bit crap and pushed back on the levers just like Stinkwheel suggested, but I still used them because they were far more effective than the best winter gloves.
Roll on to winter 2010 and I heard about Tucano Urbano muffs at exactly the right time, just as I started a new job with a longer motorway commute. I didn’t know it, but they turned out to exactly what I needed. How serendipitous eh?
I got a pair of the neoprene ones and fitted them to my CB500. They were so good I bought a second pair to use on my CBR600 to save swapping them around. I moved that pair to my CBF1000 once I bought that and took them straight to Scotland to keep my hands dry on the wettest tour... ....EVER!
I’ve not yet been able to make them push back on the levers despite occasionally touching whispermph on private roads.
I do tend to cable tie them on. I find it distracting when they come loose on the motorway and flap around so I also cable tie the rubber sleeve that slips over the bar end. That stops it falling off.
They saved my fingers through winter 2010 and 2011. I used the same pair of summer gloves throughout. Then for winter 2012 (which extended well into 2013 if you remember) I also fitted heated grips.
Very nice. Highly recommended combo. Thumbs Up
Using muffs is a little bit of a compromise. I won’t deny that riding the bike without them is much nicer, but that sort of give me something to look forward to when spring arrives. It’s very much like that first ride when you put your summer gloves back on after using winter mitts. It’s amazing how much feel and control you have over the bike.
What are they these days? Just under £40? That’s a bargain for what they provide. And they really don’t turn you gay, at least that’s what my girlfriend Brian tells me. Wink
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
The last post was made 12 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 106.24 Kb
