CG 125 Speed
Commuter_Tim
PostPosted: 12:38 - 30 Sep 2013    Post subject: CG 125 Speed Reply with quote
I was just wondering, any CG owners, past and present, what sort of top end speed should I expect out of the CG's wee little engine?
I don't expect too much out of it really, my trip to work takes about 15 minutes, and it seems fairly nippy from 0-30, but my old crappy Yamaha Scooter had no trouble hitting 65-70 on the flat, however my CG has trouble getting over about 45-50, and the top 2 gears don't seem to do much of anything even at full throttle.
Possible relevant details...
I'm 6 foot 3
13 stone
It's not really windy at the time its been struggling.
its a '98 W model
The engine has had issues with juddering here and there even at low speed when trying to accelerate quickly and whacking on the throttle, but I generally attributed that to a cold engine? (When I bought it a year ago it had been sitting in a garage for some time by the looks of it)
I ride a Bandit 600... badly.
Kai.Wilson
PostPosted: 13:00 - 30 Sep 2013    Post subject: Reply with quote
about 60mph
I has a 1988 cg
Mark65
PostPosted: 14:37 - 30 Sep 2013    Post subject: Reply with quote
I'm 5-10 and more than 13 stone Shocked , my 07 has been to 67 indicated once (prolly 62 really)but gets scary then lol.
Mark
CG Sam
PostPosted: 15:23 - 30 Sep 2013    Post subject: Reply with quote
I'm about 15 stone and 5 10, mine sits and 55/60 all day, I've had an indicated 75 (long flat run along to a fairly long hill and revving the hell out of it in each gear) but I wouldn't expect it to do that.
Have you opened your carb up? Could have partially blocked jets, that or it's running a little lean.
CG125, SV650S, CBR600F, GSXR600 SRAD
Commuter_Tim
PostPosted: 18:46 - 30 Sep 2013    Post subject: Reply with quote
I can't say i'm technically capable of doing anything like that, you could be on to something there though, when I mentioned the juddering to someone at work that's the first thing they said it could be.
Is checking out/clearing carbs an expensive job do you know?
Cheers for the help BTW
EDIT: Oh also I take it running lean implies that there isn't enough fuel getting to the engine? is that something that can be tweaked by a spanner wielding moron such as myself? Very Happy
mudcow007
PostPosted: 19:16 - 30 Sep 2013    Post subject: Reply with quote
mine hit 60 once.....that was on the east lancs, if any knows it..basically a long straight road
5th gear lowered the revs & speed, just left it in 4th an went for gold
would happily plod along at 50 though
CG Sam
PostPosted: 10:39 - 01 Oct 2013    Post subject: Reply with quote
All pretty simple jobs even with very little knowledge. The mixture can be adjusted quite easily, but it's trial and error. Standard setting may not be right for your bike, it depends on altitude etc.
If you remove your spark plug you can tell by the colouring of it if it's running lean or rich.
Do you have a Haynes manual? I know some people don't really rate them, but for things like this it's really useful, The carb is simple and I found it really interesting the first time I opened one up.
stevo as b4
PostPosted: 10:55 - 01 Oct 2013    Post subject: Reply with quote
Mine did 60mph indicated everywhere on the flat, and 65mph with a slight downhill or tailwind. It would also hold 50-55mph in top gear on most long slight inclines like motorways etc.
0-30mph is good enough to beat most average cars from the lights, but even a say a Focus 1.6 would come past by the time you got to 45-50mph assuming both vehicles were driven hard.
I never got more than 83mpg out of mine, but that's good enough to not even care IMO.
Mark65
PostPosted: 12:50 - 01 Oct 2013    Post subject: Reply with quote
Currently getting near enough 120mpg on mine, ridden nicely Very Happy
DMCpro
PostPosted: 13:05 - 01 Oct 2013    Post subject: Reply with quote
Where abouts are you? Sounds like the carb needs cleaning and setting up
Honda CB-1, TS125X
VW Golf Estate
Commuter_Tim
PostPosted: 18:40 - 01 Oct 2013    Post subject: Reply with quote
I do indeed have a Haynes manual, not that I understand most of it.
I thought about what you said with it running lean, so left the choke half on coming back from work, and 0-30 it definitely seemed a lot nippier, so think you're spot on with that one, thanks again!
Once I got above 30 it was still struggling a bit still at full throttle, so here's hoping you're right about the carbs too Smile
I'm up in Newcastle, I'm debating putting it in for a full service at the place close to me, How much do you think that should run me? (Don't wanna get fleeced)
I haven't had one done in the 6 or so months I've had the thing so couldn't hurt.
CG Sam
PostPosted: 18:58 - 01 Oct 2013    Post subject: Reply with quote
I don't have any idea how much a service would be, but if you take it for one see if they'll let you watch and talk you through it so you know what to do next time
SteveZZR
PostPosted: 00:14 - 02 Oct 2013    Post subject: Reply with quote
My 1990 with a blowing like fook exhaust and a leaky base gasket (and 43,000 miles under it's belt) has managed an indicated 80mph down a big hill with all 6"5 and 15 stone of me, sat upright on it.
Will pull quite rapidly to about indicated 65mph on flat and do about 55 up a hill
MattJ
PostPosted: 00:20 - 02 Oct 2013    Post subject: Reply with quote
Did indicated 73 on mine once, thought I was going to die.
DMCpro
PostPosted: 06:44 - 02 Oct 2013    Post subject: Reply with quote
Hi there a full service will probably be between 80-150 labour budget more for a main dealer.
Honda CB-1, TS125X
VW Golf Estate
Commuter_Tim
PostPosted: 17:35 - 02 Oct 2013    Post subject: Reply with quote
Good thinking CG Sam, will see what they say.
Judging by the speeds you lot have been reaching, mine definitely needs a service of some kind then.
Thanks for all the helpful replies, I would buy you all a pint but I don't think I could make it to you on the dual carriageways with a top speed of 45... so Karma all round Very Happy
numpty2
PostPosted: 21:22 - 02 Oct 2013    Post subject: Reply with quote
On my old CG I managed 60mph, but then I bottled it due to the drum front brake. It also felt really cruel, like when you see images of some fat bloke in a foreign country riding a small donkey side-saddle whilst hitting it with stick. I loved my CG.
bladerunner
PostPosted: 22:22 - 02 Oct 2013    Post subject: Reply with quote
Should be quite capable of 65+ mph with a rider your size. You do have to rev them hard in every gear to get a good top speed tho!
SteveZZR
PostPosted: 01:18 - 03 Oct 2013    Post subject: Reply with quote
I love.my cg too.
But its rusty, especially on the petrol tank, which makes it ginger so the only love it gets is tough love.
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 100.16 Kb
