Rev Counter
squiresy123
PostPosted: 09:23 - 01 Oct 2013    Post subject: Rev Counter Reply with quote
Hello, I am in my last year of college and I am designing a digital, universal rev counter as my final product for my electronics subject. I was curious to hear what a big motorbike community thinks about this and if you have any pointers for doing this. Also if you have any suggestions about any extras that could be added on to it such as battery voltage indicators, that would be much appreciated.
Radis
PostPosted: 09:32 - 01 Oct 2013    Post subject: Reply with quote
My god, it's that time of year again.....
trevor saxe-coburg-gotha
PostPosted: 09:34 - 01 Oct 2013    Post subject: Reply with quote
[img]https://www.irrigationtutorials.com/faq/images/repair-valve-08.jpg
cimbian
PostPosted: 10:08 - 01 Oct 2013    Post subject: Reply with quote
You are probably going to get slated for this question, but as a serious suggestion I would look at an engine hours counter as used on aircraft and boats.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
PostPosted: 10:14 - 01 Oct 2013    Post subject: Reply with quote
You need to count pulses down the HT leads in order to indicate a correct RPM. Google/look on demon tweeks for universal tachos/rev counters to see how they work.
Craig321
PostPosted: 10:39 - 01 Oct 2013    Post subject: Reply with quote
Digital Sad
Sounds like a cool project though, wish we had done stuff like that in college.
I guess one pretty cool extra would be something showing what gear you're in and what gear the system suggests or is that going too far?
Sept 2012 - Current: Hornet CB 600 F4 '05
Aug 2011 - Sept 2012: CBF 125 '09
goto10
PostPosted: 11:38 - 01 Oct 2013    Post subject: Reply with quote
Here you go, now go and play some more GTA V.
https://www.quasarelectronics.co.uk/Item/velleman-k2625-digital-tachometer-kit
PostPosted: 11:44 - 01 Oct 2013    Post subject: Reply with quote
A bit of searching and you would have found that a digital tacho isn't as popular as analogue :-
https://www.bikechatforums.com/viewtopic.php?t=273314
James83
PostPosted: 11:52 - 01 Oct 2013    Post subject: Reply with quote
One thing I notice is that all aftermarket rev counters I've seen are pre set on the scale they use, usually 10, 15, or 20k. If you can find a way to make the scale adjustable to any number, that would be unique. If your going for an LCD output, that would be fairly simple to do as well.
stevo as b4
PostPosted: 12:58 - 01 Oct 2013    Post subject: Reply with quote
Not very into the thrash it hard spirit of biking but I'd like to see a bike tacho with the little green up and down arrows like they have on car's trying to tell you when they think you should be changing up or down. Laughing
More useful things on modern sky high revving sports bikes would be a red zone that gradually increases as the oil temp comes up, and or an oil temp readout.
For a laugh you could also have a green zone on the tacho like on HGV's for maximising fuel efficiency, or a girly pink zone at low revs, and a text lit up that says 'You is da man!' near the rev limit/shift light zone. Wink
PostPosted: 13:14 - 01 Oct 2013    Post subject: Reply with quote
https://static.fjcdn.com/pictures/speedometer_03aa04_3031222.jpg
anthony_r6
PostPosted: 13:25 - 01 Oct 2013    Post subject: Reply with quote
My KOSO clocks are adjustable on the rev limit. So it goes to 12k 15k and possibly 18k? (I know there's 3 options)
cimbian
PostPosted: 14:24 - 01 Oct 2013    Post subject: Reply with quote
My 2006 Guzzi has a settable threshold for a red LED to advise of up-changes. Standard feature.
22PlusY
PostPosted: 14:42 - 01 Oct 2013    Post subject: Reply with quote
There is a rule on this forum (albeit unwritten) that we don't do your homework for you.
Peirre oBollox
PostPosted: 14:49 - 01 Oct 2013    Post subject: Reply with quote
cimbian wrote:
You are definitely going to get slated for this question.
FTFY
+1
PostPosted: 14:50 - 01 Oct 2013    Post subject: Re: Rev Counter Reply with quote
I think that if I was the sort of biker who was interested in revs, I'd buy a bike with a rev counter already fitted. Only the most pov spec machines don't have them these days anyway, and you're unlikely to make a living selling to people who buy such bikes.
OK, I'll try to find one constructive thing to say. Don't show numbers, they'll change too fast, show a (configurable) scale, running green -> yellow -> red.
If you must do numbers, at least make them colourful, or have a big, obvious "CHANGE UP, MUPPET!" light, since that's all that really matters.
weasley
PostPosted: 16:39 - 01 Oct 2013    Post subject: Reply with quote
How about, for those bikes with a screen, you use some kind of optical woo-woo to make the trailing edge of the screen (ie the cut or rolled end of the screen at the top, nearest your face) a supplementary rev indicator, using the principle Rogerborg outlined. As the revs rise the edge of the screen lights up, sweeping from left to right with colour change along the way to impress upon the rider the urgency of a gear change.
You retain your numerical rev counter on the dashboard, for pub tales, but the rev indicator is more visible in your peripheral vision as a general impression of where in the rev range you are.
The crude implementation would be to stick a line of LEDs along the top, but a cooler version would use optical transmission up the screen onto a ground or otherwise optically opaqued or translucent edging that made the light visible.
tracks
PostPosted: 19:36 - 01 Oct 2013    Post subject: Reply with quote
Give ReRace some competition and design a wank app that calculates your lean angle. Maybe design an added bonus feature that when you go too far over a big fuck off LED flashes CUNT at you.
Just you.
Wonko The Sane
PostPosted: 20:19 - 01 Oct 2013    Post subject: Reply with quote
the only bikes I can think of that don't have rev counters are 125cc's
125cc's have an on/off switch instead of a throttle.
I like my large dials on my ZZR.
UnspeedySam
PostPosted: 21:46 - 01 Oct 2013    Post subject: Reply with quote
LM3916 chip, LM2917 chip, cheap bargraph, some prototype board, and 10 mins with a soldering iron. Homework done.
1198
PostPosted: 22:16 - 01 Oct 2013    Post subject: Reply with quote
Head up display, into your visor. That'd be a project....
331X2
PostPosted: 22:17 - 01 Oct 2013    Post subject: Reply with quote
I'm doing this but stacking the 3916's to give me a smaller resolution to each LED, expect to see a thread some time in 2018 when I pull my finger out...
The other Paul Rudd
PostPosted: 22:24 - 01 Oct 2013    Post subject: Reply with quote
Mine has been built, and sat in a draw waiting to be fitted, for about a year. Other bikes going bang have halted progress. Crying or Very sad
rac3r
PostPosted: 23:29 - 01 Oct 2013    Post subject: Reply with quote
+1 Cool
Then speed cameras/traffic cops can be targeted in the display Ghost Recon style
Chequered Flag
331X2
PostPosted: 09:49 - 02 Oct 2013    Post subject: Reply with quote
I'll probably be sending you a million questions via PM when I start letting the smoke out of the IC's then! Hoping to team this with an arduino for speed, rpm readout, gear indicator and idiot lights on a 128x64 screen with an arc of smd's around it showing rpm.
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 127.44 Kb
