Derbi GPR Nude
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
SQL
PostPosted: 14:10 - 01 Oct 2013    Post subject: Reply with quote
Head is a little battered but its the best condition 3MB head that has been on ebay for a while that has been cheap, its all getting sent off to be done rebore and tidying the head up too, it should run fine if worse comes to worse 2 metal head gaskets then the rubber one Laughing sorted.
The clearance shouldn't be an issue really.
SQL
PostPosted: 14:25 - 01 Oct 2013    Post subject: Reply with quote
I haven't got a piston yet lol will get one when its being rebuilt. as it will all be done as one unit making if better, the topend is being tuned and fixed, the botton end I am splitting (Phowar) and replacing main bearings etc and changing the conrod.
SQL
PostPosted: 17:21 - 01 Oct 2013    Post subject: Reply with quote
_Iain_ wrote:
PM me when you need one and you know what oversize the cylinders at. Can sort you out a nice forged one Mr. Green Thumbs Up
Might see if I can get it teflon/ceramic coated. its going premix only so that should be a laugh, don't really want to deal with a oil pump if all I am do is riding it for fun.
PostPosted: 17:25 - 01 Oct 2013    Post subject: Reply with quote
Erm... yeah don't remove the pump. If its for fun, just fill the tank and leave it. Not heard of many DT's going pop due to oil pump failure. Thumbs Up
evoboy
PostPosted: 17:49 - 01 Oct 2013    Post subject: Reply with quote
Running premix on the road is fine. But youll need to upjet slightly due to the oil weakening the mix slightly.
You can do damage by using the engine braking while running premix, but its not much different to using engine braking while running the pump. Both wont be feeding enough oil/fuel mix in at high rpm with no throttle input. On mine i normally give it blips of throttle with the clutch pulled in, or, roll with the clutch in instead.
Who uses engine braking on a 2stroke anyway?!
APT Motorcycles
SQL
PostPosted: 18:52 - 01 Oct 2013    Post subject: Reply with quote
As said just toying with idea based purely on weight saving. I may leave the pump on it but I have no idea if it even works yet as when I got the bike it had been seized but when i removed the 2 smoke tank it was half full so it don't add up. mainly why I said premix only as I have a 25 gallon tank that I can use for my premix Laughing
SQL
PostPosted: 21:21 - 01 Oct 2013    Post subject: Reply with quote
I am completely rebuilding the engine anyway.
the 150 tyre seems to be a common thing people do because it has a 4" rim on the back it is standard 110/140.
If I lose interest in doing it ill sell it with the V5 (If it ever comes) and all/most of the bits to get it as a half decent project.
SQL
PostPosted: 22:39 - 15 Mar 2014    Post subject: Reply with quote
Update time!!
Case has been split the crank is perfect so is the big end bearing, the stator side main bearing has a slight rumble but I have mains to go in it.
Gearbox looks good too
Tommorow goes back together and then pics Smile
SQL
PostPosted: 01:17 - 17 Mar 2014    Post subject: Reply with quote
Took the engine apart and the mains were fuggered but I got some new ones and seals
https://i.imgur.com/OHlpXVL.jpg
https://i.imgur.com/miJOktf.jpg
https://i.imgur.com/aiajnHC.jpg
Bigend bearing was perfect no play in it
https://i.imgur.com/PHuDana.jpg
Old mains looking shagged, were very notchy
New mains in and seals in
https://i.imgur.com/q4uDO59.jpg
Nice new seals
https://i.imgur.com/YrH4xRZ.jpg
Powervalve open
https://i.imgur.com/7ZkPxdS.jpg
and shut
https://i.imgur.com/1teL89X.jpg
And a few nice random shots
https://i.imgur.com/kx0X8qD.jpg
https://i.imgur.com/SCuISEH.jpg
https://i.imgur.com/o0kCbIX.jpg
https://i.imgur.com/2TQTJ1A.jpg
https://i.imgur.com/rp3DNzJ.jpg
I really like this photo
https://i.imgur.com/d6Ck9Cn.jpg
https://i.imgur.com/aufLW6w.jpg
Things to do
Sort out the engine covers and polish the PV cover, head studs need to be put in, then bolt everything up tight and put in engine in frame Mr. Green Thumbs Up
Have learnt quite alot about building up the engine too
SQL
PostPosted: 15:23 - 17 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
Did you use loctite when fitting those bits of selector mechanism behind the clutch? I promise you it will cause huge amounts of pain if you diddn't Laughing
Looking good. You need to get this done!! Thumbs Up
Edit, have you used instant gasket to put the cases back together? Shocked
No Loctite used but clutch needs to come off again anyway.
And instant gasket was used on the original cases in clear form I scraped it all off, I have only put a tiny bit on it just a smear much less than original. it only looks bad because I have used red.
SQL
PostPosted: 19:02 - 17 Mar 2014    Post subject: Reply with quote
Also I now need a little end bearing and pin/circlips
Any ideas?
SQL
PostPosted: 20:48 - 17 Mar 2014    Post subject: Reply with quote
I can't find them seperate cheap, I have a piston matched to the 3mb00 topend just need new circlips and small end and preferbably gudgeon pin.
SQL
PostPosted: 21:22 - 17 Mar 2014    Post subject: Reply with quote
I bought a complete barrel with piston but I lost the circlips like a tard and the littleend just needs replacing
evoboy
PostPosted: 00:13 - 18 Mar 2014    Post subject: Reply with quote
Is it a 2nd hand top end kit?
If it is, I would advise buying a new piston kit and honing the barrel before putting it back together with a new small end bearing.
I seem to do this with almost every 2 stroke I buy. Gives me piece of mind. Still ride around with 2 fingers on the clutch lever though! Laughing
APT Motorcycles
lukamon
PostPosted: 01:01 - 18 Mar 2014    Post subject: Reply with quote
possibly stupid question; why are 2 stroke mains always exposed crankshaft side? wouldn't they last longer in the gearbox side, staying oiled? or even a sealed greased bearing?
killa wrote: Im an ass man myself
SQL
PostPosted: 11:11 - 18 Mar 2014    Post subject: Reply with quote
2 stroke main bearings are oiled with the petrol
https://upload.wikimedia.org/wikipedia/commons/3/31/2-Stroke_Engine_ani.gif
The last post was made 12 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 144.38 Kb
