Cost of a non-running engine?
James83
PostPosted: 13:16 - 02 Oct 2013    Post subject: Cost of a non-running engine? Reply with quote
In a bid to get better at spanner twirling, I've been thinking about buying a cheap non-running engine, striping it down and rebuilding it, learning how to do it as I go. I don't expect the engine to be working when I'm finished, this is really just to get some experience in stripping an engine as I've never done it before. As such, I don't want to spend serious monies as it may well go in the bin afterwards.
So, how much, realistically, should I be looking at for a basic, 'all parts present, but not necessarily running' 50/125cc engine? I had a poke about on ebay and I'm mostly turning up classics which are in the hundreds of pounds.
Sam_Y_93
PostPosted: 13:27 - 02 Oct 2013    Post subject: Reply with quote
Had you have posted this last week I would've been able to help, I've just sold a non running vfr400 engine for £50
J.M.
PostPosted: 13:55 - 02 Oct 2013    Post subject: Reply with quote
Don't limit yourself to a 50/125cc engine. A GS500 engine is very simple to work on for example, but they can be a little pricey to buy. But don't limit yourself to any specific engine... just buy anything common such as an inline twin or an inline four.
I'd recommend buying an engine that's in 1 piece rather than already disassembled, so that you can see how things are as you remove them.
You'll also need to grab some tools when working on a 4 stroke engine. Whilst not absolutely essential, there's a large clamp type tool (that I can't remember the name of) which is useful for compressing the valve springs to remove the collets.
2004 R1 & 2018 XSR900
James83
PostPosted: 13:59 - 02 Oct 2013    Post subject: Reply with quote
Cheers guys.
I mention 50/125s simply on the assumption that they are cheaper. If I find a larger engine is cheapest, I'll be grabbing that.
re tools - part of the reason for doing this is to see where my tool kit is lacking, so anything like that will be picked up as needed.
Found a 125 monkeybike engine with gearbox issues for £40 delivered. Will keep looking, but that's the best I've found so far.
map
Mr Calendar
PostPosted: 14:04 - 02 Oct 2013    Post subject: Reply with quote
J.M. wrote:
...a large clamp type tool (that I can't remember the name of) which is useful for compressing the valve springs to remove the collets.
So that'd be a valve spring compressor then, aka valve spring removal tool. At least that's what I've always heard/called them (as in here).
Although if you go into any decent auto tool supplier/factor and ask for the doobrey that presses the whatsits* so you can take them out they'll get what you need no problems Wink Very Happy
* Try not to confuse whatsits with thingies or you might get the wrong part.
J.M.
PostPosted: 14:13 - 02 Oct 2013    Post subject: Reply with quote
That'll be the thing!
There's loads on there, here's just a few I quickly found:
https://www.ebay.co.uk/itm/Honda-Cb500-Engine-Cb-500-Twin-/261295357308?pt=UK_Motorcycle_Parts_13&hash=item3cd66abd7c
https://www.ebay.co.uk/itm/cbr600-engine-/221289163265?pt=UK_Motorcycle_Parts_13&hash=item3385dcaa01
https://www.ebay.co.uk/itm/Kawasaki-ER5-ER500-engine-/131000218051?pt=UK_Motorcycle_Parts_13&hash=item1e8038b1c3
https://www.ebay.co.uk/itm/yamaha-division-600-engine-/321218482490?pt=UK_Motorcycle_Parts_13&hash=item4aca1d113a
331X2
PostPosted: 15:08 - 02 Oct 2013    Post subject: Reply with quote
I wouldn't bother with a pit bike engine as they're a bit simple. Get a twin or four if possible, download a workshop manual and then strip and rebuild it using correct tolerances and torque settings. You'll learn a lot more that way than stripping something then binning it.
331X2
Wonko The Sane
PostPosted: 19:25 - 02 Oct 2013    Post subject: Reply with quote
I've got a ZZR 600 engine that's had an overhaul and re-build that's going spare for £120
probably more than you were looking to spend tho.
is it worth buying an old, worn bike that needs some tlc and re-building it, that way, if you do it right, you've something fun / to sell at the end of it?
James83
PostPosted: 09:01 - 03 Oct 2013    Post subject: Reply with quote
Thanks, but £120 is a bit more than I'd want to spend. Plus, it would be a shame if I fucked up an engine that had just been overhauled.
I've considered buying an old bike as a project, but I'm aware that it will cost more to do than I can then sell it for, which means buying a bike that I would want to keep after I'm done, renting a trailer to get it home etc etc. If I can find something really pretty for a really good price, I might consider it.
The last post was made 13 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 71.71 Kb
