| map |
 map Mr Calendar
 Posted: 15:51 - 02 Oct 2013 Post subject: Transit Motorcycles York - Avoid! Avoid! Avoid! |
A word of caution to anyone contemplating getting any mechanical work done, or even buying a bike from Transit Motorcycles in York.
Apology for Teflon-Mike style post, please bear with me, skip to bottom for TL;DR version...
Last year my daughter took her Vespa LX50 to TRansit Motorcycles in York because the rear brakes needed some work. Also the adjustment was seized. Given that Transit are the local Piaggio dealers and so IMO should be expected to be experts with these machines. They took it apart, told her a nut on the inside needed tightening and they put it back together. She took it elsewhere for MOT (her right, her choice, more convenient, etc.) and it passed.
Roll forward a year and MOT time again so looked at rear brakes again and needed adjustment (adjuster still seized btw). I could not get rear wheel off (see this thread).
Took bike to local(ish) mechanic who I trust doesn't make up bull and add extra costs/excuses. Over the 'phone he tells me rear wheel nut was on solid. Four guys and breaker bar with scaffold pole couldn't shift it. Drilled off and so might have damaged shaft (will try to make good). Needs new bolt and washer. Washer was missing! Also ordered new brake cable because of adjuster issue.
So I 'phoned Transit.
I explained the issue and asked what they were prepared to do about it. Thinking if shaft damage it's going cost me lots of money because of some numpty overenthusiastic with air ratchet and forgetful of fitting a washer. Guy on 'phone went away for a good while and then came back to phone. Conversation then went along the lines of...
Transit: I can't see how it can be too tight. It has to be on to align with hole for split pin*.
Me; Should there be a washer on there?
Transit: I think so.
Me: Well there wasn't.
Transit: So you've been told.
Me: I trust the guy telling me this. He has no reason to make it up.
Transit: Well if you'd brought the bike back to us we could have done something.
Me: Bike taken to somewhere closer and more convenient.
Transit: If you'd brought it back here we'd have looked at it.
Me: So you're washing your hands of it. Not going to do anything.
Transit: Basically, yes.
The guy on the phone did state it's been a year. So what? There has been no reason to check the bike since so apart from a fade in the rear brake (as you'd expect) no issues with rear wheel to investigate.
I was also asked what my job was. Totally irrelevant. I did lose it here a little and said supposing I'm a solicitor who could sue your ass off. The reply was "Then do your worst".
Guy on phone refused to give me his name. Refused to give me name of any owner/contact.
I'm not a happy bunny. Was I naive in expecting good customer service after a year?
TL;DR version: Transit Motorcycles in York messed up on a simple job of replacing rear wheel on Piaggio scooter (that they're dealers for) and are washing their hands of it. Doing nothing to make good. So I'd strongly recommend boycotting them as can't be trusted.
* this is partly true. There is a hole in the shaft for a split pin. You're supposed to put on the washer, then the nut and tighten. Then you put on a protective cover type thing and this held in place by split pin. Asin this thread (for ET4 but same as LX) and this illustration. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| chris-red |
| supZ |
 supZ World Chat Champion
| matto |
 matto Crazy Courier
| map |
 map Mr Calendar
| J4mes |
 J4mes World Chat Champion
| evoboy |
 evoboy World Chat Champion
 Posted: 16:44 - 02 Oct 2013 Post subject: |
It's a bit much IMO to ask for anything from them after a year.
But, they could of handled it better by offering to take the bike in to look at it.
I cant imagine it would be that difficult to take the rear wheel nut off mind. If it was done up with an impact gun, it can be undone by one. ( not that you should really be doing things up with Impact guns, air or battery powered.) ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Nick 50 |
 Nick 50 World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| MarJay |
 MarJay But it's British!
| matto |
 matto Crazy Courier
| Polarbear |
 Polarbear Super Spammer
| -Matt- |
 -Matt- World Chat Champion
 Posted: 16:53 - 02 Oct 2013 Post subject: |
I can kind of see why they'd refuse to do anything in the current position to be honest, as it is just 'a bloke from a year ago' saying 'take my word for it - it was missing it and you are to blame'. On that sort of basis they could get harrassed for so many things that aren't actually their fault, and they did say if you'd brought it back to them they'd of done something.
However it does sound like they did a total botch job, and also theres no guarantee they would of actually done anything had you brought it back, or even not tryed to charge you for a further botch, so it does indeed sound like somewhere to avoid if its all as you say  |
| map |
 map Mr Calendar
| evoboy |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:05 - 02 Oct 2013 Post subject: |
My take away point isn't so much their attitude as that they stuffed it up in the first place. Fakking ped, innit, just nip it up tight then on to the next job.
It might be easier to come up with a list of main dealers who aren't lazy, incompetent bodgers, mind.
| map wrote: | As it is their mistake is going to end up costing me money. Lucky that's for bike bits and not flowers for a grave. |
I'd find it easier to think of the children if you'd provide pictures of her. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| iooi |
 iooi Super Spammer
| Rogerborg |
 Rogerborg nimbA
| map |
 map Mr Calendar
| map |
 map Mr Calendar
 Posted: 19:42 - 02 Oct 2013 Post subject: |
So close.
I think there is a picture me her when she was much younger in a Star Fleet uniform. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Alice-In-Sunderland |
 Alice-In-Sunderland Banned
 Posted: 19:48 - 02 Oct 2013 Post subject: |
The only reason I don't like transit is because they charged me £15 for a brake lever, guy behind the counter's a cocky prick too.
Edit: I may even know your daughter  |
| Kakana |
 Kakana L Plate Warrior
| Fisty |
 Fisty Super Spammer
| ninja_butler |
 ninja_butler World Chat Champion
The last post was made 12 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
