gt 550 is very bouncy
WULFSTAN
PostPosted: 14:20 - 03 Oct 2013    Post subject: gt 550 is very bouncy Reply with quote
Hiya ive just bought a old 1990 gt 550 now the fella I got it off said it had new rear shocks on and tbh they do look new but when you hit any sort of bump you bounce about like mad any ideas thanks
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
P.
PostPosted: 14:24 - 03 Oct 2013    Post subject: Reply with quote
Adjust them?
WULFSTAN
PostPosted: 14:32 - 03 Oct 2013    Post subject: Reply with quote
Paddy. wrote:
Adjust them?
How do i do that ?
map
Mr Calendar
PostPosted: 14:39 - 03 Oct 2013    Post subject: Reply with quote
Are they the original shocks?
If so might be worn.
IIRC on the originals you can turn the top bits to a higher number. Higher is more firm.
The originals also have air. There should be a tube connecting both sides.
There's a nipple on the side covered by a screw cap.
Also IIRC adding air can be tricky, they're not a high psi anyhow.
If you google gt550 owners club (or shaft drive kawasaki owners club) I seem to remember there was some info on a web page there.
If not originals then refer to the maker of the shocks for adjustment advice.
I would say hope this helps but on re-reading I haven't actually given you a solution Sad
temeluchus
PostPosted: 16:43 - 03 Oct 2013    Post subject: Reply with quote
cheap aftermarket shocks are probably not up to the job, the GT550 is a fairly heavy bike to begin with!
Hagons or Shock Factory if you want a quality ride.
lofimaster
PostPosted: 19:42 - 03 Oct 2013    Post subject: Reply with quote
you can try to adjust it turning the top of the rear shocks.. there are some numbers there.. 1 to 4.. 4 is the harder, damping force harder, heavy load..
PostPosted: 19:46 - 03 Oct 2013    Post subject: Reply with quote
Take it to a suspension guru?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:40 - 03 Oct 2013    Post subject: Reply with quote
It's a GT550. What exactly were you expecting?
Triumph Sprint ST 1050
Pie-Roe
PostPosted: 01:13 - 04 Oct 2013    Post subject: Reply with quote
Just deal with the worn out bounciness:
https://img196.imageshack.us/img196/2078/36192402492992954625447.jpg
Pie-Roe
PostPosted: 10:41 - 04 Oct 2013    Post subject: Reply with quote
On a serious note, mine were pretty fucked, I just added air until it worked better. like 2 pumps on a double footpump made the forks ridiculously hard though, so be careful. It's like adjustable suspension on the cheap.
WULFSTAN
PostPosted: 19:11 - 04 Oct 2013    Post subject: Reply with quote
Vincent wrote:
It sounds like the dampers aren't working correctly. Any signs of any oil leaks?
No mate no signs of any oil leaks. Would replacing with hagons be the best bet.
Hetzer
PostPosted: 19:21 - 04 Oct 2013    Post subject: Reply with quote
Don't confuse him. Damping is rebound, compression is...compression, preload is the physical spring.
Turn the preload up until the bike doesn't go down more than about 30mm when you sit on it. I doubt you have rebound and compression, but if you do turn the rebound up to about three quarters and the compression up about one tenth. Then avoid potholes, unless you want your fillings out.
The last post was made 12 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 82.79 Kb
