First Yamaha FZS600 Fazer
reddeviljp
PostPosted: 15:26 - 04 Oct 2013    Post subject: First Yamaha FZS600 Fazer Reply with quote
Looking at a very good example tomorrow morning and it could be the one for me, my first 'big bike' Very Happy
Torch, gloves and multi-tool to hand and ready to go.
Anything to look out for or be wary of as I peruse her?
Bike: 1993 CB400 SuperFour - 1999 Yamaha FZS600 - DAS passed 7/11/13 - Working my way towards a Yamaha FZ1.
Cadbury
PostPosted: 15:47 - 04 Oct 2013    Post subject: Reply with quote
2nd gear is often described as problematic, mine certainly requires a firm tap to get it past neutral, but that's (apparently) a Yamaha trait throughout.
For me, the rear brake has issues with sticking. Under-slung calliper attracts lots of dirt, again, apparently common enough (or so the garage that did some work on it say) keep on top of cleaning, and it shouldn't be too much of an issue.
Other than that, my '98 first gen has been pretty reliable. Thumbs Up
gdj444
PostPosted: 16:17 - 04 Oct 2013    Post subject: Reply with quote
Great bikes, have had four over the last ten years, if its been looked after and has some service history then shouldn't have too much to worry about, some issues around the front sprocket and 2nd gear and most have a crack or two in the fairing but that's about it, I didn't have any problems on any of mine, just don't pay too much, there are loads out there so you can be a bit picky, I sold my last one earlier this year for £1100, it was a 1999 model, with 17k miles and in very good condition for reference
The guys below will tell you all you need to know:
https://foc-u.co.uk/index.php?action=forum
Jonesy
gdj444
PostPosted: 16:20 - 04 Oct 2013    Post subject: Reply with quote
Oh, and down pipes rot for a pastime so have a very close look at them, budget a couple of hundred if they need doing, if its got stainless pipes then that it is a real bonus!
Jonesy
yaigi
PostPosted: 16:21 - 04 Oct 2013    Post subject: Reply with quote
Yayyy! Do it! That's what I've got as my first big bike too Thumbs Up
Downpipes are prone to rusting - I bought mine and replaced them on it not long after as they developed a hole, so check what sort of state they're in, if they're looking worse for wear then might be worth trying to get some money knocked off so you can replace them.
As has been said, 2nd gear is a known issue (although I've had no issues with mine), and back brake can get sticky (I've had no issue with mine, but Mr Yaigi is currently hammering his before he gets on it every morning to loosen it's death grip haha.)
Other than that, they're pretty damn sturdy reliable bikes and a WHOLE lot of fun as your first bike, but even experienced riders like Mr Yaigi still get a thrill out of em. Love em. (See my quite recent thread about how great I think they are here: https://www.bikechatforums.com/viewtopic.php?t=278927&highlight=)
Amber Phoenix
PostPosted: 16:45 - 04 Oct 2013    Post subject: Reply with quote
Are a good bike.
Do be aware the later Foxeye version (2002-2003), had headlights that weren't shit, sticky out more mirrors that show more than your elbows (interchangeable between models mind) and bigger fuel tank.
If you do go for a Square eye model, consider some of the headlight mods you can do. Pop by foc-uk.co.uk for more info.
Original downpipes on my 2003 model are on way out. Full of holes in the 4 into 1 down at the bottom underneath bike. Pipes at front look fine mind. Decent Venom (from Motad factory) stainless pipes cost ~£160 from ebay shop.
Check fairing for cracks, under indicators and sides. Check fairing/clocks are straight. When dropped the bracket holding it in place can bend and it's a pain to get back straight again.
Gears can be clunky, Yamaha trait. Can be eased slightly by using a good Castrol Racing Power1 oil.
Other wise, usual stuff, check chain for rust, stuck links and hooked teeth on sprockets. Check brakes aren't sticking. Check forks, any pitting, seals leaking etc. Should have centre stand so check swinging arm for play too (probably be fine though).
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
reddeviljp
PostPosted: 18:45 - 04 Oct 2013    Post subject: Reply with quote
What a great list chaps, useful for anyone in future. I'll take it with me!
Yaigi, I'll have a read of your thread later but thanks very much.
'2nd gear'
'rear brake has issues with sticking'
'Under-slung calliper attracts lots of dirt'
'most have a crack or two in the fairing'
'front sprocket'
'down pipes rot for a pastime - budget a couple of hundred if they need doing'
'might be worth trying to get some money knocked off so you can replace them. '
'Decent Venom (from Motad factory) stainless pipes cost ~£160 from ebay shop. '
'Check fairing for cracks, under indicators and sides - Check fairing/clocks are straight'
'check chain for rust, stuck links and hooked teeth on sprockets. Check brakes aren't sticking. Check forks, any pitting, seals leaking etc. Should have centre stand so check swinging arm for play too (probably be fine though)'
'carb rubbers crack, but don't let air in so just look shit'
Anything I've missed?
andi
PostPosted: 22:42 - 04 Oct 2013    Post subject: Reply with quote
yes the headlight is piss poor. Great bikes though!
Heres mine before I killed her.
https://i16.photobucket.com/albums/b24/andipicture/Fazer%20RIP/fazer004.jpg
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Andy_Pagin
PostPosted: 23:12 - 04 Oct 2013    Post subject: Reply with quote
Gear changes sound and feel horrible compared to a Suzuki, don't be put off by it. If the back brake feels 'hard' rather than soft and progressive then it's probably in need of a wallop with an expertly wielded club hammer and new pads. That apart they're. Pretty bullet proof
Shinigami
PostPosted: 21:02 - 06 Oct 2013    Post subject: Reply with quote
Headlight on mine (08) is fantastic, best headlight on a bike i've had yet
zero issues kicking into 2nd.
Love it,
Woman loves it
winner Thumbs Up
reddeviljp
PostPosted: 18:45 - 09 Oct 2013    Post subject: Reply with quote
Sorry about the late posting of this but what a beauty she is.
Thanks very much for all your advice which I drafted into a list. I've now bought it and the young bloke was generous to a fault and gave me a spare screen, brand new rear tyre, spare chain guard, three sets of brake pads, Oxford lock and chain and an Oxford Aquatex cover along with a 40litre Givi box and frame with two keys!
Anyhow, once I got her home I've made an absolute howler in that I turned the ignition to 'P' and I've drained out the battery! Unbelievable!
I've only got one photo that is worth showing at the moment and here she is. I think she looks a belter and I've landed a good one with, as I said above, plenty of extras for the price. 24 000 on the clock and a really good feel to it so I'm more than happy.
Amber Phoenix
PostPosted: 21:13 - 09 Oct 2013    Post subject: Reply with quote
Looks nice. Top stuff.
To make use of the Givi box, you'll need the Givi 340F rack and M3 plate (I assume it's a Monokey box, and not the cheaper Monolock version). Set you back about £100 brand new.
I presume the spare screen is the original one. You've got a decent doublet bubble screen on there. Rear hugger too, always handy to keep crap down. And the crash bars, another handy extra.
Have fun on her! And pop by foc-uk.co.uk and join the rest of us Fazer owners. Wink
Yamaha FZ6 S2 2007
Andy_Pagin
PostPosted: 21:29 - 09 Oct 2013    Post subject: Reply with quote
Remember to blast the back brake with brake cleaner regularly.
reddeviljp
PostPosted: 18:36 - 10 Oct 2013    Post subject: Reply with quote
Arfa_ - it's an absolute beauty Very Happy
The previous owner told me that he was 'gutted to be selling her' but he couldn't keep two bikes. It purred like a beauty on the ride home. Already signed up on the Fazer owners site and they know their stuff. I've had advise on how to tweek things and the people there are very friendly Very Happy
Shinigami
PostPosted: 22:56 - 11 Oct 2013    Post subject: Reply with quote
I should probably sign up to that site too. Still loving mine, just reached my first thou miles on it
Very concious of the parking light setting! luckily not drained the battery yet
andi
PostPosted: 10:10 - 12 Oct 2013    Post subject: Reply with quote
That looks very nice. Enjoy!
janner_10
PostPosted: 12:09 - 12 Oct 2013    Post subject: Reply with quote
Good choice for a first bike - solid machines (headlights aside - although to do the both-on mod takes only 10 mins and well worth doing)
The last post was made 12 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.63 - MySQL Queries: 15 - Page Size: 106.6 Kb
