 DavyJones963 L Plate Warrior
 Posted: 17:15 - 04 Oct 2013 Post subject: Idle Screw in to start... please can I have some advice! |
Hi everyone!
I have recently bought a cb100n from 1983 and have spent the last 2 weeks getting it running ok (sorting out air leaks, cleaning carb, basic maintenance that had been missed by PO). I know very little about working on bikes. The bike is running a replacement carb which is the only modification.
I have got it happily idling at 1300rpm (as stated in the haynes manual) but I struggle to get it started without screwing in the idle screw and having the choke on so it starts at 7000rpm . From there I can readjust the idle and take it off choke after a bit and it runs happily.
I know that this use of the idle screw may mean I am effectively starting it with throttle which can be hard on the engine. Should I rejet? Adjust the mixture screw? Any advice you could give would be invaluable.
Thanks,
Dave  |
 Hetzer Super Spammer
 Im-a-Ridah World Chat Champion
 bikenut World Chat Champion
