Aprilia rs125.. too much 2 stroke
iandyrs
PostPosted: 01:24 - 07 Oct 2013    Post subject: Aprilia rs125.. too much 2 stroke Reply with quote
I bought my bike a few weeks ago and it ran 100%, i then bought new 2 stroke (liqui molly). I basically said fuck it and through the whole lot of it i the 2 stroke reservoir under the seat.
The bike had little fuel and old stroke already in it.
The bike now only starts and tics over for a few seconds and dies.
The exhaust is shooting all kinds of reek out.
and the spark plug is wet.
I think ive some how flooded the bike with too much 2 stroke
so a solution on how to either flush out whats in the carb/engine?
or will adding more fuel dilute the 2 stroke and run ok ?
cheers Andy
aprilia RS125 06"
kerr
PostPosted: 01:33 - 07 Oct 2013    Post subject: Reply with quote
The amount of oil you put in wont make a differance as its fed to the carb via a pump.
When you say little fuel i presume you mean in the fuel tank not the oil tank Shocked , you have got enough fuel in the tank havent you?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
iandyrs
PostPosted: 01:51 - 07 Oct 2013    Post subject: Reply with quote
Yeah in the fuel tank lol, well it was quite low when i put the new 2 stroke in, i recently put more fuel in it and it started and began to tic over for short periods of time and then it would cut out Sad
A family friend said that it sounded like it was running rich, and to drain the fuel out, but i dont see how it could have flooded due to the fact that it is a pump system after all :S
aprilia RS125 06"
Boxing
PostPosted: 06:05 - 07 Oct 2013    Post subject: Reply with quote
Hmmm. Oil pump settings all correct? Didn't stall out after a ride prior to this?
Mileage and when was the topend last done?
iandyrs
PostPosted: 14:45 - 07 Oct 2013    Post subject: Reply with quote
How do i check the 2stroke oil settings?
Would draining the carb help ?
Its a head fryer as it was working up til now and i want to MOT it this week !
DARK DAYS
aprilia RS125 06"
kerr
PostPosted: 16:07 - 07 Oct 2013    Post subject: Reply with quote
DARK DAYS
Welcome to the worl of italian 2 smokers Wink , would be worth getting a compression tester too, also check if there is any fuel leaking from the carb, mine does this now and again when the float sticks, a good knock sorts it.
The other Paul Rudd
PostPosted: 19:46 - 07 Oct 2013    Post subject: Reply with quote
You didn't mix castor and mineral oil did you?
PostPosted: 20:38 - 07 Oct 2013    Post subject: Re: Aprilia rs125.. too much 2 stroke Reply with quote
What oil did you put in?
The last post was made 13 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 54.74 Kb
