The Leidenfrost effect - SCIENCE!
Lord Percy
PostPosted: 18:38 - 09 Oct 2013    Post subject: The Leidenfrost effect - SCIENCE! Reply with quote
The Leidenfrost effect is when a liquid touches a surface so hot that when it boils, the immediate vapour forms a protective base underneath the liquid, so it isn't properly touching the surface any more and therefore lasts very much longer than you would ever expect. If you set your oven hob to hottest and put a drop of water on it, you can see the Leidenfrost effect in action.
Some guys at the University of Bath took it a bit further. They used a sawtooth ridged surface so that the boiling water would always be at a slight angle to the standard flat position, which means the pressure of the vapour underneath causes the droplets to be propelled to the side and, therefore, can even go uphill.
tl;dr - boiling water droplets made to navigate maze.
https://www.liveleak.com/view?i=c37_1380787459
Thumbs Up Cool
PostPosted: 18:58 - 09 Oct 2013    Post subject: Reply with quote
You can achieve another odd effect if you put low boiling point petroleum ether in your hand. It boils. You can light it but it is evaporating so fast that the heat from the flame doesn't burn you.
Lord Percy
PostPosted: 19:06 - 09 Oct 2013    Post subject: Reply with quote
I saw a similar thing done with liquid nitrogen.
The last couple of clips in the video are awesome - you can see his hand causing it to boil.
MattJ
PostPosted: 22:06 - 09 Oct 2013    Post subject: Reply with quote
I see you also follow I Fucking Love Science. Laughing
DrDonnyBrago
PostPosted: 10:26 - 10 Oct 2013    Post subject: Reply with quote
I was just about to add, it can be done with LN2.
We have it in our lab, aside from putting your hand in it and making rubber and blu-tac brittle, it is nowhere near as dangerous/entertaining as my 12 year old self would have hoped.
The last post was made 12 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 44.09 Kb
