| Lord McThor |
 Lord McThor Derestricted Danger
| stirlinggaz |
 Posted: 10:35 - 10 Oct 2013 Post subject: |
hi,
i presume you mean the screw on the carb body?
can be drilled out easily (usually brass ime) with hss or cobalt drill bit.
start small 1 or 2mm then work up through drill sizes till screw collapses on itself.
shouldnt take more tham 15mins.
then buy a replacement screw.
i have done it a few times with dellorto & mikuni carbs & spares are readily available.
cheers,
GAZ
PS : just looked at cmsnl, & im looking at right schematic https://www.cmsnl.com/honda-h100s-1988-england_model3444/partslist/E__1000.html#results its a mikuni carb,& its 9 euros for new screw, i presume you'll get it in UK for around same price. if your stuck, i may have one in my big box of carbs, which i have collected over the years (i have had umpteen 2 strokes) if you tell me size/thread. is it a 21mm carb? |
| bikenut |
 bikenut World Chat Champion
 Posted: 11:19 - 10 Oct 2013 Post subject: |
If you take the carb off, remove the throttle valve and start drilling out the stub of the idle screw slowly and carefully, the drill will eventually bite and screw the stub further in.
Because it is in an open hole, it'll eventually screw all the way through and fall out into the throttle tube.
You might even have enough showing through to grip the inside bit with some needle nose pliers and unscrew it that way. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stirlinggaz |
| Lord McThor |
 Posted: 12:07 - 10 Oct 2013 Post subject: |
You can take the carb off, clamp it firmly in place and drill it in a pillar drill. Really shouldn't be able go wrong doing it that way
There may well be a bit sticking out on the inside of the carb which is what I was meaning to grab hold of.
I used to put a clothes peg under the choke button to hold it on and clip it on the fuel line when not in use. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| _Iain_ |
 _Iain_ Banned
 Posted: 12:17 - 10 Oct 2013 Post subject: |
Bin carb, add fecking huge pitbike carb & pod filter.  ____________________ Please be aware that the above post may be full of complete nonsense.
| bikenut |
The last post was made 12 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
