| stranger12 |
 stranger12 World Chat Champion
| Islander |
 Islander World Chat Champion
| stranger12 |
| dolly3900 |
 dolly3900 Traffic Copper
 Posted: 13:16 - 07 Oct 2013 Post subject: |
Long Answer
Batteries are rated in Ah (Amper Hours) for use and a maximum current to be drawn without damage
So I am assuming your 100A battery is a standard bike battery which is probably about a 6Ah with a 100A max load.
This means it will provide 1A of load current for 6 hours, 6A of load current for 1 hour, or any other combination of multiples up to a 100A load current for about 3.6 minutes (obviuosly taking into account losses etc.)
Most batteries have a typical/maximum charging rate (usually a couple of amps), but when totally dead, can draw much more in order to kick off the chemical reactions inside the little beasties before settling down to charge normally.
If your charger is rated at 10-40A, this will mean that it is designed to give out a constant load up to 10A, with a peak/spike load of 40A (such as on initial charge from flat)
If your battery is designed for a 1-2A charge current, that is all it will take under standard charging, no matter what you plug onto it, so the 10-40 charger will be operating at about 20% of its standard trickle charge load, no matter what.
It is like your TV at home, it is designed to draw about 3A from the mains, but the mains to your house is able to provide enough for the cooker, the shower and the rest of the house to (several hundrend amps in total), but the telly only draws what it needs.
Short Answer
Plug it in, it'll be fine
Hope that explains and helps
Mike ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
| stranger12 |
| Islander |
| stranger12 |
| Islander |
 Posted: 14:55 - 10 Oct 2013 Post subject: |
6Ah is the continuous discharge rating - i.e. 1A for 6 hours etc. 100A is the CCA or maximum instantaneous discharge rating.
This is why you should never wear jewellery when working on vehicle electrical systems.  |
| stranger12 |
The last post was made 12 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
