Liability of ebay seller
Marmalade
PostPosted: 17:22 - 10 Oct 2013    Post subject: Liability of ebay seller Reply with quote
I have a portable printer for use in the van, has a battery as well as mains power option.
It also has as an option a wi-fi or bluetooth card slot for plugging in modules.
I bought a used bluetooth module from a business seller and the listing states
Condition:
Used: An item that has been previously used. The item may have some signs of cosmetic wear, but is fully operational and functions as intended. This item may be a floor model or an item that has been returned to the seller after a period of use. See the seller’s listing for full details and description of any imperfections.
Enjoy true mobile freedom with HP's wireless printing solution. With the HP Bluetooth printer card installed in your printer's CompactFlash slot, you can easily print from a variety of Bluetooth-enabled devices, with no cables slowing you down....All used in good condition..card only ...
Now, it arrived today, switched on printer, plugged in module and I get flashing error lights on the printer.
Switch it off, remove battery, refit and switch on and still error lights without module, reset it, leave it without power for an hour and still error lights, it isn't even recognised by pc via cable.
I'm thinking the module has borked the printer, before i contact the seller, what can i reasonably expect of the seller?
Nexus Icon
PostPosted: 18:16 - 10 Oct 2013    Post subject: Reply with quote
I expect it's going to be bloody difficult to prove the printer wasn't already borked and has, in fact, borked the Bluetooth module.
I think you're going to be relying on good faith here so start out gently.
Best of luck. Thumbs Up
Greetings from Shitsville!
Wonko The Sane
PostPosted: 20:57 - 10 Oct 2013    Post subject: Reply with quote
does the printer need an update running on it's softwear to set it up?
our wireless one did updates when it was new
anything on hp's support site?
Rockhopper
PostPosted: 08:51 - 12 Oct 2013    Post subject: Reply with quote
You turned the printer on then put the card in? Is that what the instruction said you should do?
The last post was made 13 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 41.37 Kb
