Brake pad change Honda SH300
Adam80UK
PostPosted: 11:36 - 08 Oct 2013    Post subject: Brake pad change Honda SH300 Reply with quote
Hi can't find any info online or a workshop manual.
I need to change brake pads and I believe the SH300i has linked brakes (though I'm not 100% sure) does this effect how pads are changed?
To fit new pads, would I still work the pistons open with a screwdriver between the old pads?
Thanks
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
Fizzer Thou
PostPosted: 10:31 - 11 Oct 2013    Post subject: Reply with quote
According to this data sheet there are three pistons in the front caliper and a single piston in the rear
https://www.bikez.com/motorcycles/honda_sh300i_2012.php
If you are unable to push the pistons back into the caliper body,I use one of these
https://www.machinemart.co.uk/shop/product/details/cht268-disc-brake-piston-spreader?da=1&TC=SRC-brake+piston+tool
Make sure that the pistons are clean before you attempt to push them back into the caliper body,otherwise the seals may well get damaged by the corrosion or dirt buildup.
For any technical questions,Honda UK have a helpline,which is 0845-200-8000
Always have a 'Plan B'
Bezzer
PostPosted: 10:49 - 11 Oct 2013    Post subject: Reply with quote
For just changing pads there's no difference to doing it on a normal non linked bike, you're not bleeding it or whatever which is where it gets different.
The last post was made 12 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 36.49 Kb
