snapped cylinder bolt... :(
Norlig
PostPosted: 19:15 - 11 Oct 2013    Post subject: snapped cylinder bolt... :( Reply with quote
Just going to start this thread with saying that, I am going to buy a torque tool and new bolts first thing tomorrow.
So, I managed to do this:
https://img13.imageshack.us/img13/6835/r00x.jpg
A friend said it was easy and that I just need to drill it out?
Can someone tell me what the easiest way to get this out now is? is it indeed drilling?
dansp1
PostPosted: 19:31 - 11 Oct 2013    Post subject: Reply with quote
How did you snap it? doing it up?
if so a good sharp centre punch used carefully to tap it round should work Very Happy
Norlig
PostPosted: 20:34 - 11 Oct 2013    Post subject: Reply with quote
Snapped when turning it to fasten the cylinder to the crank case, I'll give it a try to hit it like that, but it looks like it sheared in a way that doesnt give me many places to hit.
Hetzer
PostPosted: 20:38 - 11 Oct 2013    Post subject: Reply with quote
After it's been tightened up hard enough to shear? Good luck with that.
smegballs
PostPosted: 20:49 - 11 Oct 2013    Post subject: Reply with quote
If we assume the bolt hasn't bottomed out in its tapped hole then currently it won't be under any tensile/compressive loads so it should be relatively free. The tightness comes from the tension in the fastener between the flange on the bolt head and the threads. Without a bolt head obviously it should be pretty loose.
Obviously if it sheared due to the tip of the threaded section bottoming out, as it may well have due the the bolt shearing rather than the threads stripping, then you'd be right as the remains of the bolt will still be loaded.
Hetzer
PostPosted: 20:56 - 11 Oct 2013    Post subject: Reply with quote
True that. Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 22:16 - 11 Oct 2013    Post subject: Reply with quote
Hit the stub square on with the punch near the edge. This will leave a dent in the stub (if you hit it hard enough).
Then, angle the punch with it in the dent and then gently(ish) tap the punch in the correct to undo it.
You'll need a good quality punch with a thin tip for best results. A good quality punch will have a seriously hard tip.
Triumph Sprint ST 1050
Ed Case
PostPosted: 22:27 - 11 Oct 2013    Post subject: Reply with quote
This method has worked for me more than once !. Thumbs Up Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 22:36 - 11 Oct 2013    Post subject: Reply with quote
Believe it or not, I was taught that one by a mechanic who I paid to do work for me. There are good ones out there...
1cyl
PostPosted: 22:50 - 11 Oct 2013    Post subject: Reply with quote
Buy Dormer screw extractor. Tape up crankcase opening and slowly drill a nice neat hole in snapped thread using a nice cutting agent. Spray with WD 40. Extract using correct extractor for hole size.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Ariel Badger
PostPosted: 22:57 - 11 Oct 2013    Post subject: Reply with quote
What has happened to your piston, it looks like it has had acne.
Norlig
PostPosted: 00:10 - 12 Oct 2013    Post subject: Reply with quote
That's just some 2 stroke oil i put around the edge of the piston when I first fastened the new piston/cylinder.
Supposedly it helps against scratches from dirt
Edit: it came out with ease... I am so surprised.
All it took was to push on the edge on the top of it as you said above Smile . It was almost as if it was hand tightened
dansp1
PostPosted: 08:26 - 12 Oct 2013    Post subject: Reply with quote
no charge Wink
Robby
Dirty Old Man
PostPosted: 10:26 - 12 Oct 2013    Post subject: Reply with quote
Don't use an extractor. It will snap, and then you'll be fucked.
Drill a pilot hole with a cobalt drill bit and plenty of cutting fluid. Then switch to left-handed drill bits to drill out the remains. Most times the left-handed drill bits will unscrew the remains once enough metal has been removed.
Use a torque wrench next time. It looks like an M10 bolt that you've snapped. Cylinder head bolts only tend to require between 20 and 40 ft-lb of torque, and it takes a lot more than that to snap an M10 mild steel bolt.
Ed Case
PostPosted: 15:01 - 12 Oct 2013    Post subject: Reply with quote
Robby's advice is dead right don't use extractors they are the invention of the Devil, should it snap and they usually do when start putting anything like any twisting force into them the bastard things break and when previously you had a problem now you're in deep shit. If using a centre-punch and a relatively light hammer doesn't work and if the remains of the bolt aren't 'bottomed' in the thread, it usually does the trick, his drill advice is spot-on. That or professional help is the answer. Best of luck !.
smegballs
PostPosted: 15:47 - 12 Oct 2013    Post subject: Reply with quote
Interesting you saw mild steel bolt rather than "hi-tensile". Are head bolts normally mild steel and loaded into their plastic deformation range? If so it would make sense as I've heard that some head bolts are meant to be single use, as are some brake disc bolts etc.
Norlig
PostPosted: 17:09 - 12 Oct 2013    Post subject: Reply with quote
As mentined earlier, I got the bolt off easy as It hadn't bottomned. Smile
I have bought a Torque socket wrench now, also found in the manual that I need 15nM of torque on them.
But, I did not find any bolts from any store that were the same length and diamater as the ones I had, so I made my own:
https://imageshack.us/a/img543/8116/ch2h.png
https://imageshack.us/a/img708/918/2lzz.jpg
But then the same person as in the first post said that I should not use them because they might not take the heat from the cylinder (although the bike is liquid cooled), another person said it might corrode, as the crank case is cast steel?
The bolts I made are stainless steel, not fermented
Can I use these, or do I have to order some bolts?
Timmeh
PostPosted: 18:24 - 12 Oct 2013    Post subject: Reply with quote
Is this is a trick question?
Welshd1k
PostPosted: 18:44 - 12 Oct 2013    Post subject: Reply with quote
one would hope so SS bolts are more prone to snapping if ii recal correcttly and im pretty certain head bolts are a certain grade of steel to deal with the heat and stretchng etc and to be torqued...
Robby
Dirty Old Man
PostPosted: 18:57 - 12 Oct 2013    Post subject: Reply with quote
I say mild steel as opposed to stainless steel, not going into complexities of grades.
OP, get the right bolts from a dealer. You managed to snap a mild steel bolt, so now you want to replace it with what looks like some easy-shear stainless threaded bar from a garden centre. When that snaps you'll be fucked.
Get the right parts, follow the manual to do the job right, don't bodge it or take shortcuts when failure can cause expensive damage.
Norlig
PostPosted: 19:03 - 12 Oct 2013    Post subject: Reply with quote
Gonna visit the local MC workshop on monday then, if they dont have it, I'll order from the webs.
Thanks!
The last post was made 12 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 111.15 Kb
