Help. Indicators flashing fast
Ed1stcm
PostPosted: 11:56 - 12 Oct 2013    Post subject: Help. Indicators flashing fast Reply with quote
Suzuki gladius has been sitting for a while now the indicators are flashing really fast.
If i turn on the bike and put them on, both sides flash normally but when i turn the engine on and try again, they start flashing rapidly. ?
Thanks.
janner_10
PostPosted: 12:23 - 12 Oct 2013    Post subject: Reply with quote
Has a lamp blown or a loose connection on one?
Hetzer
PostPosted: 12:24 - 12 Oct 2013    Post subject: Reply with quote
The solonoid might have gone.
Ed1stcm
PostPosted: 14:03 - 12 Oct 2013    Post subject: Reply with quote
All the bulbs work fine if the engine is off. just when i start it up, both sides flash fast.
jimbob005
PostPosted: 14:46 - 12 Oct 2013    Post subject: Reply with quote
multi meter and see how meny volts are going to the flasher unit may be a regulater/rectifier gone
Ed1stcm
PostPosted: 15:35 - 12 Oct 2013    Post subject: Reply with quote
ok will have another look.
also when its running and i put the hazards on they all blink at the right speed. And then indicate left or right there is like a second or two when they are fine before rapidly flashing again.
Ed1stcm
PostPosted: 15:47 - 12 Oct 2013    Post subject: Reply with quote
oh and at about 2000 revs or higher they also flash at a normal speed.
Ribenapigeon
PostPosted: 16:27 - 12 Oct 2013    Post subject: Reply with quote
I would check the flasher relay and connections first. however if its wofking normally when the bikes at higher revs then suggests regulator is maybe a bit dicky. Service manual will tell you how to check it.
J.M.
PostPosted: 18:15 - 12 Oct 2013    Post subject: Reply with quote
My thoughts too.
2004 R1 & 2018 XSR900
The last post was made 13 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 57.95 Kb
