cb600 wont rev over 6.5k-7k ish stravation?
Welshd1k
PostPosted: 14:24 - 12 Oct 2013    Post subject: cb600 wont rev over 6.5k-7k ish stravation? Reply with quote
Well the bike ran fine when i parked it up 4 weeks ago ish .
finsiehd my swing arm swap and forks etc goen to use it it had a miss fire so i swapped out the plugs for some new irridium ones . starts perfect will rev o the red line in neutral etc the issue :
when im riding it it will rev to 8-9k in first then the higher gears it gets to 6.5k ish and starts to judder and struggle and wont rev any higher if i feather the throttle it will build up slowly to 8k ish then start to die off. so i THINK its fuel starvation rather than eletrical .
so what ive tried :
swapped out carbs for another set with a dynojet kit installed
drained the tank and checked the fuel tap is working and vaccume is opening the tap
swaped out the coils
swaped the rectifier
fresh fuel
new fuel line to the carbs
swapped the CDI
kinda at a loss now trying to work out whats wrong with it its something stupid that im not thinking off probaly any help is appreciated
PostPosted: 15:13 - 12 Oct 2013    Post subject: Reply with quote
Do you have a prime option on the tank?
If so, leave it on that and take it for a run. Also tried opening the fuel cap and taking for a quick run?
Welshd1k
PostPosted: 15:34 - 12 Oct 2013    Post subject: Reply with quote
No prime just on off and reserve tempted to take the diaphragm out of the tank so in the on position it fuels without vacuum . And I'll try tank open latter pissing me off lol
PostPosted: 15:36 - 12 Oct 2013    Post subject: Reply with quote
Sure? A vacuum tap usually has On, Prime and Res. No need for "Off" as its vacuum fed. With no vacuum, fuel can't flow.
Weird one Confused
Welshd1k
PostPosted: 15:40 - 12 Oct 2013    Post subject: Reply with quote
Certain forward is reserve down is off and back is on lol . It's weird my rd has prime /res/on lol
PostPosted: 15:42 - 12 Oct 2013    Post subject: Reply with quote
Quick google, you are right, odd Confused Where does your vacuum pipe go to? I know the one for my old Bandit 400 when to cyl 1 inlet.
Welshd1k
PostPosted: 15:46 - 12 Oct 2013    Post subject: Reply with quote
Cylinder 2
Cylinder 3 is the pair valve
1 and 4 are blanked
Welshd1k
PostPosted: 14:07 - 14 Oct 2013    Post subject: Reply with quote
Fuel cap off no difference . Sprayed all the inlets with carb cleaner and it isn't leaking so ummm what next lol
bypass2
PostPosted: 18:48 - 14 Oct 2013    Post subject: Reply with quote
is there a good petrol flow to the carbs if so maybe float heights. have you cleaned the carbs out.
PostPosted: 18:49 - 14 Oct 2013    Post subject: Reply with quote
Remove the air filter and try it.
Welshd1k
PostPosted: 16:33 - 18 Oct 2013    Post subject: Reply with quote
tried with a stock filter / no filter etc no avail ...
took it up the road 300 yards was all good then nothing ... now wont even start LMAO
got spark
got fuel ..
wont even fire if I spray easy start in
so I think its slipped / timings jumped or cams fucked etc (engine has been stood 3 years idle) so tomorrow compression test if its fucked my old hornet engine will go in and scrap the current one then keep an eye out for a cbr600 f3 engine for moar power ... well high end (cams)
gavcarter
PostPosted: 16:40 - 18 Oct 2013    Post subject: Reply with quote
How is Battery volatage doing?
Welshd1k
PostPosted: 16:58 - 18 Oct 2013    Post subject: Reply with quote
12.4 even ran it with leads from my running landrover
gavcarter
PostPosted: 17:06 - 18 Oct 2013    Post subject: Reply with quote
12.4 is absolutely fine, check all earths make sure they are good. Considering the amount of swapping you've done i would test compression and double check timing as you've covered pretty much everything else so far
Odds on this is an electrical gremlin though.....
Nobby the Bastard
Harley Gaydar
PostPosted: 17:14 - 18 Oct 2013    Post subject: Reply with quote
Generally, all running problems are electrical rather than fuelling but....
these days petrol is full of crap (ethanol) and will gum up carbs very quickly (3 weeks lack of usage on my FZ caused similar issues but a good blast and probably our pot-holed roads sorted the issue)
Check that the main jets aren't gummed up and that the floats and valves in the carbs aren't sticking.
Triumph Sprint ST 1050
Welshd1k
PostPosted: 17:39 - 18 Oct 2013    Post subject: Reply with quote
swaped a whole wiring loom froma known good bike still 0 thinking engine
gavcarter
PostPosted: 17:54 - 18 Oct 2013    Post subject: Reply with quote
Engine usually give another symptom, sounds wrong, smokey exhaust, knocking etc just something else to go along with it other than doesnt like to rev.
Of course I am not a mechanic and not even seen the bike so everyone just makes an educated guess on it.
I cant really think of an engine problem that would give you those symptoms with out any others to go with it.
If fuelling is definitely ruled out then start trouble shooting the engine
Welshd1k
PostPosted: 18:02 - 18 Oct 2013    Post subject: Reply with quote
I think the timing may be out or sticky valve or similar compression test tomorrow and theres a NICE Cbr f3 race lump going cheap that I may purchase with cbr carbs to replace should see 100 ish bhp with my full system and the carbs etc
gavcarter
PostPosted: 18:17 - 18 Oct 2013    Post subject: Reply with quote
Would make a good excuse for an engine swap haha,
Dive into the engine tomorrow poke around and see what you can find lol
Welshd1k
PostPosted: 18:26 - 18 Oct 2013    Post subject: Reply with quote
Yeah well I got 4 hornet engines here in various states so no exscuse not to fix / strip it Smile
cb1rocket
PostPosted: 21:32 - 19 Oct 2013    Post subject: Reply with quote
New spark plugs?
Ariel Badger
PostPosted: 22:09 - 19 Oct 2013    Post subject: Reply with quote
You engine must have some kind of advance/retard mechanism for the ignition. Is it working as your symptoms sounds as if it is retarded.
The last post was made 13 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 107.53 Kb
