More vfr problems
andym
PostPosted: 14:07 - 13 Oct 2013    Post subject: More vfr problems Reply with quote
First off a quick update on my previous issues:
The running issues was down to a kink in the fuel line, 2 new 90 degree connectors and new fuel line connectors and no more running issues.
The electrical issue was down to the rear brake plug had been sitting on the exhaust and melted through causing it to short (which would explain why it was more obvious at higher revs).
Those problems have been sorted and I took it for an MOT the other day and it failed on a loose rear light (fixed with cable ties) and the front brakes binding (which is where the problem is now).
Because I didn't have the correct tools I had to try cleaning them up as best I could, but when I took it back the guy lifted the front end and spun the wheel, then pressed the brake and tried again (at least I know how to test it now Thumbs Up )
So I borrowed some tools and bought some cleaner and set about trying to sort them.... but I'm still having issues.
So far I've stripped the calipers down 3 times, the pistons are gleaming, the seals look fine (there was a bit of crud that I've cleaned off), when I push the pistons back in they more or less fall straight into place with very little pressure. Now everything is as clean as I can get it, but the front wheel still feels stiff to move, and since the calipers have been stripped the brakes lose pressure after about an hour, but there is no fluid leaking out that I can see.
I did notice that the pads on 1 side are almost down to the wear markers, but not sure if that would be causing a binding issue, also would cleaning the seals (with a cloth and brake fluid) have caused them to be causing a slow leak?
I know at some point I'll need to replace the pads and seals, but since I've come up to Glasgow I've had nothing but bad luck....
Tl;dr: stripped calipers 3 times and still fucked
Hetzer
PostPosted: 14:16 - 13 Oct 2013    Post subject: Reply with quote
You most likely have air still trapped in the lines and/or calipers.
andym
PostPosted: 14:28 - 13 Oct 2013    Post subject: Reply with quote
True, last time I cleaned them I couldn't get the pressure to build properly and had to tie up the lever overnight... so I'll give that another go, but it's the problem of why the brakes are still binding when everything has been cleaned 3 times
PostPosted: 14:51 - 13 Oct 2013    Post subject: Reply with quote
I'd expect some resistance when pushing the piston back in, then a satisfying clunk as it hits home.
Had a similar problem with a piston that wouldn't return (stay put). Removed the seals and cleaned the groove out with a whittled matchstick and blasts of brake cleaner. New seals are inexpensive and some of that red rubber grease.
Job jobbed. Thumbs Up
Hetzer
PostPosted: 15:45 - 13 Oct 2013    Post subject: Reply with quote
I had to use a sharp piece of metal scraper to get the oxidised crud out of the grooves in mine. Not so sharp as to score the metal though.
mr jamez
PostPosted: 15:59 - 13 Oct 2013    Post subject: Reply with quote
They're sliding calipers, so its common to have problems with the pins getting corroded and getting stuck in the rubber seals. Ideally they should slide nice and freely. If they are very difficult to pull apart then replace the pins and rubbers.
prawny1
PostPosted: 20:38 - 13 Oct 2013    Post subject: Reply with quote
Are your levers original, and did you clean the master cylinder at the same time?
When bleeding twin caliper systems I use a hose clamp to block off one of the calipers so that I can bleed them individually.
Once I get good lever feel on one I clamp that hose and release the other so that I can bleed it.
If you leave them both open you are compressing the air in the other caliper all the time so may take ages to clear it all.
Another thing to check would be whether you have all the pads, clips and shims in the right place, and if your calipers had been binding for a while check whether the discs are bowed from the heat and pressure.
hellkat wrote:
andym
PostPosted: 22:13 - 13 Oct 2013    Post subject: Reply with quote
When I was cleaning the calipers I noticed that 1 side seemed tighter than the other with the pistons, so I don't know if it was binding on one side but the MOT guy said that it was both sides, but I did get an advisory on both discs being slightly warped.
I've tied the lever up for the night as that seemed to get all the air out last time... so hopefully they'll be fine in the morning and I can go back to the MOT tester
The last post was made 13 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 60.03 Kb
