Crank case?/ Generater cover/ Hole! Help me please BCF!
RalphCh97
PostPosted: 19:15 - 14 Oct 2013    Post subject: Crank case?/ Generater cover/ Hole! Help me please BCF! Reply with quote
Hello members, i have come back to ask another question as you people were very helpful last time!
I bought an engine a few months back and I took the sprocket off and the was like a hole/ split in the engine right next to the generater cover/crank casing? I took the engine cover off and the is like a generater inside? Or something? I have an am6 engine and the crack is on the left, I cannot buy a new cover a that is fine, it's the actual engine, but no oil gos into the part of the engine as it's electric part/ generater, I turned bike on and no oil came out after putting some in (other side of engine where kick is etc! But the other side where gear leaver is the is a crack/split in the engine, te is a gasket on the cover but I think that's to stop water getting in? Sorry I'm new to bikes! Someone please help!:) and I can't return engine, i didn't know it had hole but I still can't return it!
Minty
PostPosted: 19:25 - 14 Oct 2013    Post subject: Reply with quote
Buy some chemical metal glue/epoxy and fill it.
My fingers smell of your mum.
RalphCh97
PostPosted: 19:34 - 14 Oct 2013    Post subject: Reply with quote
Okay thanks, does oil go around/ flow in that casing?
Minty
PostPosted: 19:45 - 14 Oct 2013    Post subject: Reply with quote
No, oil and generators are not friends. People have left them cracked and not worried about it. I'd use the chemical metal and close it up.
RalphCh97
PostPosted: 19:47 - 14 Oct 2013    Post subject: Reply with quote
Okay thanks very much, very helpful, just out of interest if water got in could it damage the generater? Also is the gasket there to stop water and things getting in? I am going to buy some of that filler now, thanks mate
Minty
PostPosted: 05:44 - 15 Oct 2013    Post subject: Reply with quote
Water and generators are not good friends either. It's an electricity thing.
Teflon-Mike
tl;dr
PostPosted: 08:20 - 15 Oct 2013    Post subject: Reply with quote
Strange... my VF1000 has a 'wet' generator running in the sump oil.... apparently its a more common arrangement these days, now engines don't tend to have points.
PostPosted: 12:02 - 16 Oct 2013    Post subject: Reply with quote
You are right there, but what modern bikes have you ridden.
Minty
PostPosted: 12:15 - 16 Oct 2013    Post subject: Reply with quote
No point asking him, Pads.
Clear, straight to the point post from Teflon.
Clearly his account has been haxxored.
The last post was made 13 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 60.05 Kb
