How do you remove kawasaki gt 550 seat.
WULFSTAN
PostPosted: 12:59 - 15 Oct 2013    Post subject: How do you remove kawasaki gt 550 seat. Reply with quote
Yes i know am a idiot but i have no idea how to take the seat off any help would be appreciated thanks.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
doggone
PostPosted: 13:31 - 15 Oct 2013    Post subject: Reply with quote
I had the similar 750, but don't recall anything unusual about it.
Has someone modified it by bolting it down?
WULFSTAN
PostPosted: 13:36 - 15 Oct 2013    Post subject: Reply with quote
How did you take yours off the 750.
map
Mr Calendar
There is a lever on the side.
Look along the side edge of the seat.
On mine it's designed so you can put a small padlock through some holes to stop this lever (so locking seat on).
You pull it back and while holding it back pull the back of the seat up and slightly back. This releases also slides it out of the hook at the front.
When putting back on slide the front in so it hooks on the tab at the tank.
I've done it a few times and missed. Looks ok but not secured.
You can lift the front on the seat near the tank to check. If it lifts up try again Wink
Hope this helps Thumbs Up
WULFSTAN
PostPosted: 13:38 - 15 Oct 2013    Post subject: Reply with quote
Thanks alot map.
The last post was made 13 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 46.62 Kb
