| jason3249 |
 jason3249 Nitrous Nuisance
| DMCpro |
 DMCpro Traffic Copper
| stevelup |
 stevelup Renault 5 Driver
| jason3249 |
 Posted: 12:25 - 15 Oct 2013 Post subject: |
Thanks mate are try that
Its passed a mot with them on
Just didnt make know sense that it dont go no brighter
| barrkel |
 barrkel World Chat Champion
 Posted: 12:27 - 15 Oct 2013 Post subject: |
I'm aware of two different ways high vs dipped beams are implemented in bikes.
The first type use single-filament bulbs (two contacts; typically H1) for both high and low beams. The high beam bulbs are unlit when dipped, and the bulbs are optimally positioned for a full cone of light facing forward. The dipped beam bulbs are offset from optimal position to give a low-biased beam, and the aim is below level; and they're usually on all the time.
The second type use dual-filament bulbs (with three contacts; typically H4), usually with a single lamp fitting for both high and low beams. The low beam setting lights one filament, and the high beam lights the other filament; the low beam filament is normally turned off while the high beam filament is lit up (or the bulb lifetime will be greatly shortened). The beam direction comes from the position of the two filaments with respect to the optimal location for reflectivity.
I don't know of any system that physically alters the voltage to the lights to adjust their brightness. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| jason3249 |
 Posted: 12:34 - 15 Oct 2013 Post subject: |
Thanks mate
I emailed some one of ebay
I said do thay have hi beam
And this is what he said
no there single filament bulbs
I through thay go dim on low beam and brighten up for hi beam but thay dont just bright on low and hi beam
| Pol Anorl |
 Pol Anorl Banned
 Posted: 13:39 - 15 Oct 2013 Post subject: |
first test is to put lights on high beam and put a spanner across both battery terminals, if the lights go brighter thrn you have a wiring issue.  ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| stevelup |
The last post was made 13 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
