loobman
mrefc
PostPosted: 02:33 - 17 Oct 2013    Post subject: loobman Reply with quote
Purchased one of these a few weeks ago installed all ok. Not too fiddly like I've read. I just have one problem. The dosing tube will not stay in the oil feed head. Within about 15 mins of riding it pops out.
Any suggestions out there as to the best way of keeping in it the hole
Thanks
jeddy11
PostPosted: 03:00 - 17 Oct 2013    Post subject: Reply with quote
It comes with a cable tie to put round the collar and squeeze tight but i think i used a bit of superglue on mine and had a little excess tube so it pushed into the feed head and not pulled out..
Had one of these on my 125 and it was great i then got another one for my er6f and just couldn't get the flow right and got pissed off after a couple of weeks with the deliver head not sitting right so ripped it off an into the bin..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
The Artist
PostPosted: 08:10 - 17 Oct 2013    Post subject: Reply with quote
They are pretty much universally agreed to be a cheap gimmick which kind of works but needs almost daily maintenance and adjustment.
PostPosted: 09:34 - 17 Oct 2013    Post subject: Reply with quote
If you email Mr Loobman any queries and pictures, he will get back to you personally.
Quote Me Happy
PostPosted: 10:56 - 17 Oct 2013    Post subject: Reply with quote
Bin it and get a Scottoiler, that's what I did.
DrDonnyBrago
PostPosted: 15:29 - 17 Oct 2013    Post subject: Reply with quote
Utter.
Pile.
Of.
Shit.
There is one in my mum's garage somewhere, sitting under a pile of junk... which is the best place for it.
Ed Case
PostPosted: 16:06 - 17 Oct 2013    Post subject: Reply with quote
DrDonnyBrago wrote:
Utter.
Pile.
Of.
Shit.
I dumped mine and that Tuturo thing.
Robby
Dirty Old Man
PostPosted: 13:19 - 19 Oct 2013    Post subject: Reply with quote
They are a pain in the arse.
I once had one set up and working perfectly, but I think that was a bit of a fluke. Certainly they never like being transferred from one vehicle to another.
I haven't use a scottoiler for years, but if they cracked using an electric kit as standard instead of fiddling around with vacuum operation, they must be good by now.
Any chain oiler will still need some ongoing maintenance, never truly "set it and forget it". Loobman falls apart, tutoro I assume also falls apart, Scottoiler used to have frequent failure of the narrow oil delivery tubes.
I like shaft or belt drive.
sprintster
PostPosted: 18:32 - 19 Oct 2013    Post subject: Reply with quote
Why waste another £100? I've had both and don't think the Scottoiler was any better for 5 times the price!
Buy a squirty oil can and put some engine oil on about every 400 miles. Thumbs Up
temeluchus
PostPosted: 02:33 - 20 Oct 2013    Post subject: Reply with quote
this. mine was fine.
sprintster
PostPosted: 09:33 - 20 Oct 2013    Post subject: Reply with quote
Agreed.Had one for two years with no problems.I don't think I worded my first reply properly.I think Loobmans are worth the money but I can't say the same for Scottoilers!
Quote Me Happy
PostPosted: 09:51 - 20 Oct 2013    Post subject: Reply with quote
I don't see it as a wasted £100. My chain is always oiled with the Scottoiler, it saves me faffing around oiling it myself as my bike doesn't have a centre stand. I wouldn't be surprised if it goes a long way towards paying for itself in extending chain and sprocket life.
sprintster
PostPosted: 10:12 - 20 Oct 2013    Post subject: Reply with quote
A Loobman does the very same for about 18 quid! The guy's only got a slack feed tube! Rolling Eyes
Serendipity
PostPosted: 11:57 - 20 Oct 2013    Post subject: Reply with quote
I put a Loobman on my bike, but removed it after a few months due to a serious and potentially dangerous flaw in the design. When I ordered the Loobman they sent me one of the new ones with the hard plastic reservoir with the push button to open the flow. The idea being you press the button for 2 seconds and immediately set off, oil flows down the pipe and drips onto the chain.
Then one day I pressed the button and it stuck down. The unit then spunked half the reservoir of oil all over the chain, floor, wheel, tyre and several passing kittens. Trying to pull the button back up resulted in it coming off in my hand. Not impressed.
Road dirt had got into the mechanism and caused the issue. Giving it a good clean solved the problem, only for it to re-occur a few weeks later. Thinking that the squeezy bottle type reservoir seemed like a better idea I wrote to Loobman to ask if I could swap to that type, but he was out of stock.
Having a chain oiler that I need to regularly clean and maintain seems like a totally fvcking stupid waste of time. I may as well just regularly clean and maintain my chain. Rolling Eyes
Anyway. Familiar end to the story. Bought a second-hand Touring Scottoiler from Fleabay. Made sure not to fit it like a retard and what d’ya know? It works perfectly. No maintenance required and I only need to top it up approximately once every 6k miles. Chain wear just stops. I never need to adjust it. The chain was on the bike when I bought it last year so I don’t know how many miles it’s covered, but I’ve added 20k since then and it still appears in great condition. I suspect that what’ll eventually kill it is the sprocket teeth starting to hook. When that happens I’ll replace the C+S as a set. Thumbs Up
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
PostPosted: 12:22 - 20 Oct 2013    Post subject: Reply with quote
Tutoro is in the bin, Loobman dual feed head is in the bin and replaced with a single piece of cable tie shoved up the japseye of the tube.
If you want to do it in the cheap and don't mind the inevitable fiddling around, Google DIY chain oiler and get bodging.
The last post was made 12 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 87.51 Kb
